土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 英国HOME文化中心设计方案
英国HOME文化中心设计方案
发布于:2015-06-14 18:48:14 来自:建筑设计/公共建筑设计 [复制转发]
England HOME cultural center
设计方:mecanoo
位置:英国
这是由荷兰工作室mecanoo设计的曼彻斯特HOME文化中心,近日完工。这个全新的国际艺术、喜剧、电影中心位于曼彻斯特是中心,成为了英国的文化中心。该项目有望成为周边地区的催化剂,并将举办艺术项目、产品展示及大规模文化活动。该建筑坐落于一个三角形场地,本质决定了该建筑的平面布局。该建筑最大的特点是外立面和角落位为弧形设计,多色的玻璃幕墙会根据天气呈现变化。该建筑的悬挑部分还为咖啡馆与公共广场提供遮盖,可作为户外活动的区域。
室内则作为“城市客厅”,利用材料面板,灌输了一种亲密感,赋予了一种原始而精致的氛围,回应了该中心作为艺术与文化之家的理念。三角形平面布局的建筑包括画廊、餐厅和电影院。此外,主剧院将分为三层,最多能容纳500名观众。该项目位于铁路附近,隔音是施工的关键元素 ,从而保证电影院和剧院的演出环境。
dutch practice mecanoo has recently completed their design for the HOME center for international contemporary art, theatre and film in the heart of manchester. forming the cultural heart of the sprawling UK city, the building hopes to act as a catalyst for the surrounding area and will host artistic projects, productions and large scale cultural events. situated on a triangular sight, which has inherently determined the floorplan, the exterior fa?ade and corner features a curved form- a characteristic in mecanoo’s designs- whilst the glazing is clad in irregularly spaced fins- which change color depending on the weather. acting as an overhang, the building becomes a canopy for the café bar and public square that can be used for outdoor events.
wanting the interiors to reflect an ‘urban living room’, the layout instills a sense of intimacy where the material palette used, gives the scheme a raw and refined atmosphere- underling the center’s purpose as a home for the arts and culture. the triangular floorplan includes a gallery, the restaurant and one of the five cinemas. in addition, the main theatre has been divided into three levels with the seating capacity of 500 people. residing near a railway, sound insulation was a key element during the construction to enable shows at the cinema and theatre to play simultaneously.
英国HOME文化中心内部演出厅实景图
全部回复(5 )
  • hawk9416
    hawk9416 沙发
    内部设计得不错
    2016-04-12 09:29:12
  • piao04
    piao04 板凳
    好资料,感谢楼主!
    2016-04-12 09:22:12
公共建筑设计
51.16 万条内容 · 429 人订阅
澳大利亚威廉斯镇图书馆
Australia Williamstown Library 设计方:Sally Draper Architects, Mitsuori Architects 位置:澳大利亚 摄影师:Mein Photo 该图书馆位于澳大利亚威廉斯镇,由Sally Draper设计。该建筑结构灵感来源于自然风景和当地历史建筑景观。在这里,流经海湾的水源源不断,与牢固的海堤和海滩上建筑相呼应,形成一道风景。图书馆包括两大特色,一个是双层阅览室,阅览室外墙采用半透明聚碳酸酯材料建造,顶部由细长复合钢和“肋骨”状排列的木材组成;另一个线型青石建筑区域,这种设计可固定建筑、隔绝附近停车场带来的噪音。同时,该区域还包括图书馆展览区、辅助空间、会议室和办公室。建筑师遵循可持续原则进行设计。图书馆内有一个大型雨水存储槽,建筑底层通风设备、建筑上层屋顶抽风器和自动开关窗的设计能最大限度保障自然通风,同时,被动式太阳能设计可降低能耗和耗水量。
