Resistance of RAU-SIK against chemicals
Change in Swelling Remarks
Test Medium 测试
温度 Shore Hardness硬度降低及增加 (%)变形
(℃) A (Points)
Formic acid conc. 甲酸,蚁酸 20 - 1 + 2 Good
Acetic acid conc. 乙酸,醋酸 20 - 1 - 1 Can be Used
Acetic anhydride 乙酸酐,无水醋酸 20 - 1 + 1 Good
Phosphoric acid 30% 磷酸 20 0 - 1 Can be Used
Phosphoric acid 85% 磷酸 20 0 - 1 Restricted Use
Phthalic anhydride 邻苯二甲酸酐,酞酸酐 150 - 1 + 2 Good
Nitric acid 10% 硝酸 20 - 2 0 Can be Used
Nitric acid 65% 硝酸 20 + 6 + 3 Not to be Used
Hydrochloric acid 10% 盐酸 20 0 0 Good
Hydrochloric acid 30% 盐酸 20 + 5 + 1 Restricted Use
Sulphuric acid 10% 硫酸 20 + 1 - 1 Can be Used
Hydrogen peroxide 10% 过氧化氢,双氧水 20 - 1 0 Good
Hydrogen peroxide 30% 过氧化氢,双氧水 20 0 0 Good
Ammonia conc. 氨水 20 + 12 + 2 Good
Calcium hydroxide saturated 饱和氢氧化钙 20 + 1 0 Good
Potassium lye 50% 氢氧化钾 20 - 1 - 1 Not to be Used
Sodium hydroxide solution 10% 氢氧化钠 20 - 3 + 1 Good
Sodium hydroxide solution 50% 氢氧化钠 20 - 3 + 3 Not to be Used
Potassium dichromate 20% 重铬酸钾 20 0 0 Good
Sodium chloride solution 10% 氯化钠 20 - 2 0 Good
Sodium chlorate 20% 氯化钠 20 - 1 + 1 Good
Sodium carbonate saturated 饱和碳酸钠 20 - 2 0 Good
Sodium perchlorate 20% 高氯酸钠 20 - 1 + 1 Good
Detergent solution 1% 清洁剂,去垢剂 20 0 - 1 Good
Acetamide 乙酰胺 150 + 3 + 1 Good
Acetone 丙酮 20 - 10 + 32 Can be Used
Benzyl alcohol 苯甲醇 20 - 2 + 1 Good
Butanol 丁醇 117 - 32 + 97 Can be Used
Butyl acetate 醋酸丁酯 20 - 25 + 152 Not to be Used
Chloroform 氯仿 20 - 29 + 244 Not to be Used
Diacetone alcohol 二丙酮醇 20 - 1 + 3 Good
Dibutyl ether 二丁醚 20 - 30 + 147 Not to be Used
Dimethyl formamide 二甲基甲酰胺 100 1 + 2 Good
1.4 Dioxan 二氧乙烷,二氧杂环乙烷 101 - 25 + 77 Not to be Used
Ethyl acetate 乙酸乙酯 20 - 22 + 110 Not to be Used
Ethanol 乙醇,酒精 20 - 5 + 7 Good
Glycol 乙二醇 20 - 1 0 Good
Glycerine 丙三醇,甘油 100 - 1 0 Good
Isopentanol 异戊醇 132 - 46 + 155 Not to be Used
Isopropanol 异丙醇 20 - 14 + 24 Good
Methanol 甲醇 65 - 4 + 3 Good
Methyl ethyl ketone 丁酮 80 - 24 + 102 Not to be Used
Methylene dichloride 二氯甲烷 20 - 22 + 154 Not to be Used
Petroleum ether 石油醚 20 - 25 + 244 Not to be Used
Stearic acid 硬脂酸 150 + 21 - 4 Can be Used
Tetrahydrofuran 四氢呋喃 65 - 28 + 218 Not to be Used
Benzine 90/100 轻质汽油 20 - 24 + 239 Not to be Used
Cyclohexane 环己胺 20 - 26 + 233 Not to be Used
Hexane 正己烷 20 - 23 + 239 Not to be Used
Styrene 苯乙烯 20 - 21 + 90 Not to be Used
Toluene 甲苯 20 - 24 + 179 Not to be Used
Xylene 二甲苯 20 - 24 + 170 Not to be Used
Brake fluid 制动液 100 - 2 + 3 Good
Diesel oil 柴油 20 - 22 + 90 Not to be Used
Gear oil SAE 90 齿轮油 150 - 1 + 3 Can be Used
Linseed oil 亚麻仁油 100 - 2 - 1 Can be Used
Mineral oil at ASTM 1 矿物油 150 - 4 + 4 Good
Mineral oil at ASTM 2 矿物油 150 - 7 + 9 Restricted Use
Mineral oil at ASTM 3 矿物油 150 - 42 + 41 Not to be Used
Mineral oil SAE 20 矿物油 150 - 23 + 22 Can be Used
Olive oil 橄榄油 100 - 2 0 Good
Silicone oil AK 350 硅树脂油 150 - 13 + 25 Not to be Used
Turpentine 松脂,松节油 20 - 27 + 195 Not to be Used
Coconut oil 椰子油 100 - 3 + 3 Good
Ball bearing oil 滚珠轴承油 150 - 18 + 20 Restricted Use
Margarine 人造黄油 100 - 2 0 Good
Vaseline 凡士林 150 - 9 + 15 Restricted Use
全部回复(37 )
只看楼主 我来说两句1、瑞好曝气管技术参数表
项 目 单 位 特 性
设备名称 硅胶膜微孔曝气管
硅橡胶膜直径 mm 67
硅橡胶膜厚度 mm 1.5
支撑管直径 mm 63
膜开孔面积 m2/m曝气管 0.15
膜片使用寿命 年 >8
气泡直径 mm ≤2.0
性 能
动力效率(3.6m深及30%密度) KgO2/kW.h 7
氧利用率(3.6m深及30%密度) % 29
通气量(标准态) m3/h.m曝气管 8
通气量范围 m3/h.m曝气管 2~12
阻力损失 KPa 3.3~6.7
2、RAU-SIK8360硅橡胶膜的性能参数:
项 目 标 准 单 位 数 值
硬度 DIN 53505 Shore A 60±5
密度 DIN 53479 g/cm3 1.19±0.02
抗压强度 DIN 53504 SII N/mm2 > 9
伸长率 DIN 53504 SII % > 450
撕裂强度 ASTM-D624B N/mm > 45 温度℃
-60~+200
3、支撑管采用抗腐蚀及耐高温的聚丙烯制成。
4、卡箍材质为ss304/ss316不锈钢
第二部分
瑞好RAUBIOXON硅橡胶膜微孔曝气管材质特点
1.RAUBIOXON曝气管由耐腐蚀、耐老化能力极强的材质所构成:
曝气膜:硅橡胶膜
支撑管:PP聚丙烯
2.硅橡胶膜的优点:
a、高弹性
b、不含增塑剂
c、不会变脆
d、与沉积物亲和力小
e、高耐高性 f、很强的抗化学腐蚀能力
g、高抗油性
h、不可生物降解
i、可循环利用
j、与EPDM微孔膜相比,硅橡胶膜对工业废水处理有更强的适用性
第三部分
瑞好硅橡胶膜曝气管的适用范围
Test Medium 测试
(℃) A (Points)
第四部分
EPDM(通常为黑色)材质局限性
1.由于所含增塑剂易在污水中流失,造成膜变脆变硬现象;
2.极易积垢,堵塞微气孔;
3.与硅橡胶相比,抗化学腐蚀及油脂污染性能差;
4.硅橡胶微孔膜能用甲酸进行化学清洗或用高压清洗设备进行机械清洗;
5. 与硅橡胶膜相比,抗化学腐蚀能力及耐老化能力要小得多;
6. 硅橡胶膜在正常情况下可使用8年以上,而EPDM膜在正常情况使用下3至5年。
7.很重要的一点:在两种新产品刚刚开始使用时,EPDM橡胶膜的氧转移率甚至比硅
橡胶的还要高,可是三个月至一年后随着其中的增塑剂的流失,橡胶膜慢慢将失去弹
性,微孔张合将慢慢停止,变脆,堵塞。阻力损失会越来越高。最后导致爆膜。
第五部分
运行对比
1.实际数据测试结果
德国某污水处理厂测试结果
硅橡胶膜微孔曝气管与EPDM曝气管的运行对比:
风机的功率: 4 x 6 kW = 24 kw
保证水中同样的溶解氧浓度时,风机的工作量:
RAUBIOXON 8次x 66分钟/天
EPDM 8次x 78分钟/天
所节省的能源:每天少运行96 分钟
每天节省能源:38.40千瓦时
每年节省能源:14,000.00 千瓦时
2.具体分析
清水中标准动力效率:
瑞好硅橡胶膜:4.7kgO2/kw.h
EPDM膜:4.0kgO2/kw.h
清水中的需氧量(安徽某项目标书要求):
2945x2=5890 kgO2/d
则风机平均功率为(按全天24小时计):
瑞好硅橡胶:5890÷4.7 = 1253 kw
EPDM:5890÷4.0 = 1473 kw
瑞好硅胶膜曝气管比EPDM胶膜管每天省:(1473-1253)x 24 = 5280 kw.h
每年省:5280 x 365 = 1927200 kW.h
第六部分
清洗方式
硅橡胶膜曝气管可以根据需要采用酸洗这种化学清洗方式及高压水这种机械清洗方
式;而EPDM由于膜与污水中化学物质发生化学变化,只能采用酸洗方式。
在通常情况下,硅橡胶膜曝气管至少能正常运行8年而不需更换;而EPDM通常2
年后就会产生不同程度的堵塞、压力损失增大等情况影响正常运行而导致更换。另
外硅橡胶膜曝气管的清洗周期也比EPDM长,维护保养容易。
硅橡胶膜与EPDM膜清洗前后压力损失对比。
第七部分
瑞好RAUBIOXON微孔曝气系统优点总结
1.RAUBIOXON微孔曝气系统可间歇运行,而不影响曝气管硅橡胶膜的密闭性能。
2.废水不会进入配气系统。
3.杂物不会进入膜孔。
4.很小的积垢倾向。
5.EPDM微孔膜曝气系统随着增塑剂流失会逐渐丧失密闭性能,并进而产生微孔堵塞。
6.RAUBIOXON微孔曝气系统有极高的传氧率(经德国Darmstadt技术大学Poepel教授测定鉴定)。
7.需要更少的空气通气总量。
8.更少的运行能耗。
9.在既定空气总量条件下,可少用曝气管以节省投资。
10.RAUBIOXON微孔曝气系统使用经济,投资可在短期内回收(BOT项目)。
11.RAUBIOXON微孔曝气系统由于其具有弹性恢复力而不受水压影响。
12.RAUBIOXON硅橡胶微孔曝气系统因其微孔分布结构可防止曝气管底积泥。
13.RAUBIOXON硅橡胶微孔曝气系统可用于现有系统改造。
14.RAUBIOXON硅橡胶微孔曝气系统易于安装,安装费用低。
15.RAUBIOXON硅橡胶微孔曝气系统清洗简单,在清洗后能迅速的大幅度恢复性能。
瑞好硅橡胶膜曝气管国内部分业绩
中国唐山市新区污水处理厂
日处理量:33000 m3/day
工程概况:改建工程中采用RAUBIOXON硅橡胶膜管式曝气器代替原有曝气管
投入运行时间:2000/2001
中国四川攀钢焦化废水/绵阳太极制药废水工业废水处理
日处理量:6000m3/day
工程概况:新建工程中采用RAUBIOXON硅橡胶膜管式曝气器
投入运行时间:2001/2002
中国南通市合成材料厂/常熟污水处理厂/南京印染厂废水处理
日处理量:30000 m3/day
投入运行时间:2001/2002
中国南通新区污水厂/江阴工业园污水厂市政污水处理
日处理量:40000 m3/day
投入运行时间:2003
中国大连医院污水/农药化工废水/水产废水/废水处理站
日处理量:20000 m3/day
投入运行时间:2002/2003
中国温州/江阴皮革污水厂工业废水处理
日处理量:m3/day
投入运行时间:2002/2003
中国徐州市荆马河污水处理厂/郑州太古可口可乐/武汉可口可乐工业废水/衡阳城西污水处理厂/纽莱制药厂/广东顺德伦教污水处理厂/顺德科技工业园污水处理厂两万吨工业废水/中山市污水处理厂等等
联系人:武汉奥威斯环保科技有限公司 张帅伟先生
Tel/Fax:15802025858 13037155588
日处理量:100000 m3/day
投入运行时间:2003/2004
1、需要更少的供气管及空气分配管,相比大大降低了故障率;
2、高性能, 低安装费用, 长期运行成本低;
3、空气分配管所需的钻孔和螺纹接头减少;
4、处理池底部所需的钻孔和锚固接头减少;
5、单位服务面积投资费用省;
6、空气阻力减小,减少能耗。
需氧量 = 200 kgO2/h(污水总需氧量)
空气量 = 3.200 Nm3/h(污水总通气量)
REHAU硅橡胶膜微孔管式曝气器
与普通EPDM橡胶管式曝气器的性能比较
REHAU硅橡胶膜微孔管式曝气器由耐腐蚀、耐老化能力极强的材质所构成:
曝气膜:RAU-SIK硅橡胶膜 (其他曝气管:EPDM)
支撑管:PP聚丙烯 (其他曝气管:UPVC)
硅橡胶膜的优点:
高弹性
不含增塑剂
不会变脆
与沉积物亲和力小
高耐温性
高抗化学腐蚀能力
高抗油性
不可生物降解
可循环利用
EPDM材料膜的缺点:
含增塑剂,由于增塑剂易在污水中流失,造成膜收缩。
经过一段时间在污水中运行后,EPDM膜会变硬变脆。
易受污水中沉积物的影响,造成微孔堵塞。
与硅橡胶膜材料相比,EPDM膜抗化学腐蚀能力及耐老化能力要小得多。
硅橡胶膜曝气管可以采用高压水清洗方式;而EPDM膜由于其材料会与污水中的化学物质发生化学变化,只能采用酸洗方式,系统复杂,危险性高。
在通常情况下,硅橡胶膜曝气管至少能正常运行6年而无需更换;而EPDM膜通常2年后就会产生堵塞、压力损失增大等情况影响正常运行而不得不更新或清洗。
运行对比
1.实际数据测试结果
德国某污水处理厂测试结果
EPDM 8次x 78分钟/天
所节省的能源:每天少运行96 分钟
每天节省能源:38.40千瓦时
2.具体分析
清水中标准动力效率:
瑞好硅橡胶膜:4.7kgO2/kw.h
EPDM膜:4.0kgO2/kw.h
清水中的需氧量(安徽某项目标书要求):
2945x2=5890 kgO2/d
则风机平均功率为(按全天24小时计):
武汉奥威斯环保科技有限公司/
简 介
武汉奥威斯环保科技有限公司是一家集销售、技术、服务与一体的专业性污水处理设备成套供应公司。自公司2001年成立以来,先后被德国、丹麦、意大利、台湾等国家和地区的著名厂商指定为总经销代理商。我公司所代理的产品,性能在国际同行业中遥遥领先,在污水处理行业中创下了累累硕果。我公司以技术为先导,以服务作后盾,在用户中建立了良好的信誉。欢迎各位精英来我公司指导参观。
武汉奥威斯环保科技有限公司将主导产品定位于:
1、韩国高速离心鼓风机 台湾龙铁longtech三叶罗茨鼓风机
2、 高效曝气系统设备-德国Rehau 硅橡胶膜曝气器
3、稳定可靠的污泥脱水系统设备-台湾Chi-shun带式污泥脱水机
武汉奥威斯环保科技有限公司自成立以来,在不断引进新产品、新技术的同时,还不断引进先进的管理理念和各类优秀人才,使企业的经营管理迈向科学化、成长走向理性化。 在形成强大销售网络的同时也为客户提供了健全可靠的售后服务网络体系。
经营理念:以技术为先导,以服务为后盾,为用户节省每一分钱
经营原则:技术先进 服务完善 诚信为本 客户至上
张帅伟 13037155588(武汉) 027-51860728 51860727
广州分公司15802025858(广州)020-83601867
http://www.alwayss.com
