土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 简洁、精美的——开放式新总部办公建筑
简洁、精美的——开放式新总部办公建筑
发布于:2020-09-08 10:22:08 来自:建筑设计/公共建筑设计 [复制转发]
Genmab生物科技公司的新址近日在乌得勒支的科学园开幕。Genmab的新总部在哥本哈根和普林斯顿-新泽西州设有分支机构,建筑与室内设计由Cepezed和Cepezedinterior完成。
新建筑的设计基于开放的工作文化和与外界的密切互动。新建筑具有很高的可持续性,充足的采光,为员工和访客提供了一个舒适,健康和鼓舞人心的(工作)环境。
Recently the opening of the new premises of biotech company Genmab took place at the Science Park Utrecht. The new head office of Genmab, which has branches in Copenhagen and Princeton - New Jersey, is an integral design of cepezed and cepezed interior. The new building has been designed on the basis of an open work culture and intensive interaction, also with external parties. With a high sustainability score and ample daylighting, the new building offers a comfortable, healthy and inspiring (work) environment for employees and visitors.
Genmab是欧洲较大的独立生物科技公司,专注于新的癌症疗法的开发。公司在几年里的快速发展,因此需要新的办公场所。
此外,新建筑还希望能使企业更具知名度,增加员工之间的互动,并与外部合作伙伴更有效地协作。
该建筑旨在成为吸引顶尖研究人员的一张名片。cepezed和cepezedinterior负责设计。
Genmab is a internationally operating biotech company that develops therapeutic antibodies for the treatment of cancer. Over the last years, the company has grown substantially, leading to the need for new premises. Its Scandinavian origins called for a special focus on design. In addition, the new-build has been seized as an opportunity to give the firm more visibility, to increase interaction between the employees and to collaborate more effectively with external partners. The building was also intended to become a calling card to attract top researchers. cepezed and cepezedinterior were responsible for the design.
全新的Genmab大楼是一栋引人注目的,简洁且精美的建筑,位于乌得勒支科学园的主干道。
该项目包括办公室,实验室和一系列配套功能,如会议中心,礼堂,咖啡厅和餐厅。
该建筑为开放式结构,跨度大且视野广。
在底层上,它由两个五层高,交错的跨间组成,同时中间间隔着一个中庭;地下层是一个停车场。
The new Genmab is a striking, cleanly styled and detailed building located directly on the main access road of the Utrecht Science Park. The program comprises offices, laboratories and an extensive range of supporting functions such as a meeting center, auditorium, science café and restaurant. The building has an open structure with large spans and long sight lines. Above ground, it consists of two five-storey bays positioned out of alignment with each other, and an atrium in between. Underground there is a parking garage that takes up the entire footprint.
建筑尽可能紧凑。两个跨间直线排成,有助于与选址很好地契合。设施项目包括会议中心、礼堂和咖啡厅,以及健身房、自行车停车库、储藏区与废物室,主要位于首层。中庭的楼板位于首层,具有广场的特征。
周围还有其他辅助功能,例如咖啡吧和带烹饪功能的开放式厨房。在办公区,会议地点沿中庭布置,而固定工作区则沿立面布置。上面的三层容纳办公室和实验室,可以灵活布置:办公室可以变成实验室,反之亦然。
The building is as compact as possible. The alignment of the two bays contributes to a good fit with the location. The facilities program with the meeting center, auditorium and cafe, but also a gym, bicycle parking, storage areas and waste rooms, has been mainly housed on the ground floor. The floor slab of the atrium is situated on the first floor and has the character of a plaza. Surrounding this are other supporting functions such as a coffee bar and an open kitchen with front cooking. In the office bay, the meeting spots are situated along the atrium while the fixed workspaces are mainly located along the facades. The upper three storeys accommodate both offices and laboratories. Their gross height is higher, so that the program here can be flexible: offices can become labs and vice ve rsa .
跨间立面是垂直铰接的,此处玻璃构件的框架隐藏在封闭元素的铝制外部饰面后面。中庭具有完全通透的立面,因此从外部可以看到宽敞的开放空间。
中庭的特殊元素是直径超过8米的岛屿,呈阶梯状放置,仿佛在空间中自由漂浮,它包含会议,讨论和灵活工作的场所。其中一间用作董事会会议室,配有热弯玻璃幕墙,带公司logo的大桌子以及包含所有气候设施的定制家具和最现代化的展示设备。
The bay facades are vertically articulated, and here the frames of the glass components are concealed behind the aluminium external finish of the closed elements. The atrium has completely transparent facades, so that the large open space is prominently in view from the outside and makes a significant contribution to how the building appears to the surroundings. Special elements in the atrium are the large islands, more than eight metres in diameter, which are positioned stepwise and seem to float freely in the space. On the islands there are spots for meeting, discussion and flexible working. One of them functions as a board room and is equipped with hot bent glass walls, a large table with illuminated company logo and a custom-made piece of furniture containing all the climate facilities and the most modern presentation equipment.
内饰明亮,整洁,时尚,并采用了大量木材和其他天然材料;走廊在光学上被拓宽,允许延伸到通透的办公空间;在可持续性方面,全新的Genmab总部获得了BREEAM“杰出”证书。
The interior is light, uncluttered and stylish, with a great deal of wood and other natural materials used. Corridors are optically widened by allowing their floor finish to continue into the transparent office spaces. In terms of sustainability, the new Genmab has the BREEAM Excellent certificate.
平面图
剖面图
建筑师:cepezed建筑事务所
地点:荷兰
面积:11178平方米
  • lijiawei411
    lijiawei411 沙发
    2020-09-10 16:17:10
公共建筑设计
51.18 万条内容 · 448 人订阅
几何美学——纯净表皮的立面科技馆,最大化展示形态美。
飞向太空 | 株洲蔷薇熙岸科技体验馆 01  项目概述 DESCRIPTION OF PROJECT 这座标志性的建筑位于湖南省株洲市天元区,南面可远眺万丰湖湿地公园。建筑形态呈现出两块几何变形的空间序列,并于内部空间和外部景观间建立一个精心编排的体验序列。
