土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 国外海滨度假产品设计(小镇、别墅、酒店)
发布于:2020-07-14 15:57:14 来自:建筑设计/公共建筑设计 [复制转发]
X2 Pattaya Oceanphere是一个位于芭堤雅的别墅度假胜地,芭堤雅是一个商业发达的海边小镇,拥有著名的旅游胜地,度假村酒店和独特的海滨度假体验。
该场地位于泰国东海岸,面对泰国湾,那里有长长的海滩,没有太多引人注目的岩石或悬崖地形。
别墅度假村的建筑语言源于以可用的材料和高效的施工方法来创造人造景观的目的。
The X2 Pattaya Oceanphere is a villa resort situated in Pattaya, a well-developed beach town with cliché tourist destinations, hotels, and resorts chains. The site is located on the eastern seaboard of Thailand, facing the Gulf of Thailand where there are long stretches of beaches without much dramatic rocky or cliff terrain. The architectural language of the villa resort is derived from the aim to create man-made landscape with available materials and efficient construction methods.
该场地的坡度平缓,距海岸线有500米。
到达后,这里有一栋三层高的悬崖状建筑,带有递增景观台阶,这是带有接待厅的会所,一层在别墅的后面,二层是餐厅,三楼是主泳池。
这些设施是为了将客人带到更高层面的地方,使他们可以尽情的欣赏风景秀丽的海景。别墅遵循现有的坡度进行布置,以使大多数别墅的二楼都能欣赏到海景。
The site has a mild sloping contour with 500 meters offset from the beach line. Upon arrival, there is a monolithic cliff-like 3 story building with escalating landscaped steps, a club house with an arrival lobby, the back of house at ground floor, a restaurant at second floor, and the main pool at the third floor. These facilities were raised to bring the guests to the elevation where they can thoroughly enjoy the scenic sea view. The villas are arranged following the existing slope with minimum cut and fill operations to allow for the second floor of most villas to accommodate the ocean view.
别墅的平面布局分为两个不同的部分。
第一部分是主起居和就寝区,而第二部分则是专门用于服务和流通。起居区被设计为一个开放空间,可采用高玻璃推拉门或滑动折叠门封闭,打开时可以完全隐藏。
The plan of the villa is separated into two distinct parts. The first part is the main living and sleeping area while the second part is dedicated to services and circulation. The living area was designed as an open space which can be enclosed with high glass sliding doors or slide and fold doors which can be completely concealed when open.
虽然服务区被视为坚固的悬崖状墙,但它是用当地的混凝土砌块建造的,该混凝土砌块具有定制的边缘轮廓,形成了锥形的前立面,还可以作为裸露的雨水通道,连接屋顶排水沟和地面景观基地排水沟。
该砌块墙已发展成更大,更深的墙,其中包含了会所的所有服务设施,核心筒和休息区域。整体建筑设计旨在证明简单的构造和自然机制可以欣赏。
While the service area is treated as solid cliff-like walls, it is constructed with local concrete blocks with customized edge profile forming the tapered front facade of doubling also as an exposed rain waterway, connecting roof gutter to on ground landscape site drain. This block wall was developed into the larger and deeper walls incorporating all the services, lift cores and resting areas of the club house. The overall architectural design aims to prove that simple tectonic and natural mechanisms can be appreciated when highlighted properly.
平面图
建筑师:Creative Crews
地点:泰国 芭堤雅
面积:18000平方米
  • lijiawei411
    lijiawei411 沙发
    2020-07-26 11:40:26
公共建筑设计
51.18 万条内容 · 448 人订阅
抬抬抬抬抬头看建筑,爽哉!
仰  /  视  /  之  /  美 欣赏时间到
