土木在线论坛 \ 建筑结构 \ 结构资料库 \ 香港移动式蜂巢酒店
香港移动式蜂巢酒店
发布于:2015-03-28 13:00:28 来自:建筑结构/结构资料库 [复制转发]
这座蜂巢酒店是香港的OVA工作室设计的, 每间客房像集装箱一样,可以移动,非常灵活机动。该项目为建造新增住房和医疗保障住房提供了条件。每个房间可以根据需求进行移动,而且房间的功能很多,还能做办公室, 要是个人或公司暂时需要办公场所时,来蜂巢酒店就是不错的选择。整体的设计注重可持续发展,房间可以循环利用,重新组装,打造新的模块。这些房间能自由地穿插、缩进,不受限制。根据实际需求,整栋酒店可以自行调节高度。集装箱似的客房来回移动,进进出出,形成一个网格系统。外部的结构很适合打广告。
the ‘hive-inn’ is a hotel structure designed by hong-kong-based OVA studio that allows containers to travel in and out of it. offering maxi-mum flexibility and mobility, the project envisions possibilities for applications such as emergency housing or medical care units. the rooms can be shipped to whatever location is required and used for multiple functions such as offices, leased to various individuals or companies who temporarily need space. focusing on sustainability, recycled containers are used for the modular pieces that are then slotted and plugged in independently of what is above or under them – enabling the building grow and or decrease in relation to demand.
全部回复(6 )
  • 土木1号
    土木1号 沙发
    感谢楼主提供的好资料,谢谢了
    2015-05-16 08:12:16
  • yzl0305
    yzl0305 板凳
    好,妙,有创新啊,思路非常好
    2015-04-02 11:39:02
结构资料库
41.17 万条内容 · 368 人订阅
超详细支座,看的清楚,一看就知道哦
超详细的支座图,看的清楚,一看就知道哦
