土木在线论坛 \ 建筑设计 \ 建筑资料库 \ 地下连续墙的注意事项
地下连续墙的注意事项
发布于:2010-09-20 01:04:20 来自:建筑设计/建筑资料库 [复制转发]
Additional information on diaphragm walls:
·        It is a classical technique for many deep excavation projects, large civil engineering works, underground car parks, metro pits etc. Especially under water table.
·        They may be used to provide structural support and water tightness.
·        Nowadays depth of panels exceeded 100m, excavation depths exceeded 50m.
·        Panel excavation is made by cable(d) buckets or kelly equipment. Recently soil cutters (hydrofraise)
·        Hard layers are excavated by trepaning or by using the recent drilling equipment “hydrofraise” or “cutter”.
·        Excavation very close to existing buildings is possible.
·        Integration to permenant structures is possible
·        Watertightness is generally sufficient for provisional structures, and may be improved for permenant structures by special joints.
·        If deviating panels occurs, flux of water into the pit may be experienced in water bearing permeable soils.
·        Slurry technique is a specialized technique and specialized contractors do the job.
Equipment: Crawler cranes, excavation equip. (buckets etc), extractor (stop and pipes), tanks, pumps, desanding equipment, air lifts, screens, cyclones, silos, mixers
  • lizhengang923
    lizhengang923 沙发
    谢谢楼主非常需要啊!!!
    2010-11-12 09:13:12
建筑资料库
13.58 万条内容 · 180 人订阅
土建资料员考试
谁有土建资料员的考试内容和教材,谢谢
