土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 创意住宅设计“第三空间”——李兴钢建筑工作室
发布于:2020-09-16 14:55:16 来自:建筑设计/居住建筑设计 [复制转发]
东侧鸟瞰-张广源
“第三空间”位于唐山繁荣的建设北路,东侧紧邻南北向平行建设的工人住宅。
塔楼和裙房的朝向、布局、体量和形状几乎都是由日照计算得出的,以满足严格的日照法规要求。
两栋平行的100米高的板状建筑沿着西南阳光的入射方向旋转一个角度,然后面向东南,裙房的屋顶被切割成锯齿形状,在东侧留出了一个带状花园。
“The Third Space” is located in the prosperous North Jianshe Road, of which the east side is next to north-south parallel rows of workers’ house. The direction, layout, the volume and the shape of tower and podium are nearly all determined by the calculation of sunlight in order to fulfill the rigorous sunlight standard. Two parallel 100 meters high slab-type building are rotated by a certain degree along the direction of the incoming southwest sunlight and then face southeast with the roof of the podium cut into a zigzag shape leaving a ribbon shape garden in the east side.
从第三空间顶层俯瞰建设北路西侧住宅区-李兴钢
西南街景-张广源
西北街景-李兴钢
“第三空间”综合体试图传达一种延伸至高空的立体城市聚落的形象,在城市中有76栋垂直堆叠的别墅。“标准层”中惯常平直的楼板以错层结构的方式层层堆叠,从而形成每个单元中连续抬升的地面标高,犹如几何化的人工台地,容纳从公共到私密的使用功能,使人仿佛在山地上攀爬穿行,在不断的空间转换中形成静谧的氛围。
“The Third Space” complex tries to convey a kind of image of a three dimensional city settlement extends to the sky with 76 vertical stacked villas in the city. The floor slabs in usually flat in “Standard floor” in this project are stacked with staggered structural arrangement and thus form continuous increase of height level in each unit like geometric artificial terraces containing the transition of functions from the public to the private with the inhabitants climb and cross in the terraces, feeling the quiet atmosphere forming in the continuous spatial transitions.
从道路西侧望向北楼-李兴钢
从南楼望向北楼南立面-张广源
收藏和媒体空间在斜坡上形成房屋的形态。不同大小、形态和朝向的亭台小屋都被转移到立面上,以收纳城市景观,并作为向城市开放的活跃的生活平台,从而成为密集分布的垂直“城市聚落”的象征。在屋顶,真正翠绿的庭院被引入顶层单元,因此创造了一种不同于通常别墅的高度感。
Collection and media space are formed into the shape of houses on the slope. Pavilion houses with different size, shapes and direction are all transferred to the elevation in order to take in the city views and serve as several lively platforms of life open to the city thus becoming a symbol of dense vertical arranged “city settlement”. The real verdant courtyard is introduced into the top units with the help of the roof and thus creates a different feeling of height than that in the common villa.
从北楼悬挑亭台望向南楼-张广源
从悬挑亭台望出东侧住宅区-张广源
所有的复式公寓单元都是垂直堆叠的,不同尺度和方向的室外亭台悬挑在对应的立面上,收纳下方和远处的城市与自然景观,自身也成为城市中的新景观。
All the duplex apartment units are stacked vertically with outdoor pavilions of different sizes and directions cantilevered in the corresponding elevation, taking in the city and nature view below and far away and becoming a new landscape in the city.
立面局部(夜景)-孙鹏
立面局部(夜景)-张广源
从入口空间看起居室(样板间室内设计:印西诃EXH)-李兴钢
从楼梯看餐厅(样板间室内设计:印西诃EXH)-李兴钢
施工中的混凝土框架结构和悬挑亭台密肋板
施工中的悬挑亭台
区位图--卫星航拍
总平面图
南楼七层平面图
南楼八层平面图
北楼七层平面图
北楼八层平面图
南立面局部放大图(复式单元错层错位分布)
北立面局部放大图(复式单元错层错位分布)
剖面图
基于日照计算分析的前期设计草图
草图--屏幕快照
整体模型
复式单元叠加模型
大比例实物模型
大比例模型复式单元内部
建筑师:李兴钢建筑工作室
地点:唐山
面积:88011平方米
年份:2015
摄影师:张广源, 李兴钢,孙鹏
厂家:南京倍立达, 深圳罡正实业
  • lijiawei411
    lijiawei411 沙发
    2020-09-17 09:00:17
居住建筑设计
28.74 万条内容 · 423 人订阅
【作品】银湖蓝山 | 强调空间感与光感的现代家居
1919年 一位叫格罗皮乌斯的大叔 成立了一个叫包豪斯的学校 专门研究建筑设计 和工业日用品设计 老格带领的包豪斯学校对建筑和室内装潢 奉行这样的设计理念: 把设计的教育重心 转移到“解决问题”上去 摆脱“玩形式”的弊病走向真正 方便、实用、经济、美观的设计体系 这样的理念为现代设计奠定了坚实的发展基础 毫无疑问,本次案例采用的设计风格 就是如今的家居中最受欢迎的「现代风格」
