土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 极简合院产品——立面公建化
极简合院产品——立面公建化
发布于:2020-08-07 09:11:07 来自:建筑设计/公共建筑设计 [复制转发]
潘郎市(Phan Rang)以全年晴朗多风的好天气而闻名。在这种气候条件下,当地人通常会选择封闭式的房屋,这将可以避免户外天气对室内生活功能的影响。内外部总是有区别的。
通过这种安全的方式来创造生活空间,人们的大部分时间都在室内度过,并且仅在午后或傍晚(太阳消失了)外出。
 Phan Rang is famous for its sunny and windy weather through out the year. In that climate condition, local people usually choose to be not against the nature with closed houses which will help them avoid the impact of outdoor weather to the indoor living functions. There always is a discrimination between inside and outside. By this safety way of creating the living spaces, people spend most of their daytime in buildings and go out only in the late afternoon or in the evening – when the sun is gone.
一年中有300个晴朗的好天气,这意味着潘郎人比越南其他任何地区遭受日照的伤害都要长。从而使全年气温都很高。但是这里,天空蔚蓝,阳光明媚,空气清新。
There are 300 sunny days in a year, which means that Phan Rang people have to suffer from sunlight more than any other area in Viet Nam. This leads to the consequence that the temperature is really high during the year. However, the atmosphere is extremely fresh with beautiful blue sky and clean sunny color.
最初人们对生活空间的想象是缓冲区。这个特别的区域被认为是内外之间的过渡空间。它应该比正常的更大,让人们感觉到,走进去,并改变他们的活动。
然而,这个空间界限并不是很清楚。有时属于室外,完全受自然的影响,有时属于室内,这将有助于扩大生活空间。
由于当地不同种类的树木和水面的湿度,流经这个空间的空气会更凉爽。在这个空间里的人们也有更多的机会接触到自然光线和空气。
The initial imagination about living spaces is about the buffer areas. This particularly area is considered as the transition space between inside and outside. It should be larger than normal for people to sense, walk inside and change their activities. However, this space boundary is not really clear. Sometimes it can belong to the outdoor and be totally affected by the nature, sometimes it belongs to the indoor which will help enlarge the living spaces. The air flows through this space will be cooler thanks to different kinds of local trees and humidity from water surface. People in this space also have more chances to connect to the natural light and air.
平面图
屋面
立面图
示意图
模型
建筑师:DA S
地点:越南
面积:220平方米
  • lijiawei411
    lijiawei411 沙发
    内外部总是有区别的。
    2020-08-10 08:36:10
公共建筑设计
51.18 万条内容 · 448 人订阅
简简单单的36例建筑立面
简  / 单  /  之  /  美 学习时间到
