土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 低造价乡村建筑实践:安吉大雁洼小房子其实建筑事务所
发布于:2021-01-21 13:41:21 来自:建筑设计/公共建筑设计 [复制转发]
感谢 其实建筑事务所的分享
△ 项目视频  摄像:山间影像
年初,其实建筑受华腾牧业委托,设计其位于安吉的一个宿舍。
Earlier in this year, ALL Studio was asked by HUATENG Co.,Ltd. to design a dormitory in Anji.
△ 场地北侧望向大雁洼 ?摄影:吴清山
小房子西北临水塘“大雁洼”,东北面对通往附近村庄的马路,西侧为猪舍。业主要求其用于接待及部分员工住宿,同时还需要容纳一定公共活动的空间。
The project is located in the northwest of Dayan lake, facing the road leading to the nearby village in the northeast side. The building is required by the client to be used for accommodation, as well as contain space for public activities.
△ 场地鸟瞰图 ?摄影:吴清山
由于项目北侧自然资源丰厚,相比原有建筑背朝大雁洼,我们认为新建筑应该与大雁洼之间的关系更接近一些。新建筑布局中,建筑主界面朝向东侧,院子中设有一条面向大雁洼的长廊,其与大雁洼之间保留了原有场地的一排水杉,从内院望向大雁洼,长廊的钢柱与水杉共同形成框选、分割水面的竖向结构。穿越长廊,便可到达小埠头。
Due to the abundant natural resources on the north side of the project, compared with the original building with its back facing to Dayan Lake, we consider that the relationship between the new building and Dayan Lake should be closer. In the layout of the new building, the main elevation of the building faces to the East. There is a long corridor facing Dayan Lake in the courtyard. A row of Metasequoia reserved from the original site is located between the yard and lake. The steel columns of the corridor and Metasequoia together form a structure of frame in front of the waterscape. Through the corridor, people can reach the small quay by Dayan Lake.
△ 建筑与大雁洼及周边环境的关系 ?摄影:吴清山
△ 埠头、保留的七棵杉树、长廊之间的关系 ?摄影:吴清山
△建筑主入口  ?摄影:吴清山
场地设计中,建筑与院子被分割成两块不同材料的区域:水泥稻场和红砖院落。入口稻场与大雁洼之间有一个略高起的台地,预示了这个区域停顿、驻留的属性。
In the design, the building and yard are divided into two areas with different materials: c ement field and red brick yard. There is a slightly higher platform between the entrance field and the   lake , which indicates that the area’s property for pause and stay.
△ 红砖院落入口 ?摄影:吴清山
△ 穿过长廊望向建筑主体 ?摄影:吴清山
△ 供人停留的红砖院落、景观与建筑的关系 ?摄影:吴清山
△ 红砖院落局部 ?摄影:吴清山
△ 红砖院落忙碌的村民 ?摄影:吴清山
△ 廊道与院落的关系,院落中保留的大樟树  ?摄影:吴清山
△ 水边埠头望向建筑 ?摄影:吴清山
由建筑,廊子,公厕,景观台地等空间要素组成的场域中,除承载基本住宿功能外,此区域还给村民一定公共活动的可能性,如交谈劳作、钓鱼休憩、公厕等。 在大雁洼不再作为灌溉水系的今天,我们希望重新拉近人们与这片场域的联系。 场地的空间要素中,有一间独立厕所 , 位于大雁洼湖边,是项目中唯一的混凝土空间,是红砖区域的核心。窗户的高度与人在如厕时高度相关,同时建筑体往西侧的旋转动作使人坐下后可以看到对岸的山林。厕所的洗手台被设置在建筑体外部,上部的混凝土挑板强调着人从厕所出来洗手的动线关系。洗手的动作面向水景,人与自然的对望关系在此时再现。
There are several space elements in the site, include  “building”, “corridor”, “toilet”, “terrace”.Among the space elements, there is an independent toilet, which is located by the Dayan Lake.It is the only space made of concrete in the project and it’s the core of the red brick yard. The height of the window is related to the height when people use the toilet. At the same time, the rotation of the building to the west side makes people see the mountains on the opposite bank when people sitting down. The washbasin of the toilet is set outside of the building, and the concrete cantilever canopy emphasizes the dynamic relationship when people coming out of the toilet to the way of wash hands. The movement of washing hands faces to the waterscape, and the relationship between people and nature reappears at this time.
△ 大雁洼、埠头与独立卫生、保留的楝树之间的关系 ?摄影:吴清山
△ 独立卫生间与水边保留的楝树之间的关系 ?摄影:吴清山
△ 施工中的独立卫生间 ?李诗琪
小房子的预算不高,我们希望在低造价的基础上最大化利用场地中的自然资源。整个设计中绝大部分选择基础建筑材料,如水泥砖、涂料、彩钢瓦、红砖、水泥地等。设计完全保留了原始场地中的树木,通过地形连接及视线关系处理,将保留的植物融入小房子的景观体系中。
Cause the low-budget of the project, we hope to retain and maximize the use of natural resources in the site. In the whole design, basic building materials are used, such as: cement floor, wall painting, color steel roofing, red brick, etc. The design retains the original trees in the site completely, and integrates the reserve plants into the landscape system of the project   through terrain connection and sight relationship processing.
△ 独立卫生间与长廊、红砖地基之间的关系 ?摄影:吴清山
△ 台地与保留景观  ?摄影:吴清山
△ 阳光穿透花格墙带来的光影效果?摄影:李诗琪
△ 院内容纳的公共活动  ?摄影:吴清山
△ 单个住所室内望向院子?摄影:吴清 山
△ 单柱悬挑屋檐下的红砖院落?摄影:吴清山
△ 建筑东南立面 ?摄影:吴清山
△ 建筑细部 ?摄影:吴清山
建筑细部,向大雁洼跌落的台地关系 ?摄影:吴清山
△ 院内望向大雁洼  ?摄影:吴清山
△ 隔大雁洼望向小房子 ?摄影:吴清山
 项目图纸
总平面图
平面图
立面图
立面图
轴测图
概念手绘图-院子
概念手绘图-独立厕所
项目信息
项目名称 : 安吉大雁洼小房子
项目类型:建筑 /景观
项目地点:浙江省安吉县天子湖镇百家园自然村大雁洼旁
设计单位:其实建筑事务所
主创建筑师 : 李诗琪
设计团队完整名单:李诗琪、金镭、艾梦江
业主:浙江华腾牧业
造价:建筑造价:19万元;景观造价:13万元
建成状态:已建成
用地面积(平方米): 925 平方
建筑面积(平方米): 111平方
公共建筑设计
51.18 万条内容 · 448 人订阅
由传统谷仓改造而成的现代图书馆
施泰姆勒建筑事务所(Steimle Architekten)将德国克瑞斯布隆-阿姆博登塞村(Kressbronn am bodense)的一个前谷仓改建成一个图书馆和社区中心,其玻璃开口由倾斜的垂直百叶窗遮挡。 这座前农业建筑位于克里斯布隆市中心,靠近村里的市政厅和节日大厅。 施泰姆勒保留了旧谷仓的特点,同时将其转化为克瑞斯布隆图书馆(Kressbronn Library)。
