作为powerhouse系列的一部分,snhetta与合作方R8 property、skanska和asplan viak共同实现了telemark未来工作空间的可持续发展模式。
作为snhetta的第四座正能量建筑,"powerhouse telemark "与类似的新建筑办公室相比,每年的净能耗减少了70%,而且在整个生命周期内产生的能量比消耗的能量还要多--这为环境可持续建筑的建设树立了新的标准。
通过标准化的内部解决方案和联合办公空间,租户可以根据需要扩大办公空间,在远程办公解决方案需求不断增加的全球背景下,提供急需的灵活性。
snhetta及其团队设计的 "动力屋telemark "提出了一个新的可持续建筑类型模型。随着世界人口和气候危机的严重性不断增加,snhetta、R8地产、skanska和asplan viak的合作团队在挪威telemark引入动力屋工作空间,作为跨行业工作的挑战,以更负责任的方式进行建设。
该建筑引人注目的太阳能屋顶以24°的倾斜度缓缓倾斜,超过了建筑体量的极限,扩大了屋顶的表面,并确保从光伏顶棚和建筑南面的光伏电池包覆的外墙中获取最大的太阳能。
snhetta and its team design ‘powerhouse telemark’ to propose a new model of sustainable building typology. the energy sector and building industry account for over 40% of global industry’s heat-trapping emissions combined. as the world’s population and the severity of the climate crisis continue to grow, the collaborative team at sn?hetta, R8 property, skanska, and asplan viak, introduce powerhouse workspace in telemark, norway as a challenge to work across industries to build more responsibly. the building’s striking solar roof gently slopes at a 24° tilt to surpass the extremities of the building’s volume, expanding the roof’s surface and ensuring a maximum amount of solar energy can be harvested both from the photovoltaic canopy and the building’s PV-cell clad south-facing fa?ade.
snhetta的 "动力屋telemark "三面都有木质栏杆,为最暴露在阳光下的外墙提供了自然的遮阳。
混凝土板使建筑具有类似于石材结构的密度,白天储存热能,晚上缓慢释放热量。每层楼的边界区域都有一个低排放系统,通过在地下350米处挖掘的地热井确保建筑有效地冷却和加热。
on three sides, sn?hetta’s ‘powerhouse telemark’ is clad with wooden balusters providing natural shading on the most sun exposed facade. behind the wooden balusters the building is covered with cembrit facade panels which give the building a unified expression. functioning just as a passive house, the building is super insulated and features triple isolated windows throughout. the concrete slabs lend the building a density akin to that of a stone structure storing thermal heat during the day and slowly emitting heat during the evening. a low ex system with water loops in the border zones of each floor, assures that the building is efficiently cooled and heated through geothermal wells dug 350 meters below ground.
倾斜的体量,45°的倾斜缺口,保持了一个清晰可辨的表达方式,在其周围的赫罗亚工业园区的工业背景下脱颖而出。内部,建筑设有一个酒吧门厅,办公空间,包括两层的联合办公空间,一个共享的员工餐厅,顶层会议空间和一个俯瞰峡湾的屋顶露台。
两个大型楼梯连接着大楼的底层和顶层,从接待区一直到员工餐厅和顶层会议室。一个独特的直木楼梯在第九层出现,在视觉上将员工餐厅和顶层会议室区域连接在一起,并将游客引向大楼的屋顶露台。
建筑师:斯诺赫塔(snhetta)
地点:挪威
年份:2020
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
简约现代上海音乐学院零陵校区建筑收录于话题 上海音乐学院零陵校区的建成,标志着这所中国历史悠久的高等音乐学府再添新翼、发新枝。 位处都市繁华活力与历史人文积淀并存的零陵路,交通繁忙人流熙攘。基地西侧、北侧现有高层一字排开,基地东侧、南侧6 层居民小区紧贴红线。 法国何斐德建筑事务 所对复杂的场地进行梳理,校园被清晰地分为教学区、生活区以及未来发展区三部分,同时通过一个完整的校区公园连成一体。
