土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 一栋充满活力、多层次的文化中心
一栋充满活力、多层次的文化中心
发布于:2020-08-11 09:02:11 来自:建筑设计/公共建筑设计 [复制转发]
Arter是一个充满活力的文化中心,也是土耳其慈善机构VehbiKoc基金会的附属公司,它汇集了艺术家和观众,以各种形式和标准来共赏当代艺术。
此外,Arter还是一栋充满活力的多层次,跨领域公共建筑,用于展示艺术作品,同时提供了一系列丰富的文化项目来激发和挑战观众。
 A subsidiary of Turkey’s philanthropic Vehbi Koc Foundation, Arter is a vibrant cultural hub that brings together artists and audiences to celebrate contemporary art in all its forms and disciplines. Conceived as a dynamic multi-layered, interdisciplinary public building for showcasing artistic works, it offers a rich cultural programme to stimulate and challenge its audience.
Grimshaw赢得了2012年的设计竞赛,随后,与伊斯坦布尔Turgut Alton建筑事务所,当地顾问、专家和承包商组成了一支多学科团队,来共同解决设计和建造过程中的规模选择、复杂性和启发性等问题。
Grimshaw won the design competition in 2012, following which it led a multi-disciplinary team to address the scale, complexity and aspiration of the design and build process, including Istanbul’s Turgut Alton Architects and other local consultants, specialists and contractors.
为明确表达VehbiKoc的社会责任感,该设计围绕公共空间而设计,旨在打造一个可达的,吸引人的博物馆,灵感源于透明性和流动性的概念,激发灵感和适应性的公共空间是其设计核心,精心布置的大画窗用作建筑向街道开放的方式,并将展厅与城市连接起来。这种连通性在伊斯坦布尔,博物馆及其艺术之间提供了连续的联系,同时仍然满足了展厅空间的功能需求,从而保护了大型内部展厅免受自然光的照射。
Articulating Vehbi Koc’s vision for social responsibility, the design hinges around spaces designed to promote access for everyone, both within and around the museum. Derived from concepts of transparency and fluidity, inspiring and adaptive public spaces are at its heart, with carefully positioned large picture windows used as a way of opening the building to the street and connecting the gallery to the city. This connectivity provides continuous links between Istanbul, the museum and its art, while still fulfilling the functional requirements of gallery spaces in protecting the large internal gallery volumes from natural light.
三层高的入口展厅穿过博物馆中心形成了一条在视觉和物理上的公共通道,将多拉普雷德街与公园连接,使建筑有效地朝各面展开,欢迎所有人的到来。这条内部街道可以协调整个场地的陡峭高度变化,是建筑的主要组织元素。
A triple height entrance gallery forges a visual and physical public route through the centre of the museum, connecting Dolapdere street with the park to the rear, making the building effectively face both ways, accessible and welcoming to all. This internal street negotiates the steep level change across the site and is the main organising element of the building.
地下层设有两个表演厅,可容纳电影和表演艺术节目,以及会议。
SevgiGonul礼堂的伸缩式座椅系统可容纳168人,而“黑匣子” Karbon剧院有可容纳332人的灵活座椅结构,以及最先进的照明,音响和技术设备。
图书馆为访客提供了进一步研究学习的机会,而零售和餐饮设施则为人们提供了休憩和放松的场所。
Below ground two performance halls occupy the lower levels accommodating programmes of film and performing arts, as well as conferences and panel discussions. The Sevgi Gonul Auditorium’s telescopic seating system gives a capacity of 168, while the ‘blackbox’ Karbon theatre has a flexible seating structure for up to 332, as well as state-of-the-art lighting, sound and technical capabilities. A library offers visitors the opportunity for further research, while retail and catering facilities provide relief and relaxation.
该建筑的展厅规模和体量各不相同,双层高、交错的空间为其多样化的艺术项目提供了多种灵活的配置和功能。
展区之间的视野和连通性提供了自然的寻路和定位。
学习区俯瞰着每个主展厅,使探索和解说项目与展览保持联系。这些空间横跨双层高的展厅,直延伸至建筑的外缘,并定义了对外立面具有点缀效果的画窗。
The building’s galleries range in scale and volume, with interlocking double height spaces offering a multitude of flexible configurations and capacities for its diverse artistic programmes. Views and connectivity between exhibition areas provide natural wayfinding and orientation. Learning spaces overlook each of the main galleries, allowing discovery and interpretation programmes to remain connected to the exhibitions. These spaces straddle the double-height galleries to reach the outer edge of the building and define the punctuated picture windows that give expression to the facade.
容纳展厅的主体量是通过立面微妙的倒角在外部进行衔接,从而为典型展厅建筑的空白立面增加了可塑性。
3D凹凸的菱形面板创造了一个极具戏剧性、诱人的表皮肌理,并全天候地反射着阳光。
丰富的光影变化以一种激动人心的动态方式为建筑注入活力,也为伊斯坦布尔的历史马赛克立面提供了一种引人入胜的当代诠释。
The main volume of the building that houses the exhibition galleries is articulated externally through subtle chamfering of the facade, adding plasticity to the blank facades typical of gallery building typology. 3D convex and concave rhomboid-shaped panels create a dramatic and inviting envelope and reflect the sun as it moves across the museum throughout the day. The rich palette of changing light and shadow animates the building in an exciting and dynamic way, providing an engaging and contemporary reinterpretation of Istanbul’s historic mosaic facade.
平面图
剖面图
建筑师:Grimshaw建筑事务所
地点:土耳其
面积:17050平方米
  • lijiawei411
    lijiawei411 沙发
    2020-08-17 08:50:17
公共建筑设计
51.18 万条内容 · 448 人订阅
如何美化环境
   在知识经济的发展趋势已经被广泛认同的今天,大学校园作为知识经济的重要载体和中心力量,其成长发展的成功与否,直接关系到整个国民素质的提高、关系到国家未来的兴衰和经济的繁荣。因此大学校园建设成为我国当前社会经济发展中的一件大事。本论文是从新世纪新经济条件下大学校园环境建设的重要性浅议我们为什么要进行校园环境景观的研究和建设,以期对我国大学校园建设的具体实践有一定的参考价值。
