土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ OFIS建筑设计:四季帐篷塔
OFIS建筑设计:四季帐篷塔
发布于:2010-03-19 20:11:19 来自:建筑设计/公共建筑设计 [复制转发]
OFIS建筑设计:四季帐篷塔(用GOOGLE翻译的,整理的,太多了,大家将就着看吧,不好意思啦~~我把英文也配上了,英文好的自己看哈)
斯洛文尼亚的公司OFIS结构提出了'的一部分,四季帐篷塔'
奔驰的宾馆,埃里温市,亚美尼亚塔竞争。 概念
该项目连接两个梯田内的地下连接的圆柱形塔,
拥抱绿色帐篷形层。较高的塔将用作餐厅,
游泳池,水疗中心,健身中心和酒吧。 它还将成立专门的酒店和公寓以及
一个商务中心,商店和一个车库。 较低的结构向外延伸,从
主塔将成为住房和展览馆以及车库。
作为埃里温市所处的地区容易发生地震的主要驱动力时,
关于适用于建筑结构体系决定了地震时的安全。
垂直结构,抵抗重力负荷和行动的部队从地震造成的,
合理化加强塔的具体核心和复合列。 the two cores两个核心
对塔内四周高大须确保结构稳定,一个核心
在较低的机箱。 在基地,该内核的外墙是160厘米厚。
由于建筑物的梯田状,最外层的边界列倾向于
对建筑物的中心。 在最里面的周边人士更倾向于在三维空间
形成一个网格。 核心壁厚和列尺寸的高度降低
的建设。
slovenian-based firm OFIS architecture has proposed 'all seasons tent tower' as part of
the mercedes benz hotel tower competition for the city of yerevan, armenia. the concept
of the project joins two terraced cylindrical towers connected in the ground floor,
embraced with a green tent-shape layer. the higher tower will be used as a restaurant,
pool, spa, fitness centre and bar. it will also house a hotel and apartments along with
a business centre, shops and a garage. the lower structure which extends outwards from
the main tower will serve as housing and exhibition hall as well as garage.
as the city of yerevan is situated in a region prone to earthquakes, the main driver when
deciding on a suitable structural system for the building was safety during earthquakes.
the vertical structure, which resists gravity load and forces resulting from earthquake action,
was rationalized to reinforce the tower's concrete cores and composite columns. the two cores
on the inner perimeter of the taller tower are required to ensure structural stability, one core
in the case of the lower tower. at the base, the outer walls of the cores are 160 cm thick.
due to the terraced shape of the building, the columns on the outermost perimeter are inclined
towards the centre of the building. those on the innermost perimeter are inclined in 3D space
to form a mesh. the core wall thickness and column dimensions are reduced with the height
of the building.
对着城市的天际塔
the tower against the city skyline
正北面对山
两塔的定位和卷的方式,创建一个设计主流观点的城市
帐篷塔转乘皮肤-冬季
皮肤的外观涵盖了塔的台阶,创造开口和全面的结构元素。 它是由一个金属网的代表景观要素。它也对应于不同的季节。夏天是绿色网报道,在
是种植在塔的阳台围栏。在冬季时,它是白色的,部分雪覆盖着。 特别注意已采取优化环境条件和减少能源 .要求塔。 外部外墙将采用一个高性能的皮肤 适应外部遮阳设备,以减少夏季太阳的收益。 混凝土板 嵌入式系统提供冷却管道没有问题,草案在冬季舒适加热。 在夏季,内部空间冷却的方法主要是使用 该板系统。在冬季,新鲜空气将被加热内的单位和分发 进入房间使用置换通风的原则。
tent tower's interchanging skin - winter
the facade skin covers the terraces of the towers, creating openings and full-structural
elements. it is made from a metal mesh that represent elements of the landscape. it also
corresponds to the different seasons. in summer the mesh is covered by greenery that
is planted at the fence of the tower's terraces. in the winter time, it is white, partially
covered with snow.
special care has been taken to optimize environmental conditions and minimize the energy
demands of the tower. the external facades will feature a high performance skin with an
adaptable external shading device to reduce solar gains in the summer. a concrete slab
embedded pipe system provides cooling without draft problems and in winter comfortable
heating. in the summer, the cooling of internal spaces is achieved primarily through the use
of the slab system. during winter, the fresh air will be heated inside the units and distributed
into the rooms using the displacement ventilation principle.
海拔-北门面
能源供应系统的基础是自然资源。 集成光伏电池
进入中庭的屋顶生成塔权力
the energy supply system is based on natural resources.photovoltaic cells are integratedinto the atrium roof to generate power for the tower.
海拔-南立面
西部海拔
东海拔
埃里温一个新景观
游览购物中心
酒店大堂
部分计划
方案计划
位置图
平面图
完了~~~~~~~~~~~~~翻译的很多地方不对,向大家致歉啦~!因为本人英文一般,但是国外网站能简单看懂一些!
全部回复(4 )
  • tianyun_08
    tianyun_08 沙发
    耳目一新,环保理念,很好的资料,值得推荐,给了很好的翻译,方便了大家!
    2010-07-06 17:04:06
  • 泡泡
    泡泡 板凳
    D
    2010-07-06 16:16:06
公共建筑设计
51.16 万条内容 · 429 人订阅
建筑外立面用金属漆,谁用过?指导下俺。
砖混结构的老房子。原建筑外墙是水磨石的。有30多年历史了。现在翻新外墙想用金属质感的材料。考虑过铝塑板,但造价和耐久性觉得不合适。俺网上查了下。想用金属漆,但俺没用过。原来的水磨石外墙要处理到什么程度也不太了解。请那位懂行的能指点下俺?使用金属漆有什么注意事项不?除了金属漆有谁知道其他什么合适的材料吗?
