土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ OMA作品:开放式、新型办公楼
OMA作品:开放式、新型办公楼
发布于:2020-10-12 09:26:12 来自:建筑设计/公共建筑设计 [复制转发]
建筑位于齐默尔大街上现有阿克塞尔施普林格总部的对面,齐默尔大街以前是分隔东西柏林的街道,是柏林最重要的位置之一。
Axel施普林格已经开始从印刷媒体转向数字媒体。 它在柏林广场的新建筑既是这一转变的象征,也是一种工具——一座吸引(德国)数字波西米亚精英的建筑。
设计的精髓是一系列露台层,它们一起形成了一个“山谷”,在中心创造了一个非正式的舞台——一个向公司其他部分传播想法的地方。
The building is situated opposite the existing Axel Springer headquarters on Zimmerstrasse, a street which previously separated East and West Berlin, at one of the city’s most significant locations.
Axel Springer has launched a move from print to digital media. Its new building on the campus in Berlin acts both as a symbol and a tool in this transition - a building to lure the elite of (Germany’s) digital Bohemia. Bisected by a diagonal atrium that opens up to the existing Axel Springer buildings, the essence of the design is a series of terraced floors that together form a ‘valley’ that creates an informal stage at the centre - a place to broadcast ideas to other parts of the company.
印刷术的天才之处在于,它是一种廉价的、实体的、超容易获得的复杂集体努力的体现,而到目前为止,数字媒体一直无法找到类似的东西。
建筑办公室类似于报纸,他们从完全不同的信息来源产生复杂的组合和选择。
The genius of print is that it is a cheap, physical, hyper-accessible embodiment of a complex collective effort, for which so far the digital has been unable to find an equivalent. Architectural offices are similar to newspapers in that they produce complex assemblies and selections from radically different sources of information.
作为建筑师,我们体会到了速度、精度、平滑的优势。但我们也遭受了一个至关重要的后果:员工和他的电脑之间的关系,将他孤立在一个内向表现的‘气泡’中,无法进行集体沟通。
As architects, we have experienced the advantages: speed, precision, smoothness. But we have also suffered one crucial consequence: the relationship between the worker and his computer, which isolates him in a bubble of introverted performance, inaccessible to collective overview.
在传统的新闻编辑室里,抽烟打字的记者占了主导地位,每个居民都知道他的同事的劳动和进步,以及共同的目标:单一的问题,与最后期限同时发布。
在数字办公室里,专注地盯着屏幕会削弱所有其他形式的注意力,从而削弱真正创新所必需的集体智慧。
In the classical newsroom, dominated by smoking, typing journalists, each inhabitant was aware of the labour and progress of his colleagues and of the collective aim: a single issue, with the deadline as a simultaneous release. In the digital office, staring intently at a screen dampens all other forms of attention and therefore undermines the collective intelligence necessary for true innovation.
因此,我们设计了一座大楼,可以大量地广播个人的工作以供共享分析。
新的办公大楼注入了一个中央中庭,向阿克塞尔施普林格建筑开放,这是阿克塞尔施普林格校区的新中心。
We therefore have designed a building that lavishly broadcasts the work of individuals for shared analysis. The new office block is injected with a central atrium that opens up to the existing Axel Springer buildings - a new centre of the Axel Springer campus.
该设计围绕一系列露台楼层展开,它们共同形成了一个数字山谷。每层包含一个覆盖部分作为一个传统的工作环境,然后发现在露台上。
在建筑的中间,山谷被镜像,形成了一个三维的天棚。
The design was developed around a series of terraced floors that together form a digital valley. Each floor contains a covered part as a traditional work environment, which is then uncovered on the terraces. Halfway through the building, the valley is mirrored to generate a three-dimensional canopy.
通过相互连接的露台形成的公共空间,在建筑的实体部分提供了正式办公空间的另一种选择,允许前所未有的扩展工作空间的词汇:一个可以吸收所有数字未来的问号的建筑。
The common space formed by the interconnected terraces offers an alternative to the formal office space in the solid part of the building, allowing for an unprecedented expansion of the vocabulary of workspaces: a building that can absorb all the question marks of the digital future.
公众可以在三层体验建筑——一楼大堂、会议桥和屋顶酒吧。会议桥是一个观景台,游客可以从这里看到公司的日常运作以及它是如何发展的。
一层包含工作室、活动和展览空间、食堂和餐厅。
The public can experience the building on three levels - ground floor lobby, meeting bridge, and roof-top bar. The meeting bridge is a viewing platform from which the visitors can witness the daily functioning of the company and how it evolves. The ground floor contains studios, event and exhibition spaces, canteens and restaurants.
设计草图
设计模型
平面图
建筑师:OMA
地点:德国,柏林
面积:57828 m2
年份:2019
公共建筑设计
51.18 万条内容 · 448 人订阅
从一粒种子开始,构建生生不息的完整IP——阿飞森林主题乐园
故事的起端是: 一粒种子醒于幻夜, 破土而出。 If a seed Awoke From the Illusion 而我们即将踏上 AFI(种子)的生长循环旅程…… 萌芽、生长、开花、传播、凋敝 生生不息……
