土木在线论坛 \ 人才招聘 \ 学生专栏 \ 土木毕业设计外文翻译中英对照版~~吐血共享!!!
发布于:2008-03-24 11:49:24 来自:人才招聘/学生专栏 [复制转发]
Tall Building Structure
Abstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
全部回复(158 )
  • qq_1427598874725
    楼主好人!!!希望来一份中英文都有的!多谢多谢!急用! 509081940@qq.com
    2015-03-29 11:21:29
  • lx3913
    lx3913 板凳
    直接发中文版的嘛,省得我翻译。、
    2012-03-22 22:22:22
学生专栏
23.92 万条内容 · 127 人订阅
高层建筑结构摘要:本文主要讲述了高层建筑。包括剪力墙结构,框架结构,筒状结构。通过对高层建筑中最普通的结构形式的分析,得出在设计过程中,应尽可能经济实用地选择合理的形式。关键词: 高层 结构 荷载 ⒈前言人类从文明社会的开始就向往着高楼大厦,最初建造的高大建筑是为了防御侵略,随后发展到教会建筑。现在高层建筑始于十九世纪八十年代,主要用于商业和住宅,但是高层建筑并没有明确的定义,可以说2~3层的建筑物为底层建筑,而从3~4层到10层或20层的建筑物为中层建筑,高层建筑至少为10层或者更多。
