“建筑之力必须适应于自然之力,建筑的目的永远是创造一种能让建筑之力和自然之力在矛盾中共生的环境。”
——安藤忠雄
"The power of architecture must be adapted to the force of nature. The purpose of architecture is always to create an environment where the power of architecture and the force of nature can coexist in contradiction."
——Tadao Ando
△ 校园于城市鸟瞰
△ 建筑隐藏于城市界面
缘起|背景与区位
Origin | Background and Location
随着城市建设从增量向存量转变,城市管理从粗放向精细演化,“城市有机更新”“既有建筑改造”“土地复合使用”“反自然建造的修正”等话题成为讨论的热点。而城市快速发展的道路机动化与住宅高层化,让老校区与新城市之间的关系矛盾重重。玉溪生态实验小学即是在如此背景之下的设计案例。
With the transformation of urban construction from incremental to stock, and the evolution of urban management from extensive to refined, topics such as "urban organic renewal", "reconstruction of existing buildings", "combined use of land", and "modification against natural construction" have become hot topics of discussion. The rapid development of the city’s road motorization and high-rise residential buildings have caused conflicts between the old campus and the new city. Yuxi Ecological Experimental Primary School is a design case in this context.
△ 场地勘探时基地原始状态
△ 地块高差与保留建筑示意图
△ 学校改造前后基地卫星图对比
基地位于玉溪中心区域,校区总面积为23500平方米,地势西低东高,地形极为特殊。初勘现场,爬上长而陡的坡道之后,杂草丛生间一栋老旧的教学楼遗忘在山林前的空地上,斑驳的墙体年复一年经受着日晒雨淋。继续教学楼后的陡坡而上,自地势高处俯瞰,城市风光尽收眼底,建筑师心中笃定了一个信念——改变与重塑,让这片土地重获新生。”
The base is located in the central area of Yuxi. The total area of the campus is 23,500 square meters. The terrain is low in the west and high in the east, and the terrain is extremely special. After first surveying the site, after climbing up the long and steep slope, an old school building amidst weeds was forgotten in the open space in front of the mountain forest. The mottled walls have been exposed to the sun and rain year after year. Continuing on the steep slope behind the teaching building, overlooking the city from a height, the architect has a belief in his heart-change and remodeling, so that this land will be reborn. "
△ 孩子们在屋顶俯瞰
△ 自然生态的校园空间
破题|需求与策略
Break | Demand and Strategy
设计伊始的充分沟通很重要,梳理需求、分析问题、匹配策略。各种问题整合之后,设计再有针对性的做出解答。化解高差既是本案的核心难题也是解题思路,破题之举便是因地制宜,将化解高差和保护生态的两相融合,变不利地形为自然山势共构相融的校园空间特色。
Adequate communication at the beginning of design is very important, sorting out requirements, analyzing problems, and matching strategies. After the integration of various questions, the design will then provide targeted answers. Resolving the height difference is not only the core problem of the case but also the idea of solving the problem. The move to solve the problem is to adapt measures to local conditions, integrating the resolution of height difference and protecting the ecology, and turning the unfavorable terrain into a campus space featuring natural mountains.
△ 教学楼主体建筑解构示意
△ 建筑与山体
设计的目标很明确,改造废弃教学楼、加建新教学建筑,保护生态、植入校方需求、合理布局,变不利地形为合理的校园空间。如何化解高差与融合生态这一项目核心难题。设计最初的空间关注点并不在教学楼的细部功能上,而是新老建筑的融合,教学建筑和山地环境相嵌,构建校园空间的全新叙事体验。
The design goal is very clear, transforming abandoned teaching buildings, adding new teaching buildings, protecting the ecology, planting school needs, reasonable layout, and turning unfavorable terrain into a reasonable campus space. How to resolve the core problem of the project of height difference and ecological integration. The initial spatial focus of the design was not on the detailed functions of the teaching building, but the integration of the old and new buildings. The teaching building and the mountain environment were embedded to construct a new narrative experience of the campus space.
△ 建筑与地势高差
△ 空间的连接与穿梭
共存|建筑与脉络
Coexistence | Architecture and Context
由于沿城市界面的建筑群不能拆改,而改造加建的学校又将以新面貌示人,设计选择以纯白为主基调,采用干净利落的极简主义风格。远远望去,学校仿佛是一座白色城堡退避于沿街建筑,隐藏于自然山林之中。
Since the buildings along the urban interface cannot be demolished, and the rebuilt and added school will show a new look, the final design is based on pure white and adopts a clean minimalist style. From a distance, the school seems to be a white castle retreated from the buildings along the street, hidden in the natural forest.
△ 建筑主体改造前
△ 建筑主体改造后
原有的教学楼建筑结构不做改变,通过在外立面加筑木质铝板格栅做美化,在建筑顶部构架与底部外部加以装饰线条,使其与新加建建筑风格统一。而新建建筑则利用山地丰富的竖向层次,塑造极具想象力的空间场所。新旧建筑间以连廊联接,L型的庭院景观边界与学生的动线自然结合。课后,孩子们的行动空间,更可以扩展到山体区域,每时每刻都可以引发运动与无限可能。
The original structure of the teaching building remains unchanged. It is beautified by adding wooden aluminum grilles to the facade, and decorative lines are added to the top frame and bottom of the building to make it unified with the new building style. The new building uses the rich vertical layers of the mountain to create an imaginative space. The old and new buildings are connected by a corridor, and the L-shaped courtyard landscape boundary is naturally combined with the movement of students. After class, the children's action space can be extended to the mountain area, which can trigger movement and infinite possibilities at all times.
△ 城市界面新老建筑
△ 教学楼建筑立面
△ 课后,孩子们的行动空间扩展到山体区域
△ 建筑与运动场地之间
校园的主入口广场与道路接平,这样广阔宽敞的平台空间使得家长在接送孩子时,有一个聚集广场,也方便人流快速疏散。沿着层次丰富的坡道向上至接待大厅是一段斜角近40度的斜坡。如何在10米多的进深距离化解4米多的高度差?
The main entrance plaza of the campus is level with the road. Such a wide and spacious platform space allows parents to pick up and drop off their children. An extra plaza is also available to facilitate the rapid evacuation of people. Along the richly layered ramp up to the reception hall is a slope with an oblique angle of nearly 40 degrees. How to resolve the height difference of more than 4 meters at a depth of more than 10 meters?
△ 学校改造前后基地卫星图对比
设计从美国旧金山的九曲花街采集灵感,利用弯曲迂回的路线长度换取空间减缓流线的坡度,同时在地面铺装采用透水沥青增加摩擦力。很快,可以看到孩子们沿着蜿蜒的坡道向上奔跑,来到学校接待大厅前的环形停留广场雀跃聚首,而沿路花坛中时令的花草和时不时撞见的特色的小品雕塑学校环境更添生机。
The design draws inspiration from the Jiuquhua Street in San Francisco, USA, and uses the curved and circuitous route length in exchange for space to slow down the slope of the streamline, and at the same time uses permeable asphalt on the ground to increase friction. Soon, you can see the children running up the winding ramp to the circular stop square in front of the school reception hall. The seasonal flowers and plants in the flower beds along the road and the characteristic sketch sculptures that you encounter from time to time add to the school environment. vitality.
△ 人行入口九曲回廊
△ 人行入口九曲回廊
共生|空中操场与林间教室
Symbiosis | Aerial Playground and Forest Classroom
在布局田径场与运动场时,不破坏山体、保护自然环境是首则;不变动土方、尽量控制成本是强规。在这块场地直接放置一个田径场,会将原本局限的空间进一步压缩。
When arranging track and field fields and sports fields, not destroying the mountains and protecting the natural environment is the first priority; not changing the earthwork and trying to control costs is a requirement. Placing an track and field field on this site will further compress the originally limited space.
△ 操场空间改造前
△ 操场空间改造后
设计采用功能堆叠的手法,将操场抬高,食堂与停车场设置在操场下层,将操场空间至于其上,这样对于土地的有效利用,创造出更多的功能性空间。于是,这样一个拥有250米长的环形跑道“空中操场”就形成了,在更接近天空的操场上运动,仿佛伸手就能猜到白云;眺望远方城市,视野开阔舒朗。
The design raised the playground, set up the cafeteria and parking lot on the lower level of the playground, and put the playground space on top, so as to effectively use the land and create more functional space. As a result, such an "air playground" with a 250-meter-long circular runway was formed. You can exercise on the playground closer to the sky, as if you can guess the white clouds by reaching out. Looking at the distant city, you have a wide and comfortable view.
△ 宽阔的操场空间
△ 建筑与山体的围合运动空间
△ 抬高的操场
在操场旁的树林,对于孩子们而言仿佛是另外一个神秘世界的入口,随着台阶拾级而上,每一个有好奇心的孩子都将情不自禁步入这秘密的自然之境。山林自然生态风景是最具感染力的。在最初的设计目标中,便是要将建筑融入环境。设计师把建筑打散,形成若干个建筑单体,并将它们放置在山体的不同高差,隐匿在绿色生态山体之中。经年累月,建筑将和山体形成共生关系:藏身于山石树林,又从山石的绿色中显现出来,若隐若现。
The woods next to the playground seem to be the entrance to another mysterious world for the children. As the steps climb up, every curious child can't help but step into this secret natural realm. The natural ecological scenery of mountain forest is the most infectious. The initial design goal was to integrate the building into the environment. The designer broke up the building to form a number of individual buildings, and placed them on the different elevations of the mountain, hiding them in the green ecological mountain. Over the years, the building will form a symbiotic relationship with the mountain: hiding in the rocky forest, it also appears from the green of the rock, looming.
△ 林间多功能教室
△ 教学楼隐匿与山林
周围是一片翠绿的景色,覆盖在无尽的蓝天之下,阳光明媚,草木在微风地吹拂下微微颤动。孩子们总能在这片绿林找到自己所喜爱的“角落”,课堂从室内延伸到室外,在树荫下、阳光下、微风中……
Surrounded by an emerald green landscape, covered in an endless blue sky, the sun is shining brightly, and the vegetation is trembling slightly under the breeze. Children can always find their favorite "corner" in this green forest. The classroom extends from indoor to outdoor, in the shade of the trees, in the sun, in the breeze...
△ 林间教室
结语|设计思考
Conclusion|Design Thinking
在城市不断更新迭变的发展进程中,校园一直以一种配套和附属的形象存在。对个人而言,校园是美好的青春回忆;对城市而言,校园是文化的精神象征。如何通过创新的设计打造一所美好的校园不仅关乎个人,更关乎城市美好的形象。 创造教育新名片不仅是口号,更是城市策略。
In the continuous development of the city, the campus has always existed as a supporting and attached image. For individuals, campuses are beautiful memories of youth; for cities, campuses are spiritual symbols of culture. How to create a beautiful campus through innovative design is not only about the individual, but also about the beautiful image of the city. Creating a new business card for education is not only a slogan, but an urban strategy.
△ 孩子们在屋顶活动
设计关注基于功能需求下质量与成本的平衡,坚持对品质的追求和儿童健康成长的专注,更是将城市更新与校园改扩建相结合,从多层级的策略思考、全方面的设计落实,极大提高土地和空间的利用率。伴随着旧建筑的更新、功能的改善、自然的维护,城市活力正渐渐唤醒。
The design focuses on the balance of quality and cost based on functional requirements, adheres to the pursuit of quality and the focus on the healthy growth of children, and combines urban renewal with campus reconstruction and expansion. From multi-level strategic thinking and comprehensive design implementation, it is extremely Greatly improve the utilization of land and space. With the renewal of old buildings, the improvement of functions, and the maintenance of nature, the vitality of the city is gradually awakening.
夜幕降临,校园重回宁静。半山半校的玉溪生态实验小学安静的等待第二天师生的到来… …
As night fell, the campus returned to tranquility. The Yuxi Ecological Experimental Primary School, which is half a mountain, quietly waits for the arrival of teachers and students the next day...
▽ 项目技术图纸
△ 区位分析示意
△学校彩平面图
△ 学校功能分层平面
△ 建筑与山体剖面-1
△ 建筑与山体剖面-2
▽ 项目基本信息
项目名称丨玉溪市生态实验小学
项目地点丨云南玉溪
业主单位丨玉溪国联文化产业发展有限公司
设计单位丨上海思序建筑规划设计有限公司(建筑、室内、景观一体化设计)
主持设计丨王涛
设计团队丨戴庆辉、黄才、高崟、高畅、陈立峰、李龑、董雯、卢琴、司迪、陈晓朦
合作设计丨玉溪建筑设计院(结构、施工图)
用地面积丨23500 ㎡
建筑面积丨13000 ㎡
校园规模丨24班
设计时间丨2018年
竣工时间丨2020年
建筑摄影丨吴清山
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
只看楼主 我来说两句 抢板凳“建筑之力必须适应于自然之力,建筑的目的永远是创造一种能让建筑之力和自然之力在矛盾中共生的环境。”
