© Pascal Léopold
建筑场地位于卡松半岛的Porzic 海滩,种着高大的南欧海松。周围建筑几乎都是新Breton风格的独栋别墅,这种风格是当地传统住宅的改良,是六十年代的典型住宅样式。 From the architect. Planted with greatly high maritime pines, the site is located above the Porzic beach, in the Crozon Peninsula. The surrounding constructions are almost exclusively individual houses of neo-Breton style, the evolution of the traditional dwelling of the region and typical of the sixties.
© Pascal Léopold
© Pascal Léopold
建筑的纬线是三层水平的,有两个悬臂飞檐。这些创造了可调节日光的外部通道。它们通过几种不同的材料来强调,例如地面水平铺设的未加工的当地红杉木,还有用于飞檐的白色混凝土。 The weft of the building is horizontal on three floors, with two cantilevers overhangs. These create an outside passageway allowing solar regulation. They are emphasized by several different materials, such as local unrefined red cedar wood horizontally laid, and white concrete for the overhangs.
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
South Facade/南立面
黑色水泥地板非常朴素,因为与建筑其余部分相比它是个倒退,它的色调非常接近传统石板的色调。门窗框架是黑色的金属材质。巨大的户外木质露台覆盖了一楼部分屋顶,这里能欣赏令人激动的卡松湾的风景。 The black concrete floor is very discreet, because it is setback compared to the rest of the building and its tint is very close from this of the traditional slate. The window and door frames are in a black coloured metal. A vast outside wood terrace covers a part of the first floor roof: it offers a breathtaking view over the Crozon bay.
© Pascal Léopold
业主希望得到低能耗房屋。为了达到这个目标,通过在南侧立面开窗,尽可能获取温暖,而在晚上可以将其关闭。至于北侧和东侧立面,则只有很少数的开窗。 The owners wished for a low-energy house. This objective is reached by opening the south facade as much as possible in order to obtain warmth and restore it at night. As for the North and East facades, they have very few openings.
© Pascal Léopold
体量的简单和紧致,加上高效率的隔热,以及可持续能源如地热的使用,培养了生物气候学的方法。 The simplicity and the compactness of the volumes, added to a highly efficient insulation and the use of sustainable energy (eg: geothermic energy) foster this bioclimatic approach.
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
© Pascal Léopold
Plan/平面图
Plan/平面图
Plan/平面图
West Facade/西立面
North Facade/北立面
East Facade/东立面
Section/剖面图
Section/剖面图
Section/剖面图
Section/剖面图
© Pascal Léopold
建筑设计:Agence d’architecture Pierre-Yves Le Goaziou 项目位置:法国卡松 主建筑师:Pierre-Yves Le Goaziou 项目时间:2012年 摄 影:Pascal Léopold |
1人已打赏
居住建筑设计
返回版块28.67 万条内容 · 403 人订阅
马塞诸塞州艺术设计学院学生宿舍楼马塞诸塞州艺术设计学院学生宿舍楼 项目名称:马塞诸塞州艺术设计学院学生宿舍楼(Massachusetts College of Art and Design’s Student Residence Hall) 建筑师:ADD Inc.建筑事务所项目地点:美国,马塞诸塞州,波士顿项目面积:13,526㎡项目时间:2013年摄影: Chuck Choi, Lucy Chen, Peter Vanderwarker
只看楼主 我来说两句 抢板凳
