土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 国外多层住宅设计
国外多层住宅设计
发布于:2020-12-17 09:13:17 来自:建筑设计/居住建筑设计 [复制转发]
在安特卫普的Slachthuis区,META完成了Koning Noord公寓建筑:一个拥有26栋房屋、一个托儿所和一个工作空间的项目。
受ISTATE委托,META设计了2块原始混凝土,将它们与围绕内部花园的基座连接起来,用金色电镀铝细木工和栏杆完成了建筑。
 In the Slachthuis district in Antwerp, META has completed the Koning Noord apartment building: a project with 26 houses, a crèche and a workspace. Commissioned by ISTATE, META designed 2 volumes in raw concrete, connected them with a plinth around an inner garden and finished the building with gold-coloured anodised aluminium joinery and balustrades.
通过在概念和执行上优先考虑严格的合理性,META为设计一个宽敞的建筑腾出了空间。
Koning Noord由2栋建筑组成:一个体量在街道一侧,完成了Twee Netenstraat的立面,另一个体量位于地块深处,也连接了相邻的建筑。两个体量在一层通过一个连续的基座连接起来,这个基座环绕着内部花园。
By prioritising rigorous rationality in both concept and execution, META makes room for the design of a generous building. Koning Noord consists of 2 buildings: a volume on the street side that completes the facade row of the Twee Netenstraat and – lying deep on the plot – a second volume that also connects to the adjacent buildings. The 2 volumes are linked on the ground floor by a continuous plinth that folds around the inner garden.
这个基座的屋顶被用作密集的绿色屋顶,除了内部花园之外,形成了第二个水平的绿色区域。有可停放37辆汽车的地下停车场和83辆自行车的棚子。更多的公共功能可以在一楼找到:托儿所,可以从庭院花园和工作空间进入。
The roof of this plinth is used as an intensive green roof and forms, in addition to the inner garden, a second horizontal green area. There is underground parking for 37 cars and a shed for 83 bicycles. The more public functions can be found on the ground floor: the crèche, which is accessible from the courtyard garden and the workspace.
“独特的体量是邻近特殊建筑的结果。底层的基座围绕一个集体的内花园延伸,连接两个体量。”建筑类型规划确保了质量和可负担性。公寓位于两个体量内。
“The idiosyncratic volumetric is the consequence of the exceptional neighbouring buildings. A ground-floor plinth stretches around a collective inner garden and connects both volumes.” – Niklaas Deboutte, META architectuurbureau Typological plan ensures quality and affordability The flats are located in the 2 volumes.
每层有四种类型的公寓,在每一层重复。只有街道一侧的顶层偏离了这一类型规划,以创建两个拥有宽敞屋顶露台的复式公寓。“该项目提供了可负担得起的、为社区量身定制的当代住宅,完全开发。”甚至在开工之前,这个项目就已经售罄。
——Bert Craeghs,
他认为最大程度重复一个类型规划有很多技术优势,增加了设计的逻辑性和可承受性。
There are 4 types of flats per floor which are repeated on each level. Only the top floor on the street side deviates from this typological plan in order to create 2 duplex flats with spacious roof terraces. “The project offers affordable, contemporary housing tailored to a neighbourhood in full development. Even before the works began, the project was completely sold out.” – Bert Craeghs, ISTATE The maximum repetition of a typological plan has many technical advantages and increases the logic and thus the affordability of the design.
窗户开口和露台明显位于彼此下方,创造了一个中性的建筑。最后,结构设计为未来公寓布局的变化提供了足够的灵活性。
灰色混凝土饰以金色的露台和栏杆,每一套公寓都有两扇大窗户。
The window openings and terraces, which are visibly positioned below each other, create a neutral architecture. Finally, the structure was designed to allow sufficient flexibility for possible future changes in the layout of the flats. Grey concrete finished with gold-coloured terraces and balustrades Each flat has two large windows.
通过分组开放和封闭的立面表面,混凝土可以使用木板模板在现场浇筑——传统上是一种昂贵的施工方法——同时在这个项目严格的财务框架内保持可行。
在露台、细木工、栏杆上,原始的灰色混凝土用金色的阳极氧化铝元素完成。“混凝土与木板模板的使用使项目与众不同。”
By grouping the open and closed facade surfaces, the concrete could be cast on site using plank formwork – traditionally an expensive construction method – while remaining feasible within the strict financial outlines of this project. The raw, grey concrete is finished with gold-coloured anodised aluminium elements in the terraces, the joinery, the balustrades,.. “The use of concrete with plank formwork makes the project exceptional.
为了在预算范围内实现这一功能,立面设计被合理化到极致。“- Eric Soors, META建筑局的结构工作是完成工作,内有一个非常详细的胴体,META应用了‘结构作为完成’的原则,这是他们的工作的特点:细心地详细描述胴体。结合严格的场地控制,这使得建筑具有了自己的特色。
In order to make this implementation possible within the budget, the facade design was rationalised to the ultimate extent.” - Eric Soors, META architectuurbureau Structural work is finishing work’ with a carefully detailed carcass Inside, META applied the ‘structure as finishing’ principle that is characteristic of their work: detailing the carcass with care. In combination with strict site control, this results in a building with its very own character.
地面平面图
1层平面图
6层平面图
7层平面图
负一层平面图
立面图
剖面图
建筑师:META建筑事务所
地点:比利时
面积:4671 m2
年份:2020
居住建筑设计
28.74 万条内容 · 423 人订阅
福建某海岛上漂浮着一座600㎡“豪宅”,即使被台风毁了,也没关系
以下文章来源于:一条 海席,是一栋漂浮在 福建东山岛海面上的“豪宅”。 它不与任何陆地、桥梁相连, 像遗世独立的孤岛那样, 被360度的海景包围。 屋主是当地人,外号“ 海岸线 ”, 因为喜欢钓鱼和大海,
