土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 住宅立面公建化
住宅立面公建化
发布于:2020-10-13 11:06:13 来自:建筑设计/公共建筑设计 [复制转发]
该项目的主题是为一个家庭的父母设计一个面积约为300平方米的住宅单元,为儿童设计四个面积为150平方米的单元,并在剩余的510平方米的土地上建造销售住房。
 The subject of the project was the designing of a residential unit of approximately 300 square meters area for the parents of a family, and four units of 150 square meters area for children and a possible surplus in the construction license on a 510 square meter land for sale.
项目视频
两层楼板之间的适当分隔以及在不损坏单层楼板的情况下重建电梯的公共空间被认为是主要的设计挑战。
因此,该项目的框架被认为是六十年代和六十年代德黑兰流行现代主义住宅公寓的普遍模式,在马什哈德被称为“ Khorjini”设计。
Proper separation of two-unit floors from each other and the rebuilding of a common front space of elevator without damaging single-unit floors were considered as the main design challenges. Therefore, the prevalent pattern of residential apartments of endemic modernism of Tehran in the fifties and sixties, which is known as the “Khorjini” design in Mashhad, was considered as the framework of the project.
后来,为了缩小单层的层高差,增减层高,在建筑中间形成了一个八十平方米的复式单元,有多余的可售空间,弥补了院景中间空地的减少和电梯前公共空间的增加。
Later, in order to reduce this level difference in single-story floors, increasing and decreasing the height of the floors led to the creation of a duplex unit of eighty square meters in the middle of the building with of surplus marketable space which compensated for the reduction of the middle void area in the yard view and the increase of the common front space of the elevator.
之后尝试运用当前现代公寓格局中的其他方式,如在楼层中设计半开放空间,在外立面中设计正负空间,在建筑规划中设计私密空间和公共空间的分离,来重新构造上述这种格局。
Afterwards an attempt was made to recreate this above mentioned pattern by applying the other parameters of the current modern apartment pattern such as designing semi-open space in floors, positive and negative spaces in facades, and separation of private and public spaces in architecture plans.
平面图
剖面图
轴测图
细部图
建筑师:Pi architects
地点:伊朗
面积:2650 m2
年份:2020
公共建筑设计
51.18 万条内容 · 448 人订阅
条形码立面——特色“立方体状”办公建筑
数字化的建筑思想:随着La Tete的出现,一个面向未来的媒体中心被创造出来。德国商报媒体集团入住了这个媒体中心。 带有集成大屏幕的条形码立面不仅代表了媒体世界的数字化,它还将La Tete变成了一个活跃的社交媒体渠道,并向公德国· 媒体之家--- caspar众开放了住宅。路过的人可以在建筑的外面看到商贸部在里面生产的东西。 Architecture thought digital: With La Tête, a future-oriented media house was created, and the Handelsblatt Media Group moved in. The barcode fa?ade with an integrated mega screen does not only represent the digitalization of the media world, it transforms La Tête into a living social media channel and opens up the house for the public. People passing by can see on the outside of the building what the Handelsblatt produces inside.
