土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 简约现代——园区办公大楼
简约现代——园区办公大楼
发布于:2020-12-11 09:18:11 来自:建筑设计/公共建筑设计 [复制转发]
IGZ在其扩展园区内的新主楼的落成,是软件公司自身经济定位的重要一步,也是增加农村地区就业机会的更大区域努力的一部分。
IGZ是一家在IT物流和工业4.0领域快速发展的公司:自Covid-19大流行以来,我们经历了数字繁荣,在欧洲金融和经济支持下,创新发展的可能性不断增加。
此外,各个城市为维持和创造就业机会而采取的基础设施措施对整个上法尔茨地区都有影响。由于这些原因,可持续和创新的规划和建设是法尔肯贝格IGZ新园区的核心任务。
 The completion of IGZ’s new main building on its extended campus is a significant step for the software company’s own economic positioning, as well as part of larger regional efforts to increase employment opportunities in rural areas. IGZ is a fast-growing company in IT logistics and Industry 4.0: part of the digital boom we have experienced since the onset of the Covid-19 pandemic and the growing possibilities for innovative developments, fostered by European financial and economic support. What is more, the infrastructural measures put forward by individual municipalities to maintain and create jobs have an impact on the entire Upper Palatinate region. For these reasons, sustainable and innovative planning and construction were the centerpieces of the new IGZ Campus module in Falkenberg.
设计: J. MAYER H.在一次邀请赛中赢得了IGZ园区主楼的设计。该建筑是该园区扩展总体规划中的第一个新建筑。
新建筑长度超过120米,位于场地的最高点,与公司现有的建筑相辅相成,形成一个和谐的整体。
更多的建筑计划用于公司的餐厅、创新中心和其他办公建筑,这些建筑与主建筑一样,清晰而准确地聚焦于场地周围的环境。该建筑采用了当地的材料,如花岗岩和木材,是上法尔茨地区的典型材料。
Design. J. MAYER H. won the design for the main building of the IGZ campus at an invited competition. The building is the first new construction of the site’s extended masterplan. Reaching over 120m in length and sitting at the highest point of the site, the new construction complements existing company-owned buildings, creating a harmonious ensemble. Further structures are planned for the company restaurant, an innovation center, and other office buildings, which, like the main building, focus clearly and precisely on the site’s surroundings. The construction was built using local materials like granite and wood, typical of the Upper Palatinate region.
创新的建筑工程技术确保了建筑概念的整体性。优先考虑利用地热能和光伏系统提供再生能源供应。
新的IGZ建筑明确指出,农村地区的建筑工程不仅仅是为农业、旅游业或当地的娱乐活动而保留。
相反,在这个 "新工作"(工作4.0)的时代,"IGZ-SAP工程师 "的新总部,使他们能够加强与当地的联系,并重申他们作为该地区创新和负责任的雇主的存在。
Innovative construction engineering techniques ensure a holistic approach to the building concept. Priority was given to providing a regenerative energy supply using geothermal energy and photovoltaic systems. The new IGZ building makes clear that construction work in rural areas is not only reserved for agriculture, tourism, or local recreation. Instead, in this age of "New Work" (Work 4.0), the new headquarters of “IGZ-The SAP Engineers”, allows them to strengthen their local ties and reaffirm their presence as an innovative and responsible employer in the region.
建设: 该建筑被规划为钢筋混凝土骨架结构。所有的承重和支撑构件都是由木材和裸露的混凝土制成,创造了IGZ公司总部的视觉蓝图。
隔墙和嵌壁式家具是非承重的,全部由木材和玻璃制成。建筑由各种元素组成,创造了一种轻盈温暖的氛围,同时对未来的变化保持高度的灵活性。灰色的玻璃木立面进一步发展和重新诠释了公司现有建筑的物质性。
Construction. The building was planned as a skeleton structure of reinforced concrete. All load-bearing and bracing components are made of wood and exposed concrete, creating a visual blueprint of IGZ’s company headquarters. The partition walls and built-in furniture are non-load-bearing and made entirely of wood and glass. Composed of various elements, the construction creates a light and warm atmosphere while remaining highly flexible to future alterations. The grey glazed wood fa?ade further develops and reinterprets the materiality of the company’s existing buildings.
建筑依赖于一种被动式温度控制方法,该方法被集成到钢筋混凝土天花板中。因此,供暖和制冷由建筑的混凝土核心温度控制系统来调节。所需的能源由60个地热桩持续产生,每个地热桩有100米深。
The building relies on a passive temperature control method that is integrated into the reinforced concrete ceilings. Heating and cooling are thus regulated by the building’s concrete core temperature control system. The energy required for this is sustainably generated through a total of 60 geothermal piles, each 100m deep.
内部: 在与客户的密切合作下,J. MAYER H.发展了建筑的室内设计概念。Steelcase是工作站家具设计的主要合作伙伴。
阁楼式的工作环境由裸露的混凝土和木材组成,配有Steelcase的Flex系列,旨在让团队的空间更加灵活。
The interior. J. MAYER H. developed the building’s interior design concept in close collaboration with the client. Steelcase was the main partner for the design of workstation furnishings. The loft-like work landscape, composed of exposed concrete and wood was furnished with Steelcase’s Flex Collection, designed to allow teams to make their space more flexible.
家具配备了轮子,使其能适应各种变化形式的个人和团队工作。Flex以其对角线元素和清晰的设计补充了建筑结构的整体几何。
设计的语言通过门厅和其他区域的大型木制装置进行交流,并进一步反映在圆形的可移动桌墙和移动白板上。触感、哑光黑色表面的选择,进一步匹配了贯穿整个建筑的木材和混凝土元素。
The furniture is equipped with wheels, making it adaptable to various, changing forms of individual and group work. Flex complements the overall geometry of the building’s structure with its diagonal elements and clear- cut design. The design’s language is communicated through large-scale wooden fixtures in the foyer and other areas and reflected further in the rounded shapes of the movable desk-walls and mobile whiteboards. The choice of haptic, matte black surfaces, furthermore matches the wood and concrete elements present throughout the building.
Steelcase公司与Kvadrat公司合作,使用他们的优质面料生产了一系列新的座椅区域和办公桌椅(Please)。
Viccarbe的软座产品被用于公共区域。竣工。该项目于2020年秋季完成。由于内部家具的灵活性和建筑的几何形状,内部布局可以很容易地适应Covid-19相关工作场所的变化和要求,如适应卫生法规和确保员工的安全距离。
Steelcase collaborated with Kvadrat, using their high-quality fabrics to produce a new range of seating areas and desk chairs (Please). Viccarbe's soft seat products were used for communal areas. Completion. The project was finalized in autumn 2020. Thanks to the flexibility of the interior furnishings and the building’s geometry, the inner layout can easily be adapted for Covid-19 related workplace changes and requirements, such as accommodating for Hygiene regulations and ensuring the safe distancing of employees.
区位图
平面图
立面图
剖面图
建筑师:J.MAYER H
地点:德国
面积:8000 m2
年份:2020
公共建筑设计
51.18 万条内容 · 448 人订阅
田园里的展示中心鄢陵建业君邻大院时光馆
在当下气候变化、全球变暖的情况下, 混凝土和钢筋的建筑大楼, 已经对生态环境造成了污染。 建筑师面临着可持续设计与绿色设计的需求。 木构建筑渐渐得到建筑师的青睐, 木构较于钢筋水泥的混合, 更加轻便以及绿色环保, 成执设计&隽执科技团队运用木构建筑的优势,
