土木在线论坛 \ 电气工程 \ 工业自动化 \ control of a vertical
发布于:2008-02-22 15:14:22 来自:电气工程/工业自动化 [复制转发]
Hello to all.
I need some help in controlling a vertical gantry using a s7-200 with only I/O digital ports and a ST400NT stepper motor control board. the gantry stops at different points due to opto-switches.
I would like to use distributed control where the plc tells the motor control board to start and stop. I am a novice at plcs so can someone please respond or it would be most appriciated if a sample code can be given to me
thank you(the board can be viewed on ....)
the board as one of its features can be controlled using serial link, can the s7-222 cpu with I/O control a motor controller board like that?
  • lvxinchi
    lvxinchi 沙发
    :L :L :L
    please say chinese
    2008-08-08 11:33:08
工业自动化
17.93 万条内容 · 389 人订阅
求助关于200与EV2000变频器RS485通讯
现在有一个造纸机传动项目,要求 S7-200 CPU226CN 与 EV2000变频器 RS485通讯控制,请问哪位大虾有此方面的程序,借我学习一下~ 不胜感激!!!!!!!!如果有造纸机分部传动方面的程序也可~~~~~~~~~~~~十分感谢~ 我的邮箱:860008007@qq.com
