深圳是一个诞生于上世纪90年代的城市,一个充满新意的地方。它是中国科技创新的摇篮,人们认为这个城市和其城市生活是完全面向未来的。BAM的项目地点位于深圳的山区,因此造就了动态的高差。
Shenzhen is a place of utter newness, a city born in the 1990s. It is the cradle of tech innovation in China and regards itself and its urbanism as entirely future-focused. BAM’s project site is set within a mountainous region of Shenzhen, resulting in dynamic height differences.
项目场地由两种完全不同类型的景观组成,一种是起伏的街景,它穿越险峻的断面条件,环绕着平坦的中央景观,住宅塔楼则从这里出现。在场地的较低一侧,街道是作为通往商业和一个小型巴士总站的通道,隐藏在架空景观裙楼之下,并且裙楼上有供住宅使用的休闲花园。
The landscape of the project consists of two entirely different types of landscapes, an undulating streetscape that traverses drastic sectional conditions which encircles the flat central landscape from which the residential towers emerge. At the lower level of the site, the streetscape provides access to retail and a small bus terminal tucked below the overhead landscape podium containing recreational gardens for the residences towering above.
裙楼层面的景观被必要的消防车道不经意地切成两半。BAM将这一元素改变成曲折的道路,通过明亮鲜艳的图案来伪装行车道,从而将两边联系在一起。这条曲折的道路一方面是划分场地的主要元素,也是将场地连接在一起的主要元素,同时还引导居民前往塔楼架空大厅的主要通道。
The podium level landscape is unceremoniously cut in two by the required emergency vehicle circulation. BAM adapts this element into a zigzagging pathway which serves to tie the two sides together by camouflaging the vehicular road through aggressive and insistent patterning. This zigzagging path at once, is the primary factor which divides the site, while also bringing it together, meanwhile acting as the main circulation leading residents to their open-air tower lobbies.
位于项目中心的游乐场的不仅是深圳这个城市的实验性质的证明,也是深圳居民的实验性质的证明。这种由植物、图案、色彩和材料构成的爆炸性的姿态,如此迅速地被文化所吸收,成为常见的、典型的,甚至是通用的,这就是深圳进步的本质和面向未来的快速发展的真实证明。
The playground at the center of the development is a constructed testament to the experimental nature of not only Shenzhen as a city, but its inhabitants. The mere existence of such an explosive gesture of planting, patterning, color, and materials which has become so quickly absorbed into the culture as common place, typical, or even generic, is a true testament to Shenzhen’s progressive nature and rapid future-oriented development.
▽总平面图 Master plan
Project: Buji Residence
Design firm: BAM
Site Area: 18,691 m2
Client: Shenzhen Legend 深圳里城
Construction: 2019
景观规划设计
返回版块25.18 万条内容 · 282 人订阅
遇到对的设计,围墙也这么精彩!收录于话题 围墙 ,本来是一种重直向的空间隔断结构 用来围合、分割或保护某一区域 而在设计师的手中 它不仅可以变得高颜值 而且中看又中用 加入更多功能性的设计
