Courtesy of Note_D
这是位于Alibaug的庭院式豪华别墅。通过以起挑悬臂巧妙地调整,使室内外空间的过渡变得模糊的,户外体验感得到了提高,且使得占地面积最小化。别墅的螺旋几何形状提供了封闭、半封闭和阴影的空间。螺旋分隔出了二楼的私人领域(卧室),一楼的公共区域和半地下室的设备区。功能性的户外空间,如夹层的阳台,在居住者从公共领域走向分布在庭院周围的私人空间时也次第注入新的元素,以保持视觉上的水平连接。 From the architect. Adapting the courtyard type for a luxury villa in Alibaug. By manipulating the courtyard i.e. lifting an arm, the transition between indoor and outdoor spaces is blurred, outdoor experience is enhanced and ground coverage is minimised. The resultant spiral geometry of the house provides enclosed, semi enclosed and shaded spaces. The spiral segregates into private areas on first floor (bedrooms), public areas on ground floor and service areas in a semi basement. Programmable outdoor spaces such as the loggia on the mezzanine are injected at regular intervals as you move from public to private around the courtyard, maintaining a visual connection across levels.
Courtesy of Note_D
Courtesy of Note_D
土丘保护了在洪水易发区的房子,并成为庭院景观的延伸。光面的建筑语言掩盖了结构元素并且疏导了地表径流。窗户的玻璃镜像出室外的植物,在施工期间植物没有受到任何的干扰。 The mound protects the house in a flood-prone zone and becomes an extension of the courtyard into the landscape. The faceted vocabulary disguises structural elements and channelizes surface run-off. The windows mirror the foliage outside, none of which was disturbed during construction.
Floor Plan/楼层平面图
Alibag迅速发展成为城市精英的首选目的地。从孟买乘船到Alibag也只是很短的路程,群山环绕其中且有大片开放式的绿色空间。Tomoe别墅坐落在一个古朴的村庄,距离码头10分钟路程。其郁郁葱葱的环境为住宅创造了极佳的地理位置,易于维护且将周围环境引入室内。别墅包含了生活区,一间厨房,六间卧室,花园,露台和一个游泳池。清新的空气环绕其间,茂盛的枝叶挡住了繁忙的城市生活的所有痕迹。 Alibag is fast becoming the destination of choice for the city’s elite. It’s a short boat ride from Mumbai, is surrounded by hills and has vast spaces of open green. Tomoe homes are nestled in a quaint village 10 minutes from the jetty. Their beautiful location and lush surroundings create the perfect setting for a home that is radically designed, easy to maintain and has the ability to invite the outdoors inside. The villas effortlessly contain living areas, a kitchen, six bedrooms, gardens, terraces and a swimming pool. They’re all accessorized with fresh air and lush foliage to block out all traces of hectic city living.
Courtesy of Note_D
Tomoe之家对于印度风格的周边及当地的环境非常敏感。该别墅是基于一个典型的印度庭院住宅进行设计的,这有利于适应热带气候,尤其是光线和通风条件。庭院式别墅模糊了分隔墙,营造一了个绿化环境。该别墅在其中一端被抬起,提供一个完全开放的首层的感觉。客厅和用餐区面向包含花园和游泳池的30000平方英尺的景观,上层包含了卧室、一个私人休息室和露台,而在两个楼层之间的夹层是一个有顶的户外客厅的理想场所。许多室内和室外空间融合在一起,创造了一个无缝的生活体验。 Tomoe homes are sensitive to their Indian context and the local environment. The design is based on a typical Indian courtyard house, which is conducive to tropical weather, especially in terms of light and ventilation. The courtyard house blurs the walls of separation to create greenery The house is raised on one end to offer a completely open ground floor feel. Living and dining areas open out on to 30,000 square feet of landscaped gardens and a pool, the upper level becomes a cocoon for bedrooms, a private lounge and terrace while the mezzanine between the two floors is the perfect setting for a covered outdoor living room. The many indoor and outdoor spaces fuse together to create a seamless living experience.
Courtesy of Note_D
Floor Plan/平面图
水池位置的设置充分利用了风向,达到为房屋自然降温的目的。在草坪上铺路既环保,又易于维护。厨房通向花园,新鲜香草和蔬菜随手可得。庭院区域连接到房子,但也有自己的入口可通往厨房和用餐区。 The location of the pool has been chosen to take advantage of the wind direction in order to naturally cool the house. The pavers on the lawn are environmentally friendly and easy to maintain. The kitchen opens out to a garden to gain instant access to fresh herbs and vegetables. The domestic area is attached to the house, but has its own entrance with access to the kitchen and dining areas.
© Tina Nandi
Courtesy of Note_D
Courtesy of Note_D
© Tina Nandi
Site Plan/场地平面图
Section/剖面图
Section/剖面图
Diagram/图解
Model/模型
Model/模型
Model/模型
Model/模型
Model/模型
Model/模型
建筑设计:Note-D 位置:印度马哈拉施特拉邦 项目负责人: Hemant Purohit, Smita Khanna 设计团队:Pierre Michael, Sneha Borkar, Bhuvana Selvaraj, Teja Choudhary 面积:5500.0平方英尺 时间:2014年 摄影:Courtesy of Note_D, Tina Nandi 顾问: Renu Gupta 开发商:Sidhant Khanna 结构顾问:Suhas Jadhav (Vastech) 卫生设备:Husain Quettawalla(Bath工作室) 施工单位:UCT / Sachin Jayesh Gharat / Jivaram Suthar |
1人已打赏
居住建筑设计
返回版块28.67 万条内容 · 403 人订阅
澳大利亚维多利亚度假屋© Peter Bennetts 该度假屋坐落在位于Mornington半岛上的高台地上的沿海植被,呈现出低矮,不可描述的街道形态。该场地可以通过相邻的天然绿色屏障后面的小路进入,围绕出场地明显而非正式性质。From the architect. Set within coastal vegetation, on an elevated site on the Mornington Peninsula, the Holiday House presents a low slung, non-descript street presence. The site is accessed via an unsealed road from which adjacent properties are generally set back behind a natural green buffer, lending the surrounds a distinctly informal character.
只看楼主 我来说两句抢地板回复 举报
