土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 为什么我的CAD2006安装中出现以下提示内容
只能安装2004,05、06、07都安装不了
全部回答(1 )
  • dzf1999
    [2/27/2008 23:34:05] === Installation started on JUJUMAO by Administrator ===
    [2/27/2008 23:34:06] [Info] Windows Installer upgrade is not required
    [2/27/2008 23:34:06] System Version = 3.1.4000.4039
    [2/27/2008 23:34:06] Installation skipped: MSI Runtime 3.0
    [2/27/2008 23:34:06] [Info] .NET Framework Runtime upgrade is not required
    [2/27/2008 23:34:06] System Version = 2.0.50727.832
    [2/27/2008 23:34:06] Installation skipped: .NET Framework Runtime 1.1
    [2/27/2008 23:34:06] Installation started: .NET Framework Runtime 1.1 Language Pack
    [2/27/2008 23:34:06] Command = "D:\AUTOCA~1\Bin\AcadFEUI\support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
    [2/27/2008 23:34:08] [Error: 1603] 安装时发生严重错误
    [2/27/2008 23:34:08] Installation failed: .NET Framework Runtime 1.1 Language Pack
    [2/27/2008 23:34:08] Installation aborted
    [2/27/2008 23:34:31] === Installation ended ===
    2008-02-29 01:11:29 来自 PC 评论 举报
CAD下载及教程
52.09 万条内容 · 690 人订阅
