土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ “独特”的顶层设计,创造了“连绵起伏”的屋顶效果
发布于:2020-09-10 14:22:10 来自:建筑设计/居住建筑设计 [复制转发]
这座两层楼的建筑融合了两种截然不同的建筑理念。底层被设计成一个简单的盒子空间,包含了客厅、厨房、门厅和车库。它作为上面的基座。
This  two-story building is a stack of two distinctive expressions of architectural ideas. The ground floor is articulated as a simple box volume that holds the living room, kitchen, foyer and garage. It acts as the pedestal for the above.
顶层有其独特的主题。一系列扭曲的表面表现在墙壁和天花板上,重复并创造出一个有节奏的序列。
The top floor has its own distinctive theme. A series of twisted surfaces express themselves as walls and ceilings, repeat and create a rhythmic sequence.
网格外壳一直是我们的目标,因为网格外壳可以使屋顶更加有趣。在 "alpha house "的案例中,墙体成为屋顶,并创造出一个轮廓,由一个标志性的、有节奏的图案组成,坚持--以巴厘岛连绵起伏的山景为背景,完成了一个与环境融为一体的雕塑物体的画面。
Grid shells have always done it for us, as they suggest interesting and new ways to define roofs. In the case of the ‘alpha house’, walls become the roofs and create a silhouette, consisting of an iconic and rhythmic pattern that sticks - completing the picture of a sculptural object blending into its  environment- with the rolling mountain scape of Bali as it’s background.
一座水池与建筑方向平行,在水面上体现出它的波浪形特征。布局简单、实用、重复。同时在建筑功能上提供了隔离周围环境的效果。
A pool runs parallel to the building direction and reflects it’s wavy character in the water plane. The layout is simple, practical, and repetitive. The building’s east-west orientation provides self shading and shields off neighbors.
所用的材料是用'kerobokan石'的墙,这是一种在现场附近发现的当地硬砂岩,并且在巴厘岛建设时普遍使用的传统材料。
Materials used are walls with ‘kerobokan stone, a local hard sandstone found in the vicinity of the site, and represents a traditional material that people use for their constructions in Bali.
我们的目标是表达和唤起一个独特的意义或主题。在这种情况下,流畅性代表了前进的方向,同时表达了对创造的喜悦。
We aimed to express and evoke a distinctive meaning or topic. In this case fluidity stands for the way forward, expressing the joy for and of creation.
建筑师:Alexis Dornier
地点:印尼
面积:280平方米
年份:2020
摄影:KIE
  • jzd蒋
    jzd蒋 沙发
    真的是富豪级别的建筑,一般人还找不到能设计出这样造型的设计师,政府做来作展厅之类的还是可以的
    2020-09-14 11:12:14
居住建筑设计
28.74 万条内容 · 423 人订阅
自建房设计图纸
我想问一下谁有二层半自建房设计图纸
