马斯克建筑事务所被提名为 "清凉阿布扎比 "全球设计竞赛的十个获胜团队之一。他们的提案 "The Oasys "是一个系统,让阿布扎比的居民可以在不感到炎热的情况下放松和享受户外空间。
该项目从67个国家的1,570多名参赛者中脱颖而出,旨在通过本地化的城市热岛效应解决方案来应对气候变化的影响。
Oasys系统是一个由网格化车站和枢纽组成的网络,作为港湾和避难所的岛屿。"随着划拨的土地成为我们网络的第一个地点,它将作为一个中心点,可以作为休息、活动、以及作为集体和社区的社交场所。
空间可用于临时性的弹出式建筑、休憩区、咖啡馆、展览、运动等。" The Oasys系统的未来是围绕城市建立多个网络,打造休息中心。
The Oasys system is a network of gridded stations and hubs that act as islands of harbor and refuge. "With the allocated land to be the first location of our network, it will act as a central point which can be used as a resting place, for activities, and for socializing as a collective and community. Space can be used for temporary pop-ups, sitting areas, cafes, exhibitions, sports etc." The future of The Oasys system is to build multiple networks around cities to create hubs of rest.
该团队解释说,随着阿布扎比计划的发展,室外热舒适系统将成为解决气候危机的危险的公共和私人空间的重要。
Oasys由类似棕榈树的结构模块构成,这将是该系统的主要功能。它还将通过棕榈树下的喷嘴喷洒雾气,并通过棕榈树屋顶的太阳能电池板收集太阳能。
The team explains that as Abu Dhabi plans to grow, outdoor thermal comfort systems will become important to public and private spaces to address the dangers of the climate crisis. The Oasys is constructed from modules of palm tree-like structures that will be the main function of the system. It will also spray mist through nozzles that underlay the palms, as well as collect solar energy through solar panels on the roof of the palms.
所有的模块系统都可以相互连接,每个模块可以不同的规模和可调。它可以是临时的,也可以是永久的,这取决于空间的使用,而基础将容纳储存水和任何操作设备。
The modular systems all able to connect with each other, and each module can be different scales and adjustable. It can be temporary or permanent depending on the use of the space, while the foundation will house the storage of water and any operating equipment.
气流分析图
平面图
细部图
细部图
建筑师:马斯克建筑与设计事务所(Mask Architects)
地点:阿拉伯联合酋长国
建筑方案设计
返回版块21.19 万条内容 · 304 人订阅
广州8大精品楼盘:叠拼 洋房 大平层 超高层....收录于话题 北上广深位居国内一线城市 而广州,人口的增长及经济的迅速发展 使人们对居住生活环境要求越来越 高 由此诞生了众多高品质的精品楼盘 本次搜建筑精心挑选了 广州八个精品特色项目 与大家一同前往观摩学习 龙湖 · 揽境
