距离会员到期还有30
建筑英语词汇(连载)
提问 发帖 回复
希望对大家有些作用! 同时希望能在工作之余记住几个单词。
  • 收藏0
  • 打赏0
分享至:
评论 文明留言,专业沟通
请先 登录,再评论!
全部评论
  • wych
    wych 2005年07月21日 12:16:26 33楼
    continuous barrier 连续护栏 continuous beam 连续梁 continuous covered elevated walkway system 直通有盖高架行人道系统 continuous covered walkway 直通有盖行人道 continuous footing 连续基脚;条形基础 continuous load 连续荷载 continuous protected walkway [safety measure in construction site] 连续的防护行走通道〔建筑地盘安全措施〕 contour 等高线;地势;地形 contour interval 等高距 contour line 等高线 contour walk 依地势建筑的小径 contract bill 承包标书 contract drawing 合约图纸;合约图则 contract for tenants’ works 核准承造住户装修工程合约 contract of tenancy 租赁合约 contraction crack 收缩裂缝 contraction fissure 收缩裂纹 contraction joint 收缩缝;收缩接缝 contractor 承建商;承办商;承包商 Contractor Confidential Review Committee 承建商机密检讨委员会 Contractor of the Year Award 承建商年奖 contractor shed 承建商屋棚 contractor yard 承建商工地 contractor’s entitlement to suspension of work 承建商享有停工的权利 contractor’s equipment 承建商的设备 contractor’s general responsibility 承建商的一般责任 contractor’s matshed 建筑地盘的棚屋 contractor’s method of valuation 成本估价法 Contractors Performance Review Committee 承建商表现检讨小组委员会 contractors’ register 承建商名册 Contractors Registration Committee 承建商注册事务委员会 contractor’s representative 承建商代表 contractor’s superintendence 承建商监督 contractual tenancy 合约下的租赁;合约租赁 contractual term 合约租期 contravention of lease conditions 抵触租契条件 control list 监察清单 control of access 通路入口管制 control of rent increase 加租管制 control panel 控制板;控制电箱;控制盘 control plan 规划大纲图;基本蓝图 control traverse diagram 导线测量控制图 controlled area 管制区 controlled blasting 控制式爆破;定控爆破 controlled parking zone 停放车辆管制区 controlled premises 受管制楼宇 controlled rent 受管制 金 controlled tenancy 受管制租住权 Convention Between Great Britain and China Respecting an Extension of Hong Kong Territory 《拓展香港界址专条》 conventional mortgage 传统按揭办法 conversion 改建 conversion works 改建工程 converted block 改建大厦 converted one-person flat [converted 1P flat] 改建一人单位 conveyance 转易契;业权转易;产权转易 conveyance formalities [Home Ownership Scheme] 购楼法律手续〔居者有其屋计划〕 conveyance on sale 售卖转易契 conveyance terms 转易契约的条款 conveyancing arrangement 业权转易安排;购楼法律手续 conveyancing cost 业权转易费用 conveyancing document 业权转易文件 conveyancing method 业权转易方法 conveyancing section [Lands Department] 田土转易组〔地政总署〕
    回复 举报 点赞
  • wych
    wych 2005年07月21日 12:16:50 34楼
    cooked food centre 熟食中心 cooked food stall 熟食档位 cooking bench 灶台;“ ” cooking range 灶头 cooling system 散热系统;冷却系统 Co-operative Building Society 建屋合作社 cooperative housing 合作建屋计划楼宇 Co-operative Housing Scheme 合作建屋计划 co-ordinate data 坐标数据 Co-ordinating Committee on Potentially Hazardous Installations 潜在危险设施土地使用策划和管制协调委员会 Co-ordinating Committee on Street Sleepers 露宿者统筹委员会 co-owner 共同业主;业权共有人;共同拥有人 co-ownership 共同业权;共同拥有物业权;共有业权 copal-oak varnish “谷巴”树脂光漆;“谷巴光油” coparcener 共同继承人 coping 盖顶〔墙或栏〕;墙帽;栏顶 coping stone 盖顶石;墩台石 copper tube 铜管 corbel 梁托;翅托;托架 cordon lantern 作界线用的路灯 core 土芯;岩芯 core barrel 岩芯钻管 core data bank 土芯样本资料库 core diameter 土芯直径;岩芯直径 core district 核心地区 core drilling 取芯钻探;钻取土芯;钻取岩芯 core facility 核心设施 core objective 核心目标 core of the breakwater 防波堤堤心 core penetration test 样芯贯入度测试 core recovery 岩芯回收率;岩芯采取率 core sample 土芯样本;岩芯样本 corehole 钻孔 coring 钻取土芯;钻取岩芯 coring programme 土芯钻取计划 cork board 软木板 corner site 街角地盘 cornice 飞檐 corporate landlord 机构业主 corporate tenancy 机构租赁;法人租赁 corporate tenant 机构租客 corrected area weighting 修正面积比重 corrective maintenance 更正维修;故障维修 correlated boundary 并图地界 correlated sheet [map] 合并地图 corridor 走廊 corrosion of the reinforcing steel 钢筋 蚀 corrosion protection 锈蚀防护 corrosion resistance 耐蚀性 corrosion-resistant material 防蚀物料 corrugated asbestos canopy 波纹石棉瓦檐篷 corrugated barrier fence rail 波浪式护栏横档 corrugated sheet 波纹薄板;“坑板” corrugation grinding machine 波纹研磨机 Corruption Prevention Guide on Building Management for Owners’ Corporations 《楼宇管理秘笈》 cosmetic treatment 美化工程 cost of remedying defects 建筑缺陷修补费;建筑瑕疵修补费 cost rent 成本租金 co-tenant [public housing estate] 共住租客〔公共屋 〕 cottage 平房;小屋;村舍 cottage area 平房区;寮屋区 Cottage Resettlement Area 寮屋徙置区 cotton rag 碎棉布 Council of the Hong Kong Institute of Architects 香港建筑师学会理事会 Council on Squatter Policy 木屋政策评议会 counter collection service 柜台收租服务 counter conveyancing service 物业转易手续柜台服务 Counter Notice 反对迁出通知书 counter shop 柜台铺位 counterfort drain 排水扶垛 counterfort retaining wall 扶壁式挡土墙 countersunk head screw 埋头螺钉;“埋头螺丝” countersunk screw 埋头螺钉 counterweight 对重装置;平衡锤辘;“坠铊” coupled shear wall 并联剪力墙 coupling beam 并联梁 coupling flange 联结凸缘 coupling joint 联轴接头 course 层〔砖石砌体〕 courtyard 天阶;庭院 cove 凹圆〔线脚〕 coved edge 凹圆边 coved tile 凹圆瓦 covenantee 契诺受益人 covenantor 契诺承诺人 covenants, clauses and provisos 契约、条款及但书 cover layer 覆盖层 cover tile 盖瓦 coverage 上盖面积;室内面积 coverage area 上盖面积 coverage scale 上盖面积比例;覆盖率 covered area 有盖面积;有盖地方;室内面积 covered channel 有盖排水渠;暗渠;暗槽 covered drain 暗渠 covered floor area 有盖楼面面积 covered footbridge 有盖行人天桥 covered nullah 大型暗渠;暗置大渠 covered pedestrian walkway 有盖行人道 covered
    回复 举报 点赞
  • wych
    wych 2005年07月21日 12:17:12 35楼
    cradle 承船架;托架;吊篮 crane 起重机;吊机 crane tower 起重机塔 crank pin bearing 曲柄销承 crank shaft 曲柄转轴 creation of easement 设定地役权 credit in waiting time 获缩短的轮候时间 credit value [Letter B] 面值〔乙种换地权益书〕 creep [concrete] 蠕变;徐变〔混凝土〕 creep limit 蠕变极限 creep load 蠕变荷载 creep rupture 蠕变断裂 creep settlement 蠕变沉降 creep strain 蠕动应变 creep strength 蠕变强度 creeping speed 蠕变速度 crematorium 火葬场 creosote 木材防腐剂;杂酚油;木馏油 crest level 堤顶高程;顶高程 crib wall 网格式墙 Crisis Communications Centre [Civil Engineering Department] 危机通信中心〔土木工程署〕 critical building 情况严重楼宇 critical element 主要元件;临界构件 critical flow velocity 临界流速 critical load 临界荷载 critical loaded structure member 受力最重的楼宇构件 critical path analysis 要径分析;要径分析法 critical slope angle 最大安全斜坡角度 critical stress 临界应力 critical surface 临界面 critical transverse wind loading 楼宇抵受横向风力的临界载重 crop compensation 青苗补偿;农作物补偿 crop compensation allowance 青苗补偿津贴;农作物补偿津贴 cross bar area [H block] 横廊〔工字型大厦〕 cross beam 横梁 cross district search service [Land Registry] 跨区查册服务〔土地注册处〕 cross district transfer 越区调迁 cross grain 横纹 cross head 十字头;丁字头 cross road duct 横越道路管道;“过路筒” cross section 横截面;横切面 cross sectional area 横截面面积;横切面面积 cross tie 横木 cross ventilation 对流通风 cross-boundary infrastructure project 跨界建设项目 cross-district search 跨越地区查册 crossfall 横斜度 cross-flow force 水流横向力 cross-harbour utility reserve area 水电设施的海底专用范围 cross-sectional area 横切面面积 cross-shaped block 十字型大厦 cross-village small house application 越村小型屋宇申请;外丁提出小型屋宇申请 crowd loading 集束荷载 crown 路拱;拱顶 Crown lessee 官地承租人;官地承批人 crucible 坩埚 cruciform block 十字型大厦 crushed rock 碎石 crushed stone 碎石 crusher 碎石机 crushing and screening plants 轧筛机 crushing strength 压碎强度 crystal oscillator 晶体振荡器 cube test [concrete] 方块测试〔混凝土〕 cubicle 房;小间 cul-de-sac 尽头路;死巷 cultivation 松土;翻土 cultivation area 耕地范围 cultural use 文教用途 culvert 暗渠;涵洞;排水渠 culvert bridge 桥式暗渠 cumulative impact monitoring 累积影响监察 cumulative stock 累积单位数目 curing time [concrete] 养护期〔混凝土〕 currency value of Letter A/B 甲/乙种换地权益书币值 current demand [electricity] 电流需求量 current limiter 限流器 current market rent 现行市值租金 current measurement [water] 水流量度 current practice 现行方法 current rent 现行租金 current tenancy 现行租赁 current value 目前的市价 current-carrying capacity 载流量 current-carrying conductor 载流导体 curtailment [reinforcement] 长度不足〔钢筋〕 curtain grouting 帷幕灌浆 curtain wall 幕墙;玻璃幕墙 curtain wall support 幕墙承托物 curve 路弯;弯位 cushion 垫层;桩垫 cushioning material 垫承物料 custodian of enemy property 敌产保管人 custodian of property 财产保管人 custody of drawings and documents 图则及文件的保管权;保管图则文件 Customer Service Assistant Scheme 住户服务助理计划 cut and fill 随挖随填 cut slope 削土斜坡;削切斜坡 cut-and-cover method 明挖回填法 cut-and-fill design 挖填设计<
    回复 举报 点赞
  • wych
    wych 2005年07月21日 12:17:37 36楼
    dado 墙裙;护壁;“傍水” daily letting return 每日出租报表 damages for non-completion 未能竣工损害赔偿;未能完工损害赔偿 damp proof course 防潮层 damp proof membrane 防潮表层 damper 气闸;调节风门;减震器 dangerous building 危楼;危险建筑物 dangerous goods store 危险品仓库 Dangerous Hillside Notice 危险斜坡通知书 Dangerous Hillside Order 危险斜坡修葺令 dangerous slope 危险斜坡 Dangerous Structure Removal Notice 拆除危险构筑物通知书 dangerous terrain 危险地势 date for possession [site] 接管日期〔地盘〕 date of agreement [agreement for sale and purchase] 协议日期〔买卖合约〕 date of assignment 转让契约日期 date of first assignment 单位首次售出日期 date of instruction 买卖通知书日期 date of possession 管有日期 datum 基准;基准面 datum location 基准地点 datum mark 基准记号 datum plane 基准面 datum station 基准站 "dau chung" 斗种〔计算新界农地面积的传统单位〕 daywork rate 日工单价;计日工作单价 D-day 最后迁出期限〔扩展重建计划〕;清拆日期〔清拆小贩摊档〕 dead bolt 固定栓 dead end [drainage] 死端;封闭尽处〔渠道〕 dead load 恒载;静荷载 dead shore 顶撑 dead-load test 恒载试验;静荷载试验 deadlock 单栓锁;单闩锁 debris 泥石;岩屑;瓦砾 debris flow 泥石流;岩屑流 debris flow deposit 泥石流形成的坡积物 decantation 迁移;调迁 deck 面板;桥面;平台 decked nullah 铺面渠 declaration of the valuation lists 公布差饷估价册 decomposed granite 风化花岗岩 decomposed granite soil 风化花岗岩土壤 decomposed rock 风化岩 decomposed volcanic rock 风化火山岩 decompression 减压;卸荷 decontrol of rent 解除租金管制 decoration 装修;装饰 Decoration Handbook 《装修手册》 decorative finish 饰面 decorative lighting 装饰照明 de-designation 撤销指定乡村区 dedication of land 拨地 deed 契据;契约 deed of appropriation 拨地契据 deed of assignment 转让契据 deed of assignment in escrow 等候履行条件的转让契据 deed of covenant 契约 deed of equitable mortgage 衡平法上的按揭契据 deed of exchange 交换契 deed of family arrangement 家庭协议证明书 deed of gift 送让契 deed of grant 批地契据;批约 deed of mutual covenant 公契;公共契约 Deed of Mutual Covenant and Management Agreement Clause 公契及管理协议条款 deed of partition 分产契 deed of reassignment 赎回契据 deed of rectification 修正契据 deed of release 解除扣押契据;解除责任契据 deed of surrender 放弃租住权契据〔租约〕;土地交还契据 deed of variation 契据修订书 deed poll 分割契据;单边契据 deed register 契据登记册 deed registration system 契据登记制度
    回复 举报 点赞
  • wych
    wych 2005年07月21日 12:18:29 37楼
    deep bore well pump 深钻井泵 deep compaction 深层压实 deep cut 深挖 deep foundation 深层基础;深层地基 deep groove 深槽 deep piling 深层打桩法 deep rotational failure 深圆弧滑动破坏 deep seal 深层密封 deep sewage collection tunnel 深浚污水收集隧道 deep trench excavation 深沟挖掘;深沟开挖 deep tunnel intercepting sewer system 地下深层污水截流系统 deep vibration compaction 深层振荡式压实 deep well water pump 深井水泵 deeply weathered 深层风化;深度风化 defaulting tenant 欠租租客 defect 建筑缺陷;建筑瑕疵 defective block 问题公屋;有建筑缺陷的大厦 defective building 欠妥的建筑物 defective material 有损坏的物料;有问题的物料;不合规格的物料 defective slope 有问题的斜坡 defective title 有问题的业权 defective works 有缺陷的工程;不合规格的工程 defects and deficiencies [works] 错漏〔工程〕 defects liability certificate 保养证明书;保修证明书 defects liability period 保养期;保修期;维修责任期 defects monitoring centre 楼宇问题监察中心 defects report 楼宇损坏报告 defence estate 军用房屋土地 defence land 防务用地;军事用地 defence land agreement 军事用地协议 defence lot 国防地段 deferment 押后;推迟;递延项目 deferral 押后;推迟;递延项目 deferred mortgage arrangement 延缓按揭安排 deferred possession area 延迟移交区 deferred tax 递延税项 defined area 划定地区 definitive map 精确地图 definitive zoning 划定用途 deflection 挠度;变位 deflection curve 挠度曲线 degree of consolidation 固结度 degree of corrosion 蚀程度 degree of exposure 日照程度 degree of sharing 同屋共住户数 dehumidifier 抽湿机 dehydrogenation tank 脱氢缸 delamination of concrete cover 混凝土保护层层状剥落 delayed works 工程延误 Deletion Certificate 取消差饷估价证明书 delinquent report 转帐失误欠租报表 deliver up possession 交回管有权 deliver up vacant possession 腾空交回管有权 deluge system 密集洒水系统;集水花洒系统 Demand for Rates 征收差饷通知书 demand note 缴款通知书;缴款单 Demand Side Management Programme [electricity supply] 用电需求管理计划 demarcation district [D.D.] 丈量约份;约 demarcation district lot 丈量约份地段 demarcation district plan 丈量约份图则 demarcation district sheet 丈量约份地图 demise 批租;转管 demise charterer 转管租约承租人 demographic trend 人口统计动向 demolish 拆卸 demolition action 清拆行动 demolition order 拆卸楼宇令 demolition team 清拆工作队 demolition works 拆卸工程 density of soil 土壤密度 Density Zone Table 发展密度分区表 density zoning 发展密度分区制 density zoning policy 发展密度分区政策 densometer 密度计;比重计 dentition [rock slope] 补隙〔石坡〕 denudation 剥蚀作用
    回复 举报 点赞
  • wych
    wych 2005年07月21日 12:19:14 38楼
    dependent domestic premises 非独立住宅楼宇 deposit 沉积物;淤积物 deposit of plan 存放图则 depot 车厂;仓库;车站 depreciated current replacement cost 折旧后现行重置成本 depreciated replacement cost 折旧后重置成本 depth gauge 深度规;深度计 depth of carbonation 碳化深度 depth of cover to reinforcement 钢筋在混凝土的深度 derelict area 荒废地区;荒废地 derelict land 荒废地 derivative landlord 转接业主;居于别址的二房东 derived plan 衍引地图 derrick barge 浮式起重机 derrick crane 人字起重机;“三星架” descri ption of property 产业地址;物业名称 design and build contract 设计连施工合约〔房屋署〕;设计及营造合约 〔工务局〕 Design and Build Sub-committee [Contracts Committee of the Construction Advisory Board] 设计及建造事宜小组委员会〔建造业谘询委员会合约条款委员会〕 design and construction 设计及施工 design and disposition 设计及规划 design assumption 设计假定 design calculation 设计计算书;设计计算资料 design code 设计守则;设计规范 design criterion 设计准则 design, disposition and height clause [DD&H clause] 设计、规划及高度条款〔地政总署〕;建筑物的设计形式、布局及高度条款〔房屋署〕 design drawing 设计图;设计图纸 design earth pressure 设计土压力 design feasibility test 设计可行性测试 Design Guide for Commercial Centres 《商场设计指南》 Design Guide for Common Facilities [estate facilities] 《共用设施设计指南》〔屋 设施〕 Design Guide for External Works [estate facilities] 《外部工程设计指南》〔屋 设施〕 Design Guide for Miscellaneous Standards [estate facilities] 《杂项标准设计指南》〔屋 设施〕 design life 设计使用期;设计使用年限 design link 设计上的衔接 design load 设计载重;设计荷载 design mix 配料设计;设计成分 design parameter 设计规范;设计规限 design population 计划人口;预定人口;预计人口 design pressure 设计压力 design requirement 设计上的规定 design safety factor 设计安全系数 design specifications 设计规格 design speed 设计速度 design strength 设计强度 design stress 设计应力 designated area 指定地区 designated development 指定发展 designated occupier 指定占用人 designated public area 指定公众地方 designated trade 指定行业 designated use 指定用途 designated village area 指定乡村区 designated water level 设定水位 designed maximum capacity [water supply] 设计的最高供水量 designed mix concrete 设定配合比的混凝土 designed supply capacity [water supply] 设计供水量 desilting manhole 隔沙沙井 desilting material 疏浚物料 desilting sand pit 隔沙池;隔沙井 desilting sand trap 隔沙池;隔沙井 desire line 交通需求线 desire line diagram 交通需求线图 destuffing 拆装 detached building 独立建筑物;独立式楼宇 detached private residence 独立式私人住宅 detail working drawing 施工详图 detailed design 设计详图;详细设计 Detailed Design Review Panel 设计详图检讨小组 detailed design stage 详细设计阶段 detailed drawing 详图;细节图;明细图;“大样图” detailed geotechnical investigation 岩土工程详细勘察;岩土工程详细勘探 detailed geotechnical stability study 详细岩土稳定性研究 detailed planning proposal 详细规划建议 detailed survey 碎部测量 deterioration of reinforcement 钢筋损蚀 determination of lease 终止契约;解除契约 determination of tenancy 终止租赁;解除租约 determined Government rent 已厘定的地税 detonating fuse 导爆索 detonating relay 导爆索接驳器 detonator 雷管 devalued at... 按……折算 devegetation 除草;去芜 development area 拓展区;发展区 development clearance 发
    回复 举报 点赞
  • wych
    wych 2005年07月21日 12:19:39 39楼
    dial gauge 千分表 diaphragm 横隔板;横隔梁;膜片 diaphragm plate 横隔板 diaphragm wall 截水墙;隔墙;地下连续墙 diazo film 重氮晒图;晒蓝图 diesel hammer 柴油打桩机;“油渣锤” Differential Global Positioning System [DGPS] 差位全球定位系统 differential settlement 不均匀沉降;不规则沉降;沉降差 difficult ground 问题地区;特殊土地区 digital echo sounder 数码回声测深仪 digital map 数码地图 digital map data 数码地图数据 digital mapping 数码绘图 digital photogrammmetric workstation 数码摄影测量工作站系统 digital terrain model 数码地形模型 digital vibration meter 数字振动计 digitization of a map 把地图上的资料转为数码 dike 堤;岩墙;岩脉 dilapidation 破旧;失修 diluvial fan 洪积扇 diluvial soil 洪积土 dim transformer 光暗变压器 dimension survey 尺寸测量 dimensional tolerance 尺寸公差 dimensioned location 用尺寸标明的位置 dimensioned plan 度量图 dimmer 光暗掣 diorite 闪长岩 dip 倾角 dip angle 倾角 dip direction 倾向 dip gauge 垂度规 dip meter [groundwater] 地下水位测量仪 direct access 直达通道;直接通道 Direct Access Services [Land Registry] 直接查册服务〔土地注册处〕 direct allocation system 直接编配方法 direct catchment area 直接集水区 direct contractor 直接承建商;直接承办商;直接承包商 direct feed 直接供水 direct shear equipment 直剪仪 direct shear test 直剪试验 direct upfront subsidy 直接现金补助 Director of Architectural Services 建筑署署长 Director of Buildings 屋宇署署长 Director of Civil Engineering 土木工程署署长 Director of Drainage Services 渠务署署长 Director of Housing 房屋署署长 Director of Lands 地政总署署长 Director of Territory Development 拓展署署长 discharge of mortgage 撤销按揭;解除按揭 discharge point [garbage] 送运站〔垃圾〕 discharge value 流通量;排放量 Disciplinary Committee [Estate Agents Authority] 纪律委员会〔地产代理监管局〕 disconnecting trap 气隔弯管;存水气隔弯管 discount rate 折扣率;扣减率 discount to market value 比对市值的折扣〔市值折扣〕;按市值折减 discounted price 折扣价 dish channel 碟渠 dish drainage channel 碟形排水渠 dismantle 拆卸;拆除 dismissal of contractor’s employees 解雇承建商雇员;解雇承办商雇员 dispersed structure 分散结构 displacement 排水量;位移 displacement pile 送入桩 disposable land 可供批拨的土地 disposal 批地;卖地 disposal dump 垃圾倾卸站 disposal site 卸泥场 disposition [building] 配置〔建筑物〕 disposition of property 产权处置 dispossessed 被逼迁 dissolution feature [rock] 岩溶现象〔岩石〕 distance gauge 测距规 distemper 色胶涂料 distinct branch of family group 明显分支家庭 distortion settlement 扭曲沉降 distress for rent 欠租扣押 distributed load 分布荷载;分布载重 distribution board 配电箱 distribution box 接线盒;配电箱 distribution main [water supply] 总配水管 distribution panel 配电盘;配电板;配电屏 distribution pipe 配水管 distribution reinforcement 匀力钢筋;分布钢筋 District Building Management Co-ordination Team 分区大厦管理统筹小组 district centre 地区商场 district centre [Type A Commercial Centre] 地区商场〔甲类商场〕 District Clearance Co-ordinating Committee 地区清拆统筹委员会 District Lands Conference [DLC] 地区地政会议 district lands office [Lands Department] 分区地政处〔地政总署〕 District Lands Officer 地政专员 district maintenance office [Housing Department] 分区保养办事处〔房屋署〕 district open space 地区休憩用地;区内空地
    回复 举报 点赞
  • wych
    wych 2005年07月21日 12:20:04 40楼
    Document Imaging System [Land Registry] 文件影像处理系统〔土地注册处〕 document of title 契约文件;业权文件;所有权文件 doll house 室内间格模型 dolomite 白云岩 dolosse 防波石 dolphin line 柱墩线 dome 圆拱顶 dome grating 拱形格栅 domestic accommodation 住用设备 domestic block 住宅楼宇;住宅大厦 domestic building 住用建筑物 domestic car parking space 住宅楼宇停车位 domestic cottage 住宅平房 domestic floor 住宅楼层 domestic housing 住宅楼宇 Domestic Operating Account 住宅楼宇运作帐目 domestic premises 住宅处所;住宅楼宇;住宅单位 Domestic Property Ownership Rule 不得拥有住宅物业规定 Domestic Property Price Index 住宅物业价格指数 domestic removal allowance 住户搬迁津贴 domestic rent control 住宅租金管制 domestic rent policy 公屋租户租金政策 domestic rental market 住宅楼宇租赁市场 domestic storey 住宅楼层 domestic subcontract 自选分包合约 domestic subcontractor 自选分包商;自选次承建商 domestic subtenancy 住宅分租租赁 domestic tenancy 住宅租赁 domestic tenant 住宅租客;住宅租户 domestic use 住宅用途 domestic utility charges 住宅公用设施收费 domestic vacancy 空置住宅楼宇;空置住宅单位 door chain 防盗链 door closer 门掣;门气鼓 door frame 门框 door furniture 门配件 door gasket 门胶边 door handle 门把手 door head 门楣 door holder 门夹;门扣;门球 door jamb 边框;“企框” door leaf 门扉 door sill 门槛;门坎 door stop 门挡 door threshold 门槛 door viewer 防盗眼 door-phone 门口对讲机 door-telephone 门口对讲机 door-to-door rent collection system 登门收租办法 dormant crack 静止裂缝 dormitory town 居住性质的市镇 double cruciform block 双十字型大厦 double glaze 双层玻璃 double glazing glass 双层玻璃 double letting premises 两个单位合成一组出租的房舍;“ 房” double net rent 双倍净额租金 double permit system 双证制 double removal allowance 重复搬迁津贴 double rent 双倍租金 double rent payer 缴交双倍租金的租户 double rent policy 双倍租金政策 double seal 双重密封 double slab block 双长型大厦 double-action self-closing door 双向自动关闭的门 double-deck crossing 双层干线 double-H block 双工字型大厦 double-I block 双I型大厦 double-storey colonnade 双层高柱廊 doubleton 二人家庭 doubleton family 二人家庭 dovetail joint 鸠尾接;鱼尾榫;燕尾榫 dowel 暗钉;榫钉;销钉;定位销 dowel bar 接头插筋;传力杆;暗销杆 dowel joint 暗钉接合;榫钉接缝 dowel pile 榫桩;定位桩 dowelled 用榫钉连接;设传力杆的 down feed 下行供水管;“落水喉” down pipe 雨水管;“落水管” down ramp 下行坡道 downstream silencer 下游减音器 downward force 下向力 downzoned land 降低用途分区 downzoning 降低分区用途
    回复 举报 点赞
  • wych
    wych 2005年07月21日 12:20:32 41楼
    draft 吃水 draft amendment plan 修订草图 Draft Code of Practice for Demolition of Buildings 《建筑物拆卸作业守则拟稿》 draft outline zoning plan 分区计划大纲草图 draft plan 草图;草拟图 drag force 水流力;拖曳力 drain 排水渠;排水道 drain and sewer 沟渠 drain board 去水板 drain cock 排水旋塞;“清缸掣” drain hole 排水孔;去水孔 drain layer 铺渠工 drain pipe 排水管;排水渠 drain plug 排水塞 drain tube 排水管 drainage 排水;疏水;排水设施 drainage aggregate 疏水石 drainage alignment 渠道线向 drainage and health requirements for village type houses 乡村式屋宇的排水及卫生规定 Drainage Appeal Board Panel 土地排水事务上诉委员会 Drainage Authority 排水事务监督 Drainage Authority Area 排水监管区 drainage blanket 排水砂层;疏水层 drainage capacity 排水系统的去水能力 drainage chamber 排水沙井 drainage channel 排水渠;排水沟 drainage connection system 排水渠道接驳系统 drainage gallery 排水廊道 drainage impact assessment [DIA] 排水影响评估 drainage inlet 排水入口 drainage layer 排水层;疏水层 drainage line 水流线;排水路线 drainage manhole 排水沙井 Drainage Master Plan 雨水排放整体计划 Drainage Master Plan Studies 雨水排放整体计划研究 drainage material 排水物料;疏水物料 drainage measure 排水措施 drainage outlet 排水出口 drainage path 排水径 drainage pipe 排水管道 drainage plan 排水设施图 drainage proposal 排水系统建议书 drainage pump 排水泵 drainage reserve 渠务保留地;渠务专用范围 Drainage Services Department 渠务署 drainage strip 排水带 drainage sump 集水井;排水集水坑 drainage system 排水系统;渠道系统 drainage trench 排水渠坑道 drainage works 排水工程;渠务工程 drainer 去水板 drainer worktop 去水板兼工作台 drawdown [groundwater] 水位下降〔地下水〕 drawing and specification contract 图则规格合约;图纸及规范合约 drawing list 图则清单;图纸清单 Drawing Management System 建筑图则管理系统 Drawing Practice Manual 《实用绘图手册》 drawing section [Lands Department] 绘图组〔地政总署〕 draw-off tap 放水龙头 dredging of seabed 浚挖海 dredging works 疏浚工程;挖泥工程 drencher 喷淋器 drencher curtain 水帘 drencher head 喷淋头 drencher system 水帘系统 dressed block 细琢石块 drill and blast method 爆钻法 drill hole 钻孔 drill rod 钻杆 drilling 钻孔;钻取;钻探 drilling machine 钻孔机;钻机 drip 滴水槽;滴水线 driven cast-in-place pile 沉管灌注桩 driven pile 打入桩;入土桩 driven tunnel 入土隧道 driving analysis test on piles 试桩工程 driving cab 驾驶室 driving cap 桩帽 drop gate 横杆吊闸 dropped kerb 下斜路缘 dry construction 干建造法 dry fire main 干消防喉 dry pail latrine 旱厕 dry powder fire extinguisher 干粉灭火筒 dry riser 消防干上水喉 dry sieving 干筛 dry wall 预制墙板;预制墙 dry wall partition 干墙间隔 dryer 干燥机;干燥剂 drying area 晾晒处 drying ground 晾晒地 drying rack 晒衣架;晾衣架 drying shrinkage 干水收缩;干收缩 dry/wet pipeline 干湿喉管 dual lock 联动拉手;联动窗扣 dual temperature thermostat 双温恒温器 dual-scale system 双比例尺法 ductile iron 延性铁;韧性铁;球墨铸铁 ductile iron pipe 延性铁管;球墨铸铁管 ductile iron pipe with cement lining 水泥衬里延性铁管;水泥衬里球墨铸铁管 ducting works 管道敷设工程 duly stamped 已适当加盖厘印 dump 倾卸;卸泥;弃置废物 dump truck 泥头车 dumper 卸土车;卸土机;泥头车
    回复 举报 点赞
  • wych
    wych 2005年07月21日 12:21:02 42楼
    early redemption [Home Purchase Loan Scheme] 提早清还贷款〔自置居所贷款计划〕 early warning system 预早警告系统 earth 泥土;地线 earth bund 土堤 earth copper strap 接地铜织带 earth crust 地壳 earth electrode 接地极 earth embankment 土堤 earth fill 填方 earth grave 泥坟;土坟 earth leakage circuit-breaker 断路器;“水线跳掣” earth loop impedance test 接地阻抗测试 earth loop tester 地线系统测验器 earth mound 土丘;土墩 earth plate 接地板 earth pressure 土压力 earth pressure at rest 静止土压力 earth pressure distribution 土压力分布 earth rod 接地棒 earth science 地球科学 earth tag 接地片 earth tape 接地带 earthenware drain pipe 排水瓦管 earthenware pipe 瓦管;陶管 earthfill road embankment 填土路堤 earthfill slope 填土斜坡 earth-fixed co-ordinate system 地图坐标系统 earthing 接地 earthing cable 接地线 earthing lug 接地线耳 earthing system 接地系统 earthing terminal 接地终端 earth-moving machine 掘土机;动土机 earthquake engineering 地震工程 earthquake loading 地震荷载 earthquake proof construction 抗震工程;抗震建筑 earthquake proof foundation 抗震基础;抗震地基 earthquake proof joint 防震缝;防震接缝 earthquake resistance design 抗震设计 earth-retaining structure 挡土构筑物;护土结构 earth-retaining wall 挡土墙;护土墙 earthwork 土方工程 earthwork specifications 土方工程规格 easement 地役权;附属建筑物 easement in the land 地役 eaves 屋檐 eaves gutter 檐沟 eccentric load 偏心荷载 ecologically sensitive area 生态易受破坏地区 edge 边缘地带 edge beam 边梁 edging 镶边 effective area 实用面积 effective stress 有效应力 effective width 实用阔度 efficiency index of curing compound 养护药品的效率指标;保养药品的效率指标 effluent 污水;废水;流出物 effluent discharge 污水排放 effluent discharge pipe 污水排放管 effluent outfall 污水出口管;污水排放管 effluent treatment 污水处理 effluent tunnel 污水隧道 egress point 出口 ejectment 迫迁 ejectment of tenant 强迫租客离开 elastic beam 弹性梁 elastic deformation 弹性变形 elastic equilibrium 弹性平衡 elastic foundation 弹性基础;弹性地基 elastic settlement 弹性沉降 elastic support 弹性支座 Elderly Citizens Housing Scheme 长者住屋计划 Elderly Persons Priority Scheme 共享颐年优先配屋计划 electric steam boiler 电热式蒸汽锅炉 electric travelling crane 电动起重机 electrical contractor 电器承装商 electrical cut-off switch 电力截断掣 electrical distribution system 配电系统 electrical installation drawing 电气布置图 electrical installations [public works category] 电器装置〔公共工程类别〕 electrical plug 电插头 electrical point 电掣位 Electrical Reinforcement and Rewiring Programme 加强供电及重铺电力装置计划 electrical rising main system 垂直电力总线系统 electrical socket outlet 电源插座 electrical subcontractor 电业分包商;电气装置分包商 electrical supplier 供电商 electrical technician 电力工程技术员 electrical term maintenance contract 电力工程定期维修合约 electrical transformer room 电力变压房 electrical wiring 电气布线 electrical works 电气工程 electrician 电业工匠;电工 electricity cable 供电电缆 electricity meter box 电表箱 electronic distance measurement 电子测距法 electronic map 电子地图 electronic tilt sensor 电子测倾器 electro-thermal damper 电热防火闸 element in distress 元件超负荷 element of constructio
    回复 举报 点赞
加载更多资料
TA的关注
相关标签
上传
上传
请选择删除原因
