继2013年获奖的Z设计大楼之后,最近完工的Z-5大楼在“空中别墅”的概念上更进一步。我们的目的是在这里展示另一种替代类型,以对抗过于常见的“公寓楼”,因为我们周围都是典型的当代住宅建筑。
. Following our award winning Z Design building of 2013, Z-5 building, completed recently, takes even a further step in sharpening the "villa in the air" concept. We aim to present here another alternative typology vs. the too common "apartment block", so typical of contemporary residential architecture all around us.
方案基本上很简单,每层由四个单元组成。但没有“典型楼层”。通过旋转33个单元中的一些单元,减去某些楼层中的其他单元,我们打破了统一的街区:实现了三维的组合。
因此,虽然所有的公寓都“种植”在建筑核心周围,但每一个都几乎与它的邻居断开连接。作为这种组合的副产品,各种私人屋顶平台被创造出来,一些是小的-15平方米,一些大的- 100平方米。
The plan is basically simple, comprised of four units per floor. But there is no "typical floor". By rotating some of the 33 units and subtracting others in certain floors, we break the uniform block: a three dimensional composition is achieved. Thus, while all apartments are "planted" around the building core, each is almost disconnected from its neighbors. As a by-product of this composition, various private roof terraces are created, some are small -15 sqm, and some large - 100 sqm.
该结构基本上是35厘米厚,就地浇筑混凝土板,没有柱内的任何单位。外墙覆以干装的灰白色花岗岩。客厅和一些相邻的卧室被铝和玻璃幕墙包围,增强了透明和不透明的对比。
模型图
设计草图
平面图
立面图
剖面图
建筑师:Amir Mann-Ami Shinar建筑事务所
地点:以色列
面积:8500 m2
年份:2019
公共建筑设计
返回版块51.17 万条内容 · 431 人订阅
专家点评
只看楼主 我来说两句 抢板凳
