土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 悬浮的建筑形式——电影院设计
悬浮的建筑形式——电影院设计
发布于:2020-12-07 14:05:07 来自:建筑设计/公共建筑设计 [复制转发]
项目视频
将投影贴图技术的幻觉与舞台表演者的真实感融为一体的表演,其独特性是激发观众想象力的关键。这激发了设计师团队的想法,将这些幻觉技术融入到建筑中,与建筑产生同样的想象效果。
The uniqueness of a performance which integrates the illusion of projection mapping technology with the realism of stage performers is key in generating the imagination of the audiences. This sparks the ideas for the designer team to incorporate these illusion techniques to create the same effect of imagination with architecture.
为了达到各种惊艳的效果,人们研究了几种幻术,特别对 "悬浮 "的概念进行了进一步的讨论和研究。它通过让沉重的剧场体量在视觉上毫不费力地漂浮在地平面之上,极大地增强了幻觉的想象力。
为了达到悬浮的效果,包括阴影、从下面看到的建筑体量和体量下的空隙等几个元素都对完成设计目标起着至关重要的作用。
Several illusion techniques have been studied to achieve various stunning effects and the concept of ‘levitation’ was particularly discussed and studied further. It dramatically enhances the imagination of illusion by allowing the heavy theatre mass to visually float effortlessly above the ground plane. To achieve the effect of levitation, several elements including shadows, building mass seen from below and clear space or void under the mass all play an essential role to accomplish the design objective.
此外,建筑形式需要保持简单,代表一个 "盒子",便于视觉理解。诀窍是通过在墙面和天花板上加入镜面,将剧院的预功能空间伪装成一个清晰的空间或空隙,让悬浮的盒子可以感知地漂浮在上面,这样既隐藏了结构,又反射了周围的环境和天空。
Moreover, the architectural form is needed to be kept simple representing a ‘box’ for ease of visual understanding. The trick is to disguise the pre-function spaces for the theatre at ground level as a clear space or void to allow the levitating box to perceivably float above by incorporating mirror planes on both walls and ceiling which hide the structure and reflect the surroundings and sky.
由于包厢与主体结构悬臂8.75米,采用钢结构,使游客能更深入地感知漂浮包厢底座的反光,从而使剧场包厢的尺寸为15×50×14米,漂浮在空中。
下方的反射池增强了包厢下方的高度效果,天花板上安装的照明灯也有助于强调低光条件下的天花板边界。
Since the box is cantilevered from the main structure by 8.75 meters, steel structure is used so that visitors can perceive the reflection of the floating box’s base in greater depth which results in the size of the theatre box at 15 x 50 x 14 meters floating in the air. The reflective pond below enhances the effect of the height under the box and the lighting installed in the ceiling also helps emphasize the ceiling boundary under low light conditions.
利用芭堤雅的沿海微风;此外,动感的立面被用来创造另一种表达动态的幻觉效果。利用一种特殊形状的钻石片,由描绘泰国传统艺术的折叠铝片制成,用于连接到张力电缆的动感组件。
在微风习习的日子里,这些3万块金色钻石一样的石片会形成波光粼粼的效果,仿佛一片海洋,供游客体验。
Taking advantage of the coastal breeze in Pattaya; furthermore, a kinetic fa?ade is used to create another illusive effect that expresses dynamic. A specific shape of diamond pieces made of folded aluminum sheets depicting traditional Thai art are utilized for the kinetic components attached to tensioned cables. On a breezy day, these 30,000 golden diamond pieces create sparkling wave effects resembling an ocean for visitors to experience.
设计分析图
区位图
1层平面图
2层平面图
3层平面图
屋顶平面图
立面图
剖面图
剖面图
细部图
建筑师:Architects 49
地点:泰国
面积:16000 m2
年份:2017
公共建筑设计
51.18 万条内容 · 448 人订阅
真正的城市公共空间-Banquín长椅Mecanismo
Concentrico06国际建筑设计节呼吁人们对城市及环境进行反思。在此基础之上,设计团队对现有城市要素进行分析,找到具有潜力却尚未被利用的要素,最终选择长椅作为研究对象。 ▼社区前的长椅 ? Mecanismo 设计团队侧重于使长椅不仅仅是只能满足行人休息需求的城市家具。现有城市公共座椅的设计、形状和大小只能供一个人使用,它们从共有变为私有。设计团队试图将长椅变成真正的城市空间,城市中人们的聚会场所。
