土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 葡萄牙Miguel Torga Space文化中心
发布于:2015-06-14 18:17:14 来自:建筑设计/公共建筑设计 [复制转发]
Portugal Miguel Torga Space cultural center
设计方:Eduardo Souto de Moura
位置:葡萄牙
摄影师:Luis Ferreira Alves
Miguel Torga Space文化中心位于葡萄牙萨布罗萨,由Eduardo Souto de Moura设计,其目的是在活动中学习和传播Miguel Torga的诗歌和文学作品。该建筑外墙为片岩墙(这一地区典型建筑特色),这一设计划定建筑范围,设定建筑形象。该建筑有两个入口,南部有两个老庭院,东部为公共区域,西部为服务区域,东西部被墙壁分开。建筑西部有一家自助餐厅,通过大型落地玻璃门可进入该餐厅。
Miguel Torga Space文化中心为两层建筑(地上一层和地下一层),占地面积将近1315平方米。室外停车区域和商店占地面积将近3115平方米,四周的墙壁高度不同,停车场和商店为1米高度墙,建筑为5.5米墙。建筑外墙为钢筋混凝土结构,墙外层为Foz-Coa片岩。结构内墙由混凝土建造,隔墙由砖砌体构成。屋顶外层铺有一层卵石层。
The “Miguel Torga Space” cultural center proposes, among other activities, to study and disseminate the poetic and literary work of Miguel Torga.The schist walls (characteristic elements of this area), draw the boundaries of the building and define its image.The building is implanted south of old fair grounds and has two entrances, public (east) and services (west), set by the mismatch of the walls. There is also a direct entrance to the cafeteria (west), through a large glass door, allowing an independent program.
The building has two floors (a ground floor and one floor below ground level), a site area of approximately 1315 m2, an outdoor parking area / market of approximately 3115 m2 in a variable height, and two walls that configure it, between 1 meter (parking / fair) and 5.5 meters(building).Constructively the building consists of a reinforced concrete structure externally clad in schist pillars of Foz-Coa. Structural interior walls are made of concrete and partitions are made of brick masonry; on this system are set up the final finishes. The roof is coated with a layer of schist cobble.
全部回复(3 )
  • yuyanhui63
    yuyanhui63 沙发
    设计的很有创意
    2016-07-08 04:36:08
  • 结构大佬
    结构大佬 板凳
    学习了,谢谢。
    2016-07-07 22:08:07
公共建筑设计
51.17 万条内容 · 431 人订阅
奥地利Tirolerl新节庆音乐厅
Austria Tiroler new Festival Hall 设计方:Delugan Meissl Associated Architects 位置:奥地利 摄影师:Brigida González 这是由奥地利建筑公司Delugan Meissl Associated Architects设计的Tiroler Festspiele Erl新节庆音乐厅。这个新建建筑位于奥地利埃尔,棱角分明,通体黑色,以岩层为背景,其造型的设计灵感来自场地周边地形。现状的“激情剧场(Passion Playhouse)”初建于五十年代,自1998年以来它就作为Tyrol Festiva的夏日剧场和管弦乐团的表演场地,使用频繁。因此该项目旨在为冬日里举办活动提供音乐厅,而其巨型的单体体块从视觉上与现状建筑相互渗透。两者相视而对,两者通过充满张力的视线联系提高了它们之间的建筑对话。
