土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 百年柿子园里长出的建筑:上苑宅Robot3Studio
发布于:2021-01-20 11:46:20 来自:建筑设计/公共建筑设计 [复制转发]
  感谢 Robot 3 Studio 的分享
△ ? Robot 3 Studio
这个房子位于北京城的北边,燕山脚下。建筑用地在院落一角,以一棵柿子树为界,前宽后窄,六十平米左右。
The house is located in the north of Beijing at the foot of yanshan mountain. The building land is in a corner of the courtyard, bounded by a persimmon tree, about 60 square meters wide in front and narrow in back.
△ 东侧 立面
这里之前是一片柿子园,树龄都已过了百岁,站在园子里就可以感受到百年光阴凝结在这里,新建的房子应该是从这片地里土生土长出来,浑然天成而充满生命力度的。
It was a persimmon garden here before, which’s trees age have been over hundred years. Standing in the garden you can feel a condensation of history. Thus the new house should be born and bred in these fields, full of life and nature.
△ 建筑外立面
建筑分为两层,主体埋进地下两米。通过一条廊道拾级而上,端头有楼梯可直上屋顶,站在屋顶,园子的景色一览无余。一层的入口也藏在廊道的里处,抬步进屋由东向西依次排列书房、卫生间和卧室,卧室西侧开大窗,不用借景,景就在屋中,窗外的柿子树正好遮阳。贴北墙有一道楼梯,楼梯上方开有天窗,顺着光线下来,地下一层挑高三米四,靠西侧是一长条窗,清风穿堂而过,捎走夏日的湿闷,下午的时候阳光可以直扫屋尾。北墙开有一门,门外走廊连接着老房子的地下室,走廊的尽头开了一个玻璃屋顶的厨房,在这里烧出的菜可以称得上光合味道了。清早,雾气未散尽,日头刚打东边起来,在院子里四下走走,馀韵悠然。
The house has 2 floors, with the main body buried 2 meters underground. Step up through a corridor, the end of the stairs can be straight to the roof, where the whole garden view can be take. The entrance of the ground floor is also hidden in the corridor, the study, bathroom, and bedroom are arranged from east to west. There is a staircase against the north wall, with a skylight above it. The underground floor is 3.4 meters high with a long window on the west side. The cool wind passes through the hall, taking away the humid summer air, and the sunlight could touch the whole room in the afternoon. The north wall is opened by a door, and the corridor outside connects to the basement of the old house. At the end of the corridor there is a glass-roofed kitchen, where the food is as it mixes the light.
△ 柿子园里的建筑
建造这个房子有些条件限制,一是高度,二是预算不能超过二十六万,所以为了满足使用功能,建筑的一部分须埋进土里,这个半地下室为了解决防水的问题,同时考虑到施工水准,所以整个建筑决定以混凝土为主要材料整体浇筑,这样也可以省去大部分室内装饰的工作以节省费用。一层南侧开窗墙面使用砌块砖,这些都是国内最基础和成熟的建造方式,完成质量会较有把握和冗余度。
There are some limit conditions to build this house, one is the height, the other is the budget can not exceed 260,000 RMB. In order to fulfill functions, part of the house has to be buried in the ground. Solving the problem of waterproofing and considering the construction level, the semi-basement decided to take concrete as the main material to be poured as a whole, which could also save most of the interior decoration work and cost. The window wall on the south side of the second floor is constructed with block bricks, which are the most basic and mature construction methods in China, also the finished quality will have greater redundancy.
△ 建造过程
△ 卧室
△ 一层走廊
如果仅仅只是满足于使用需求,那这个房子就只是一个普普通通的方盒子,如何破题?“时间”给出了答案,要做出嵌凿进时间的建筑。不用加法,做减法,以刀代笔,凿刻出来。
If it's just for use, the house will be simply an ordinary square box. How to break the routine? "Time" gives the answer, to design a house embedded in time. Do nothing add, do subtraction, chiseling out space with a knife as a pencil.
△ 负一层透光窗
△ 负一层东、南侧
△ 负一层西侧
△局部细节
中国的哲学和美学质别于任何国度,“志气和平,不激不厉而风规自远”是最质朴、根本的世界观。建筑是涵盖生存且远高于生存的认知途径,故而人的精神砌筑进建筑的烙印就不可磨灭。
The intrinsic nature of Chinese philosophy and aesthetics is different from that of any other country. “With peaceful ambition and least competition,one’s morals will spread faraway” is the simplest, most fundamental world view. Architecture is a cognitive approach that covers and far surpasses survival, therefore, people's world view and view of life and death could be imprinted on architecture indelibly.
 项目图纸
△ 模型图
△ 平面图
△ 立面图
△ 剖面图
△ 草图
设计机构:Robot 3工作室
建筑设计:潘飞、韩冬、王植、令重山
项目地址:北京市怀柔区上苑艺术公社
项目类型:住宅建筑
建筑面积:118平米
材料:混凝土、混凝土砌块、玻璃
设计时间:2018.8-2019.3
建成时间:2019.7
摄影:Robot 3工作室
Architect:Robot 3 Studio
Design Team: Pan Fei,Han Dong,Wang Zhi,Mountain Ling
Location:Shangyuan Art MuseumSynopsis,Huairou District, Beijing
Project Type:Residential building
Building Area: 118 sqm
Building Material: Concrete,Concrete Block,Glass
Design Period:2018.8-2019.3
Completion: 2019.7Photographer:Robot 3 StudioRobot 3
公共建筑设计
51.18 万条内容 · 448 人订阅
圣莫尼卡学院艺术综合体,怎样成为创意工厂的?
格里姆肖工作室(Grimshaw )最近透露了圣莫尼卡学院(Santa Monica College)校园内一座艺术综合楼的设计方案,该综合楼由三幢楼组成,由露天广场连接。 这个占地21000平方英尺(1950.9平方米)的教育设施,将取代这个加州社区学院西端现有的停车场。 格里姆肖在洛杉矶的办公室与圣莫尼卡学院(SMC)的教师密切合作,设计这座大楼,目的是促进跨学科的实验。
