土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ “Y字型”办公建筑设计
“Y字型”办公建筑设计
发布于:2021-01-14 14:46:14 来自:建筑设计/公共建筑设计 [复制转发]
这座位于Krinkels BV公司总部大楼的特色楼梯是由国际特色楼梯制造商和创新楼梯系统设计师Eestairs、Paul de Ruiter Architects、木艺师Jakko Woudenberg和Winters bouw en ontwikkeling四方合作的结果。
Krinkels的设计要求是让建筑与景观场地共存,提供一个低压力的环境和幸福感。Paul de Ruiter建筑事务所交付了一座高度透明、节能的建筑,其圆形的中央中庭有一棵阿姆斯特尔王树和绿色的墙壁。
This feature staircase at the headquarters building for Krinkels BV – specialists in creating environmentally sustainable spaces – is the result of a four-way collaboration between Eestairs, an international manufacturer of feature staircases and designer of innovative stair systems, Paul de Ruiter Architects, wood artist Jakko Woudenberg and Winters bouw en ontwikkeling. Krinkels’ brief was for a building that co-existed with its landscaped site, providing a low-stress environment and sense of well-being. Paul de Ruiter Architects has delivered a highly transparent, energy-efficient building with a circular central atrium featuring a Ficus Amstel King tree and green walls.
中庭的戏剧性中心点是由Paul de Ruiter建筑事务所设计的一个3000平方米的艺术品,代表着树木生长的环状物,它横跨底层,并沿着两个弯曲的楼梯向上延伸到一楼。
Jakko Woudenberg和其他三位工匠花了几个月的时间在底层和一楼制作橡木和柚木 "环",然后无缝地延伸到两个钢制楼梯上。
他们用蒸汽弯曲了40公里长的柚木和橡木细条,并将其粘在木质基材上。与EeStairs项目负责人Johan Floor合作,Woudenberg制作了两套楼梯的扁平化、毫米级精度的模板,将底层的图案延续到楼梯上,使其与上层的图案完全吻合。
Paul de Ruiter建筑事务所的生态相关项目包括位于荷兰Amstelveen的 "树之桥 "和位于Oosterwolde的生物经济创新中心。
The atrium’s dramatic centre-piece is a 3,000 m2 artwork designed by Paul de Ruiter Architects representing tree growth-rings spreading across the ground floor and up two curving staircases to the first floor. Jakko Woudenberg and three other craftsmen spent several months creating the oak and teak ‘rings’ on the ground and first floors, which then seamlessly extend up the two steel staircases. They steam bent 40 km of thin, metre-long strips of teak and oak, gluing them to wooden substrates. Working with EeStairs project leader Johan Floor, Woudenberg made flattened, millimetre-accurate templates of the two sets of stairs, continuing the ground floor patterning up the staircases so that they exactly fitted the patterns on the upper floor. Paul de Ruiter Architects’ eco-related projects include the Bridge of Trees at Amstelveen and the Biosintrum hub for bio-economic innovations in Oosterwolde, both in Holland.
Krinkels大楼的中庭是参观者首先体验到的地方,它被构想为大楼的生命之心。巨大的树木、绿色的墙壁和壮观的花纹木地板突出了Krinkels的环保专长,与中庭光滑的白色楼梯形成了鲜明的对比。
Jakko Woudenberg称这件艺术品为 "Innsaei",冰岛语的意思是由内而外地了解一些东西。两层楼的生长环尺寸不同,因此保持图案的流畅性在技术上具有极大的挑战性,尤其是当它流向两个弯曲楼梯的立柱时。
The atrium of the Krinkels building is the first thing visitors experience, conceived as the living heart of the building. The monumental tree, green walls, and spectacular patterned wood flooring highlight Krinkels’ environmental expertise, providing a dramatic contrast with the sleek white atrium stairs. Jakko Woudenberg called the artwork ‘Innsaei’, Icelandic for knowing something from the inside out. The dimensions of the growth rings differ across the two floors, so maintaining the fluidity of the patterning was technically extremely challenging, in particular as it flows up the risers of the two curving stairways.
地面平面图
首层平面图
屋顶平面图
平面图
立面图
剖面图
分析图
设计单位:Paul de Ruiter建筑事务所
地点:新西兰
建筑面积:3000 m2
建筑年份:2019
  • hbs1612
    hbs1612 沙发
    简单,好设计,值得学习研究
    2021-04-13 09:59:13
  • wuhee98
    wuhee98 板凳
    简洁,精致,不突兀,能很好的融入周边景致!值得学习!就是不晓得能否满足防火规范的要求?
    2021-03-17 14:53:17
公共建筑设计
51.18 万条内容 · 448 人订阅
漂亮!!极简现代——中学教学楼
曼谷预科大楼D座位于曼谷预科中学校园内,主要用于10-12年级的教室、六年级和宽敞的学生活动空间。 Bangkok Preps building D, located on the Bangkok Preps Secondary Campus, is mainly use for grade 10-12 classroom, sixth form and spacious common space for student activities.
