土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ “阶梯式”公寓住宅,面积从88平米到196平米,每层平面都是不同的形状
发布于:2020-12-18 10:58:18 来自:建筑设计/居住建筑设计 [复制转发]
阿姆斯特丹繁华的Zuidas是一个以雄伟的办公楼为主的商业区,紧挨着火车站,史基浦机场(Schiphol)和阿姆斯特丹市中心。
该项目是这里的第一座人性化,绿色和充满活力的大楼。这座建筑共有11层,包括47套公寓,面积从88平米到196平米不等。南侧是一系列堆叠的绿色露台和阳台,逐渐向外扇形延伸成一个宽阔的基地。
Zuidas is a popular location close to the train station, Schiphol and the city centre of Amsterdam. It’s a business area dominated by imposing office buildings. The George is the first human, green and exuberant gesture here. The festive building has 11 floors and 47 flats, varying in size from 88 to 196 square metres. The south side is a series of stacked green terraces and balconies, which gradually fan out into a wide base.
这个底座坐落在在建筑的两侧,就像一件夏日风中飘扬的裙子。由于公寓彼此相互移动,因此每层平面都具有不同的形状和质量。
实际的外墙是通透的,由三层玻璃组成,可以完全展开,而北侧是三段式立面,玻璃砖砌体的自由浮雕。
两个混凝土入口通往一个绿树成荫的大厅,弯曲的楼梯向上延伸,并在二楼有一个80平方米的公共露台,居民可以在其中聚会。
This base curls up on the sides of the building like a dress billowing in the summer wind. Because the flats shift in relation to one other, each floor plan has a different shape and quality. The actual facade is transparent and consists of triple-glazed fronts, which can completely unfold. The north side is characterised by a trisected facade with a free relief of glazed brickwork. Two concrete entrances lead to a green hall full of trees, a curled staircase leading upward and an 80-square-metre communal terrace on the second floor, where residents can meet among the greenery.
引人注目的碗形屋顶将雨水收集在储水池中,并用PVC面板填充。雨水排放植被时,太阳能为建筑的中央区域供电。该项目致力于在大都市中营造健康的社交生活环境。
The striking bowl-shaped roof collects rainwater in water storage and is filled with PVC panels. While the rainwater drains the vegetation, the solar power supplies the central parts of the building with electricity. The George is committed to a healthy and social living environment in a metropolitan area.
平面图
手绘图
建筑师:Dok Architecten
地点:荷兰
面积:8487平方米
居住建筑设计
28.74 万条内容 · 423 人订阅
室内手绘效果图
