BIM专业软件
返回版块9081 条内容 · 268 人订阅
Autodesk revit architecture快捷键本文就Autodesk revit architecture当中的快捷键做简单介绍,仅为参考。编辑 "DE" -删除 "MD" -修改 " menu:" -上次选择 "SA" -选择全部实例 "MV" -移动 "CO" -复制 "CC" -复制 "RO" -旋转 "AR" -阵列 "MM" -镜像 "RE" -调整大小 "GP" -创建组 "EG" -编辑 "UG" -解组 "LG" -链接组 "EX" -排除构件 "MP" -将构件移到项目 "RB" -恢复已排除构件 "RA" -全部恢复 "AP" -添加到组 "RG"-从组中删除 "AD" -附着详图 "PG" -组属性 "FG" -完成组 "CG" -取消组 "PP" -锁定位置 "UP" -解锁位置 "CS" -创建类似实例 "PR" -属性; 视图 "ZR" -区域放大 "ZZ" -区域放大 "ZO" -缩小两倍 "ZV" -缩小两倍 "ZF" -缩放匹配 "ZE" -缩放匹配 "ZX" -缩放匹配 "ZA" -缩放全部以匹配 "ZS" -图纸大小 "ZP" -上次滚动/缩放 "ZC" -上次滚动/缩放 "VP" -视图属性 F8 -动态修改视图 "VG"-可见性/图形 "VV" -可见性/图形 "HH" -隐藏图元 "HI" m -隔离图元 "HC" -隐藏类别 "IC" -隔离类别 "HR" -重设临时隐藏/隔离 "EH" -在视图中隐藏-图元 "VH" -在视图中隐藏-类别 "EU" -取消在视图中隐藏-图元 "VU" -取消在视图中隐藏-类别 "WF" -线框 "HL" -隐藏线 "SD" -带边框着色 "AG" -高级模型图形 "TL" -细线 "RR" -渲染-光线追踪 F5-视图-刷新; 建模; "WA" -墙 "DR" -门 "WN" -窗 "CL" -柱 "CM" -构件 "LI" -线 "RP" -参照平面; 绘图 "DI" -尺寸标注 "EL" -高程点 "TX" -文字 "GR" -网格 "LL" -标高 "TG" -标记-按类别 "RM" -房间 "RT" -房间标记 "DL" -详图线; 工具 F7-工具-拼写检查 "MA" -匹配 "LW" -线处理 "PT" -填色 "SF" -拆分面 "AL" -对齐 "SL" -拆分墙和线 "TR" -修剪/延伸 "OF" -偏移; 设置; "SU" -日光和阴影设置 "UN" -项目单位; 窗口; "WC" -层叠 "WT" -平铺 "SI" snapcode:"交点" "SE" snapcode:"端点" "SM" snapcode:"中点" "SC" snapcode:"中心" "SN" snapcode:"最近点" "SP" snapcode:"垂足" "ST" snapcode:"切点" "SW" snapcode:"工作平面网格" "SQ" snapcode:"象限点" "SX" snapcode:"点" "SR" snapcode:"捕捉远距离对象" "SO" snapcode:"关闭捕捉" "SS" snapcode:"关闭替换"; "ZZ" -区域放大 "ZX" -缩放匹配 "ZC" -上次滚动/缩放 "ZV" -缩小两倍 "VV" -可见性/图形 "CC" -复制;
