土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 庄严简约博物馆设计
庄严简约博物馆设计
发布于:2020-10-19 11:27:19 来自:建筑设计/公共建筑设计 [复制转发]
巨大的田野被一个小的单层村庄所包围,被选为新的Zoya展览综合体的场地。考虑到这个地方因伟大的卫国战争的历史而令人难忘,微型建筑与巨大的开放空间相邻,我们围绕着跨尺度的概念进行设计。
木屋的形状和布局通过不同的体量来诠释,以适应博物馆的建筑。
А huge field surrounded by a small single-story village was chosen as a site for the new Zoya exhibition complex. Keeping in mind the context of the place memorable for the history of the Great Patriotic War, miniature buildings neighboring enormous open space we built out concept around the idea of interscale. The shapes and layout of wooden houses were interpreted through different volumes fit into the museum architecture.
该两层建筑总面积为2500平方米,包括展示区、咖啡厅、礼品店和所有相关设施。每个展厅都是一个独立的体量,有自己的展示功能,可以俯瞰外面的标志性地点——这就是历史景观如何融入展览叙事的。
所有的体量都由柱廊围成流线型,增加了博物馆形象的严密性,扩大了屋顶步行区,并将建筑与周围区域统一起来。
The two-story building with a total area of 2 500 square meters includes an exhibition area, café, gift shop, and all the associated amenities. Each hall is an independent volume having its own expositional function with viewpoints overlooking iconic locations outside – this is how the historic landscape gets involved in the exhibition narrative. All the volumes are streamlined by a colonnade perimeter-wise adding strictness to the museum image, enlarging roofed walking areas, and uniting the building with the surrounding area.
建筑正面的原始几何形状由纹理混凝土板制成,增强了光线效果,并诠释了周围村庄房屋的形状。
简约的自然材料内饰使展览内容脱颖而出,带有地板到天花板玻璃的咖啡馆和厨房围绕中心元素组织,类似俄罗斯的火炉。
The original geometry of the building front made of textured concrete panels sharpens light effects and interprets the shapes of the surrounding village houses. Minimalistic interiors made of natural materials make the exposition content stand out, the café with floor-to-ceiling glazing and kitchen are organized around the central element resembling a Russian stove.
主建筑周围的景观空间被一条直径50米的圆形步行路线环绕,它穿过主要的纪念碑——Zoya Kosmodemyanskaya雕像,一座老博物馆,Kulik house,刑场。
该综合体是一种原始的表达,一种新的伟大的卫国战争记忆。
The landscape space around the main building is encircled by a round walking route 50 meters in diameter, it lies through the main monuments – Zoya Kosmodemyanskaya statue, an old museum, Kulik house, execution place. The complex is an original expression, a new shape of the Great Patriotic War memory.
区位图
平面图
立面图
轴测图
建筑师:Architectural buro A2M
地点:俄罗斯
面积:2500 m2
年份:2020
公共建筑设计
51.18 万条内容 · 448 人订阅
立体停车楼设计,斜板结构,利用率提高30%,增加25%的停车位……
GWP新作 “无限流动”— 东莞CBD示范性立体停车楼
