发布于:2007-07-31 19:07:31
来自:人才招聘 / 学生专栏
[复制转发]
h beam 宽幅工字梁
h pile 工字型桩
habitable area 居住面积
habitable room 住房
habitat condition 居住条件
habitation 住宅
habitation building 居住房屋
hack saw 弓形锯
hacking knife 砍刀
hade 垂直倾斜
haft 把手
hail 雹
hair crack 发丝裂缝
hair mortar 麻刀灰泥砂浆
haired cement mortar 毛丝水泥灰浆
half angle 半角
half bat 半块砖
half brick 半块砖
half brick wall 半砖墙
half column 半身柱
half glass door 上半装配玻璃的门
half goods 半制品
half landing 中间平台
half lap joint 半叠接
half lattice girder 格构梁
half mortise hinge 半开榫铰接
half plane 半平面
half storey 半层
half surface hinge 半节门折翼
half tide cofferdam 半潮围堤
half tiled wall 半截贴面砖墙
half timber house 砖木结构的房屋
half truss 半桁架
halfpace 中间平台
halfpace stair 两节楼梯
halfspan loading 半节距装载
hall 大厅
hallway 穿堂
halogen 卤素
halogen leak detector 卤素探漏器
halved joint 半叠接
hammer 锤
hammer beam 悬臂托梁
hammer dressed ashlar 锤琢石
hammer drill 凿岩机
hammering 锻造
hand brace 手摇钻
hand buggy 手推车
hand clamp 手动夹钳
hand compacted concrete 人工捣实混凝土
hand distributor 手压燃机
hand drill 手摇钻
hand finisher 手工整面机
hand float 泥刀
hand grip 手柄
hand guard 扶手
hand held compactor 手提式压实器
hand held roller 手提式路碾
hand mixed concrete 人工搅拌混凝土
hand mixer 手动混合器
hand operated bar cutter 手工钢筋切断机
hand placement 手动式浇注
hand rammer 手夯锤
hand sprayer 手动喷雾器
hand tool 手工工具
hand welding 手工焊
handiwork 手工
handle 柄
handling 操纵
handling equipment 搬运设备
handling reinforcement 架立钢筋
handling stresses 搬运应力
handrail 栏杆
handsaw 手锯
handwork 手工椎
hangar 飞机库
hanger 吊架
hanging 悬挂
hanging bridge 吊桥
hanging door 吊门
hanging gutter 吊挂檐槽
hanging post 悬挂支柱
hanging truss 吊桁架
harbour 港口
harbour basin 港池
harbour facilities 港口设施
harbour of refuge 避风港
hard aggregate 硬质骨料
hard asphalt 硬沥青
hard brick 硬砖
hard burnt plaster 无水石膏
hard compact soils 硬质压实土
hard concrete 干硬性混凝土
hard drawn wire reinforcement 冷拉钢筋
hard finish 硬质墙面层
hard glass 硬化玻璃
hard mortar 干硬灰浆
hard parking place 硬质铺面停车场
hard pavement 硬质铺面
hard rock 硬石岩
hard rock concrete 硬石混凝土
hard surfacing 表面淬火
hard top 硬质铺装路
hard water 硬水
hardboard 木纤维板
hardcore bed 碎石垫层
hardened cement paste 硬化的水泥浆
hardened concrete 硬化混凝土
hardened mortar 硬化灰浆
hardened neat cement paste 加固的路边
hardened verge 硬路肩
hardener 硬化剂
hardening 硬化
hardening accelerating admixture 促硬剂
hardening accelerator 促硬剂
hardening by chemical method 化学硬化法
hardening condition 混凝土硬结条件
hardening of concrete 混凝土硬化
hardening of ground 地基硬化
hardening process 硬化过程
hardness 硬性
hardness of concrete 混凝土硬性
hardness of water 水的硬度
hardness test 硬度试验
hardpan 硬土层
hardware 金属构件
hardware mounting machine 金属制品装架具
hardwood 硬木
hardy cross method 弯矩分配法
harmonic pencil 低束
harmony 低
harped tendon 竖琴形钢筋束
harsh concrete 干硬性混凝土
harsh mix 干硬性混合料
hasp 挂钩
hasp and staple 钩与扣眼扣件
hatch 舱盖
hatching 画影线
hatchway 屋顶口
haul 搬运
haul road 运料路
haulage 搬运
hauling 搬运
haunch 拱石段;加腋
haunch board 梁腋侧板
haunched beam 加腋梁
hawk 抹灰托板
haydite 陶粒
haydite concrete 陶粒混凝土
hazardous gas emissions 有害气体发散
hazardous materials 火烧性材料
hazardous substances 有害物质
haze 混浊斑点
全部回复(6 )
只看楼主 我来说两句回复 举报
