Moscone中心是一个宽敞的、充满光线的空间集合,容纳了各种与会议相关的活动,同时将典型的内向型游客功能与城市的公共生活紧密相连。
该项目由SOM与Mark Cavagnero Associates共同设计,在现有建筑仍在运行的情况下,分多个阶段进行扩建。
Moscone Center is an expansive collection of light-filled spaces that accommodates a variety of convention-related activities while making strong connections between the typically inward-looking visitor function with the public life of the city. Designed by SOM with Mark Cavagnero Associates, the expansion was constructed in multiple phases while the existing buildings remained operational.
莫斯克尼中心位于旧金山市场南部的中心地带--这里有SFMOMA、墨西哥博物馆、非洲散居博物馆和当代犹太人博物馆,占地近20英亩,横跨霍华德街两侧的两个街区,位于经常参观的Yerba Buena花园和儿童花园之间。
Located in the heart of San Francisco's South of Market neighborhood—home to SFMOMA, El Museo Mexicano, Museum of the African Diaspora, and the Contemporary Jewish Museum—the Moscone Center spans close to 20 acres across two blocks on either side of Howard Street, sited between the frequently visited Yerba Buena Gardens and the Children’s Garden.
通过漂浮在地面上的清晰的水平形式,中心获得了一个新的市民形象,框架由白色金属和填充透明和熔块玻璃,沐浴在过滤光线的内部循环。
这些巧妙的图案创造了一个鲜明的特点,同时尽量减少内部的人工照明。
The Center gains a new civic presence through a clear horizontal form floating above the ground, framed in white metal and infilled with transparent and fritted glazing that bathes internal circulation in filtered light. These artfully patterned these facades create a distinct character while minimizing artificial lighting within.
在地面上,以前是空白的或凹进去的正面现在环绕着人行道,新的游客中心、零售空间、大堂和75英尺高的循环中庭具有最大的透明度和渗透性。
在天空中,一个发光的雕塑式屋顶延伸到霍华德街,形成了四个新露台中的一个,创造了天际线的景观,强调了建筑的水平比例。莫斯科恩中心是美国最紧凑、最高效、最可持续的会议中心之一
At the ground, formerly blank or recessed frontages now hug the sidewalks, with maximum transparency and permeability in a new Visitor’s Center, retail spaces, lobbies, and a 75-foot-tall circulating atrium. At the sky, a luminous sculptural roof runs the length of Howard Street and frames one of four new terraces, creating views of the skyline and emphasizing the building’s horizontal proportion. Moscone Center is one of the most compact, efficient, and sustainable convention centers in the U.S.
它的人均碳足迹是世界上较低的,也是国内唯一一个获得LEED白金认证的会议场所。它还拥有最大的屋顶太阳能电池板阵列在旧金山,它提供了近20%的中心力量,和一个积极的地下水和灰水系统,允许中心使用更少的水比扩张之前,有足够的剩余灌溉芳草地艺术花园和供应城市的街道清洁舰队的一部分。
区位图
1层平面图
2层平面图
3层平面图
剖面图
建筑师:Shannon Krick+Skidmore+Owings & Merrill公司
地点:美国
面积:504平方英尺
年份:2019年
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
一处漂亮的木平台,庭院必备木平台是最常见的 室外 场地类型之一, 木材的特性自然温润, 更加”平易近人“, 能够营造出亲切而舒适的环境, 在庭院设计中常常会用到。 当木平台遇到树木, 不需要习惯性的给树砌一个池子, 它们有更好的结合方式, 只需在木平台上给树留一个孔洞, 让树从木头里“钻”出来, 让它们一起生长。
