土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 求祠堂全套设计图纸
求祠堂全套设计图纸
发布于:2019-04-20 01:04:20 来自:建筑设计/公共建筑设计 [复制转发]
在此请教各位大神,有大概想法的效果图,有大概尺寸,求完整的平面图,效果图
有没有人可以帮做图?可付费用。
地基大小:35M*65M,门前留35M*15M广场,大概完成效果如下:
如有哪位大神帮忙画图,请联系我,电话:18930210116
公共建筑设计
51.18 万条内容 · 448 人订阅
南京的又一地标!!江苏·南京承天大桥
江苏·南京承天大桥 AND office + NAN architects 在与AND office的合作下,NAN architects设想一座横跨中国秦淮河的南京承天大桥。该项目正在建设中,旨在在南京南北轴线间形成一个的重要连接,同时也创造了一个门户和令人印象深刻的地标。该结构将连接穿过南侧的京沪高铁和北侧的城市带高速公路。 In collaboration with AND office, NAN architects has envisioned the nanjing chengtian bridge to span across the qinhuai river bank in china. the project, which is currently under construction, intends to form an important connection between the north and south of nanjing, while also creating a gateway and impressive landmark. the structure will link the beijing-shanghai high-speed railway, which passes through the south side, with the city-belt highway to the north.
