土木在线论坛 \ 建筑设计 \ 建筑效果图 \ 世界最高的混合木材塔楼,开启一种创新的新方法
发布于:2020-07-02 09:43:02 来自:建筑设计/建筑效果图 [复制转发]
Atlassian新总部
世界上最高的商用混合木材建筑
即将成为“世界上最高的混合木材建筑”的Atlassian总部正在澳大利亚悉尼建造。由SHoP与BVN合作设计,这座40层高的塔楼预计2025年建成,于后将为科技巨头Atlassian提供一个崭新的创新空间。
The Atlassian Sydney Headquarters, the soon to be “world’s tallest hybrid timber building” is being built in Sydney, Australia. Designed by SHoP in partnership with BVN, the 40-story high tower will provide, once completed in 2025, a new and innovative space for technology giant Atlassian.
总部位于纽约的SHoP,澳大利亚BVN以及Eckersley O’Callaghan结构工程公司联合设计。
新的Atlassian总部将打破所有记录。在建的世界上最高的混合木材建筑将成为数千名科技人员的新家。
Designed in conjunction with New York-based architect SHoP, in partnership with Australian firm BVN and Eckersley O’Callaghan as the structural engineering firm, the new Atlassian Headquarters in Sydney will break all the records. Under construction, the world’s tallest hybrid timber building will be home to thousands of technology workers.
混合性地使用木材、玻璃和钢作为材料,将用于塔楼室外和室内区域,“将采用节能的方法,以自然通风和大型绿植露台为特色,使人们能够亲密接触大自然。
该项目符合Atlassian的价值观,将100%使用可再生能源,实现净零排放。实际上,总部的目标是与传统建筑相比,建筑中的含碳量减少50%,而建成后与传统建筑相比,能耗降低50%。
垂直立面中的太阳能电池板将有助于现场产生绿色能源。最终,该建筑将在立面上采用内置的太阳能电池板,以100%可再生能源运行。
Including a mix of outdoor and indoor spaces, the timber design with a glass and steel facade, “will use an energy-efficient approach that features natural ventilation and large planted terraces giving access to nature”. The project, in line with Atlassian’s values, will operate on 100% renewable energy and reach net-zero emissions. In fact, the headquarters aim for 50% less embodied carbon in construction compared to a conventional building, and 50% less energy consumption compared with a new conventionally operated building. Solar panels in the vertical facades will help generate green power on-site. Eventually, the building will operate on 100% renewable energy with built-in solar panels in the facade.
新混合木结构实现了Atlassian的目标,即到2050年实现零碳净排放,“显着降低了碳排放量,大大减少了建筑的碳足迹”。
此外,立面还集成了具有自遮阳功能的发电系统,以减少内部的直接热量获取。
结合大量木材的使用,创新的立面使项目能够利用悉尼的温带气候来帮助减少碳排放并产生现场能源。
Realizing Atlassian’s goal of achieving net-zero carbon emissions by 2050, the new hybrid structure “is significantly lower in embodied carbon and offers a substantial reduction in the building’s carbon footprint”.In addition, the facade incorporates an electricity-generating system with self-shade capabilities to reduce direct heat gain internally. “Combined with the use of mass timber, the innovative facade enables the project to leverage Sydney's temperate climate to help reduce carbon emissions and generate onsite energy”.
我们的设计注重提升城市环境中公共领域的体验,因此,我们非常珍惜有这样的机会与如此出色的合作伙伴联合,为悉尼新科技区的天际线打造一座高性能的地标。-SHoP创始负责人William Sharples
Our collective work around the world focuses on elevating the experience of the public realm in urban environments, so we really welcome this opportunity to work with such wonderful partners to create a high-performance landmark for Sydney's new tech district, at ground level, and in the skyline. -- William Sharples, SHoP Founding Principal
该项目高约180米/ 590英尺,是世界上最高的商用混合木材建筑。在设计中,建筑的结构元素与立面联系在一起。由SHoP / BVN和Eckersley O’Callaghan共同设想,这种方法产生了一个钢外骨骼,支撑着巨型楼层。此外,木结构建筑为员工和访客提供了一个温暖而诱人的环境。
A leading design in Mass Timber Construction (MTC), the project at approximately 180 meters / 590 feet high, is the tallest commercial hybrid timber building in the world. Part of the design, the structural element of the building is tied to the facade. Imagined by SHoP/BVN together with Eckersley O’Callaghan, this approach generates a steel exoskeleton that supports the mega floors between neighborhoods. Moreover, the timber building generates a warm and inviting environment, for workers and visitors.
项目视频:
我们开发了一种创新的新方法,使用体量为木材的混合结构来设计这座塔楼。[…]与传统的高层建筑相比,此方法可将减少高达50%的碳排量,从而为未来的木结构塔楼设定新的可持续性标准。-Eckersley O’Callaghan创始董事,James O 'Callaghan。
We have developed an innovative new approach to designing tall towers using a hybrid structure where the volumetric mass is timber. […] This approach significantly reduces the embodied carbon of the tower by up to 50% when compared to traditional tall building construction, setting a new sustainability standard for tower construction in the future. -- James O’Callaghan, Eckersley O’Callaghan Founding Director.
建筑师:SHoP
地点:澳大利亚 悉尼
层数:40层
高度:约180米/ 590英尺
  • davidliu_sha
    davidliu_sha 沙发
    好资料,感谢楼主无私的分享
    2020-09-09 11:24:09
  • 小潘土木
    小潘土木 板凳
    能在这上班一定很爽,最好在顶楼
    2020-07-02 15:39:02
建筑效果图
4.15 万条内容 · 143 人订阅
中华新城商业综合体规划设计
项目档案地点:重庆,渝中面积:620000㎡类型:商业综合体设计服务:商业综合体设计 中华新城是由重庆中华企业房地产发展有限公司投资开发的大型综合物业。占地面积9.5万㎡,总建筑面积62万㎡,是重庆主城内大型的复合式房地产项目。该项目融SHOPPING MALL、高档住宅、甲级写字楼、五星级酒店、酒店式公寓为一体,是重庆市未来的城市新地标。
