国内外网友讨论:
①Did they use some sort of durable prefabricated materials for the building?是否采用了某些耐用的预制材料?Beast(中国)
②It safer than any building build in Philippines.比菲律宾的大楼安全Guynextdoor2(印度)
③Only in china.只有在中国才可能yusheng
④J57 will officially cap on February 16 afternoon, steel structure setting upfinished.Height is 204 meters.This is changsha’s 16th building higher than 200meter大楼将于2月16日下午正是封顶。钢结构已经搭建完成。高度为204米。这是长沙第16栋200米高的摩天楼。Ryuzaki(印度)
⑤only the chinese can do this.When i first saw this news i though it wasfake.Hatsoff!只有中国人才能办到!第一次看到这个新闻的时候以为是假的。致敬!VALKRYIE(加拿大)
⑥How many shortcuts did it take to build it. I imagine a lot到底偷工减料了多少哦。Beast(中国)
⑦There is no doubt China is an advance country.毫无疑问,中国是先进国家。yusheng
⑧I’m sorry dudes. I ain’t entering that building anytime soon. I will admire itfrom a distance though.老兄,抱歉。我不会进那栋大楼的。我会离得远远的赞叹之。opruh(菲律宾)
⑨Don’t worry, you’re not even invited to enter.别担心,他们不会邀请你进去的PATHAN786KING(巴基斯坦)
5人已打赏
返回版块140.14 万条内容 · 2080 人订阅
全部回复(258 )
只看楼主 我来说两句回复 举报
非常感谢楼主的分享
