土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 高端住宅创新的处理
高端住宅创新的处理
发布于:2020-12-04 14:34:04 来自:建筑设计/居住建筑设计 [复制转发]
该项目在威斯敏斯特历史悠久的鸟笼道保护区创造了新的住宅类型,由兰德证券公司在伦敦发起的一项新的高端住宅开发项目,旨在创建28套公寓和3栋联排别墅的创新组合。
临近白金汉宫,横跨两条街道,各具特色和城市形态,其西面是传统的伦敦排屋,而东面是壮丽的维多利亚式豪宅。
该项目需要对环境作出回应,以在一个复杂的单体建筑内实现连贯一致的方案,从而将豪宅大小的核心建筑与联排别墅相结合。
An innovative residential block creates a new typology within the Westminster conservation area This new high-end residential development in London initiated by Land Securities sought to create an innovative combination of 28 apartments and 3 townhouses within a single block. A complex site in the Birdcage Conservation Area, close to Buckingham Palace, straddles two streets, each with its distinct character and urban forms of traditional London row townhouses to the west and grand Victorian mansion blocks to the east. The project demanded a particularly sensitive approach to context to achieve a coherent and unified scheme within a complex single volume whereby a mansion sized core building is combined with a more domestically scaled interpretation of townhouses.
本项目通过对弓形窗的新颖诠释,与奥雅纳的外立面专家合作,共同开发了这一概念:重新审视了英国建筑中反复出现的元素。
这种处理既参考了周围地区的历史背景,又提供了视觉上独特的现代外观。
弧形玻璃从建筑中延展出来,赋予立面一种雕塑感,使街景具有凹凸感。它还创造了有价值的附加内部区域,同时在内外部提供了一个半户外的漂浮空间。
在整个过程中,材料以类似的创新方式进行处理。在砌砖过程中有细微的变化,以确保整个方案的统一性,同时也区分了豪宅和联排别墅的外立面。
The difference in scales is partly mediated through an innovative treatment of the classic bow window. We worked closely with facade specialists at Arup to develop the concept: a contemporary take on one of the recurring themes of English domestic architecture. The treatment references the historic context of the surrounding areas but also provides a visually distinctive and contemporary facade. The curved window glazing protrudes from the building to give a sculptural quality to the elevations, animating the streetscape with convex and concave forms. It also creates valuable additional interior area offering a semi-external floating space which is simultaneously inside and outside. Throughout, materials are approached in a similarly creative manner. Subtle changes are made within the brick laying to ensure unity across the scheme but also create distinction between the facades for both mansion and townhouses.
该建筑采用了一系列可持续和节能措施,例如屋顶和光伏发电,为建筑,居住者和周围环境提供了好处,并实现了可持续生活的4级准则。
该项目需要与利益相关者进行广泛而仔细的协商,以创建一个突破性的方案,从而实现城市致密化和语境敏感性。
最初的设计原则证明了它们在不断变化的开发人员中的适应能力。Castle Lane是定制智能设计的一个示例,可帮助我们的客户建立品牌并开发引人注目的终极产物。
The building incorporates a range of sustainable and energy efficient measures, such as living roofs, and photovoltaics, to provide benefits for the building, its occupants and surrounding environment and achieved a level 4 Code for Sustainable Living. The project required extensive and careful negotiation with stakeholders to create a ground breaking scheme which achieves urban densification and contextual sensitivity. Robust design principles established at the outset proved their resilience across changing developers. Castle Lane is an example of bespoke, intelligent design which helps our clients build brands and develop striking end products.
平面图
立面图
概念图
建筑师:NAME architecture
地点:英国
面积:4600平方米
居住建筑设计
28.74 万条内容 · 423 人订阅
室内手绘效果图
室内手绘
