土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ “贝壳状”的住宅建筑设计
“贝壳状”的住宅建筑设计
发布于:2020-08-07 09:22:07 来自:建筑设计/居住建筑设计 [复制转发]
314 architecture studio公布了位于希腊雅典南部郊区的“ h1003”或“ yadori kai”住宅方案。
该公寓大楼项目采用贝壳状的有机形式,轻质的结构和反光表面,将水生元素与简约设计融为一体。
situated within the southern suburbs of athens, greece, 314 architecture studio has unveiled the ‘h1003’ or ‘yadori kai’ residential proposal. the apartment complex project integrates aquatic elements with minimal design, using seashell-like organic forms, lightweight construction and reflective surfaces.
314 Architecture Studio项目的设计理念是创建三个独立的体量,将其外观和功能作为一个元素。
薄而弯曲状的楼板连接体量,在每个层上以不同的方式旋转,以完成有趣生动的形象。此外,在整体设计中现简约感和优雅感。
the main idea behind 314 architecture studio‘s project is to create three separate volumes that look and function as one element. thin, curved slabs connect the volumes, which are rotated differently on each level, in order to complete the interesting form. in addition, simplicity and elegance are evident in the overall design approach.
建筑师选择了没有更多“装饰”元素的有趣立面。在这里,形式遵循功能,形象不言而喻。该方案还基于“玻璃屋”的概念:整个建筑都保持透明通透,体量轻盈。
the architects opted for interesting facades without further ‘decorative’ elements. here, form follows function and the form speaks for itself. the proposal is also based on the idea of a ‘glass house’: transparency is maintained throughout the building and volumes appear to be lightweight.
有机中庭允许新鲜空气和自然采光穿透建筑。水景在设计过程中起着至关重要的作用,水池和池塘无缝地集成在每一层中。
水,镜子反射光线和建筑的造型,而镜子也用于“开放”和释放空间。反射,形式和环境都作为一个更大综合体的一部分。
a number of organic atria in critical locations allow fresh air and natural lighting to penetrate the building. water plays a vital role in the design process, with pools and ponds seamlessly integrated in each floor. the water and mirrors reflect light and the shapes of the building, while the mirrors are also used to ‘open up’ and free space. the reflections, the form and the environment all work as part of one bigger synthesis.
平面图
建筑师:314 architecture studio
地点:希腊
面积:3.134,6 m2
  • davidliu_sha
    davidliu_sha 沙发
    好资料,感谢楼主无私的分享
    2020-08-11 09:44:11
  • lijiawei411
    lijiawei411 板凳
    水景在设计过程中起着至关重要的作用,该公寓大楼项目采用贝壳状的有机形式,轻质的结构和反光表面,将水生元素与简约设计融为一体。
    2020-08-11 08:53:11
居住建筑设计
28.74 万条内容 · 423 人订阅
555号私家公馆
设计究竟是对创造的要求更高,还是对改造的要求更高,目前尚无定论。虽然从零开始打造出大师级作品需要面对一系列挑战,但是在原基础上进行改造也并非简单的工作,毕竟不可忽视依附和脱离之间的矛盾。555号私家公馆属于后者。这个以艾哈迈达巴德(印度)为基地的住宅项目经过重新配置,在保持原设计灵魂的同时被赋予了新的身份。讨论中,建筑师一致认为比起拆除重建,翻修能使干预最小化。
