土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 漂亮!!住宅更新——创造了一种精致的图案,使外立面充满活力
发布于:2020-09-17 10:17:17 来自:建筑设计/居住建筑设计 [复制转发]
新建筑参与了boulevard Ney和Porte de Clignancourt的城市更新,它被分成两个体量,底部由托儿所占据的共享平台连接。在这里,这个70年代就已存在的地块被密集化,使建筑部分与林荫道保持一致,使之成为一个更紧凑、更有活力的地方。
Participating in the urban renewal of the boulevard Ney and the Porte de Clignancourt, this new building is split into two volumes linked at the bottom by a shared platform occupied by the nursery. Here, this densification of a lot already in existence since the 70s aligns the built part with the boulevard, rendering it a tighter and livelier place.
尊重现有塔楼的现代主义建筑,6层和9层高的两座塔楼的位置彼此相对,以及错落有致地拼接在一起,为现有塔楼和新公寓创造了景观,并增加了幼儿园庭院的日照。滑动的效果使楼层被处理成层状,使体量逐渐缩小。
Respectful of the modernist architecture of the existing towers, the positioning of the two beacons of 6 and 9 stories facing each other, and their splicing in staggered setbacks, create views for the existing towers as well as the new apartments and increases sunshine on the nursery’s courtyard. The sliding effects result in the floors being treated as strata tapering the volumes.
建筑的圆角由混合材料组成,增强了光线和透明度,与现有塔楼的直角形成对比。
一系列的几何砖组合创造了一种精致的图案,使外立面充满活力,而它们的角落、露台和凉廊的护栏则是由通风的砖块镂空组合而成。
砖与社会住房的历史对话,同时由于其白色和外墙的轮廓而展现出现代风格的一种新高度。
The rounded corners of the building, composed of a blend of materials enhancing light and transparency, are in contrast with the right angles of the existing towers. Series of geometric brick assemblages create a delicate pattern enlivening the facades while their corners and the guardrails of the terraces and loggias are made of an airy assemblage of brick openwork. The brick is in a dialog with the history of the social housing, while also exhibiting a highly contemporary style, owing to its white color and the outlines of the facade.
场地平面图
平面图
细部图
建筑师:ITAR Architectures
地点:法国 巴黎
面积:5200平方米
专家点评
  • lijiawei411
    2020年09月23日 11:05:29 来自 PC 回复 举报
居住建筑设计
28.74 万条内容 · 423 人订阅
天正如何调出左边的工具栏
电脑是32位的装的是天正20  V2.0    cad2014    cad2019   打开天正后工具栏一直不显示, 用CTRL 不行     tmnload命令也不行   就显示未知命令    也加载不了   不知道怎么解决,求教。
