土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 奥地利萨尔斯堡水城设计方案
奥地利萨尔斯堡水城设计方案
发布于:2015-06-14 14:37:14 来自:建筑设计/公共建筑设计 [复制转发]
New Paracelsus Spa and Pools in Salzburg Winning Proposal
设计方:HMGB Architects
位置:奥地利 萨尔斯堡
建筑面积: 14000 平方米
造价: 37 00万欧元
预计完成时间: 2014年
HMGB Architects设计事务所近来公布了他们在奥地利萨尔斯堡水城设计竞赛中获得第一名的方案。项目位于花圃公园的北端,取代了原来建于1950年的帕拉塞尔苏斯水城,包括七个不同的spa水池、桑拿房和水疗空间,还有城市各部门的办公室。设计通过建筑清晰明确的体量定义了公园西北的边界,水城分为两个部分,北边的部分包含了全部7个spa水池,南侧部分则容纳了水疗功能和办公空间。为了更多的沐浴阳光,欣赏公园和城市的景色,所有的室内spa都设置在完全透明的玻璃幕墙之后,朝向南侧的公园,玻璃幕墙就像一座垂直的水池景观,而享受spa的人们会感到似乎是在树冠中沐浴一样。所有的水池都相连通,像是河流,分支再融合。有些水池的池底和池壁是透明的,形成内外之间更多的景观交流。水滑梯和跳水板的设计融入到了景观之中,滑梯、跳水板和循环装置都固定在背景墙上。背景墙部分是透明的、部分是不透明的。通过透明的部分,北面的桑拿、疗养和办公空间里的人们可以穿透spa部分欣赏到公园的景色。建筑的南部与公园融合,北部则融入城市肌理,入口位于公园一边,并设置了室外咖啡座。
HMGB Architects shared with us their first prize winning proposal in the competition to design the new Paracelsus Spa and Pools in Salzburg, Austria. Located at the northern edge of the Mirabellgarten Park, the project will replace the existing Paracelsus Spa and Pool from the 1950s to include a spa with 7 different pools (6 internal and 1 external pool), sauna and therapy spaces, as well as offices for various city departments. The design defines the northwestern park edge through the building’s clear volumetric mass and is divided into a southern part including all pools and a northern part including therapy and office spaces. In order to make the most of the south-facing orientation towards the sun, the park and views over the city, all interior pools are assembled in a completely glazed vertical pool landscape that faces the park southwards. Visitors feel as if they were taking baths inside the tree canopies. All pools are connected into a continuous, forking and re-connecting vertical landscape. Some of the pools have glazed openings in the bottom and sides to allow for more views in- and outside. A slide and diving boards are integrated into this landscape. The whole pool landscape including pools, slide and circulation elements is cantilevered from a collective back wall.This back wall is partly opaque, partly transparent and translucent to allow for views from the sauna, therapy rooms and offices in the northern part through the pool landscape into the park. A wide passage connects the southern park with the urban context northwards. Inside the park-facing part of the passage, the main public entrance and an outdoor café are situated.
萨尔斯堡水城-10
公共建筑设计
51.16 万条内容 · 431 人订阅
美国汉普顿纽约桥•高尔夫会所
The Bridge 设计方:Roger Ferris + Partners 位置:美国 汉普顿 纽约 竣工:2010年 摄影师:Paùl Rivera © Archphoto 面积: 40000 平方英尺这座高尔夫球场及俱乐部的设计根植于这样的理念:环保、自足、节约能源并且最低程度的破坏原有的自然景观。总平面的设计和选址基于的原则是尽量减少道路的面积,并且减少建筑的占地。所以这座俱乐部是一个选址谨慎,对环境负责的建筑,符合当地的气候和文化,并采用了节能技术措施。其形式和朝向的选择都是为了实现绿色建筑这个观念。弧线的屋顶为捕获盛行风向而设计,也有利于雨水的收集。在三面都能看到长岛海岸线的高尔夫球场里,形成像起伏的小山一样的景观。整块的双层玻璃不但能带入充沛的阳光,也更便于对流通风。长长的低矮屋檐在建筑各个表面上都减小了热量摄取。这座两层楼高、面积达4万平方英尺的俱乐部包括了所有跟高尔夫或者社交活动有关的空间。除了更衣室、健身设施、设备用房等,还包括餐厅、办公室和行政管理区。
