地面隔音砂浆 墙面隔音涂料 楼板隔音 房屋隔声 华阳绿建
住宅建筑项目周边的交通噪声、社会噪声、城市旧城改造、新型开发区建设、地铁轨道交通建设等产生的施工噪声污染及住宅建筑内的各项机械设备的应用,都给人生活造成极大困扰。这时候房屋隔音就显得尤为重要。
The traffic noise, social noise, urban old city reconstruction, new development zone construction, metro rail transit construction and other construction noise pollution around residential construction projects, as well as the application of various mechanical equipment in residential buildings, have caused great trouble to people's lives. At this time, the sound insulation of the house is particularly important.
华阳HY-F1减振隔音砂浆
HY-F1减振隔音砂浆主要是由硅胶盐水泥、石英砂以及天然环保型弹性阻尼材料、表面活性剂与外加剂组合而成的预混干粉砂浆。减振隔音砂浆中的阻尼材料调整了刚性模量,增大机械能转化为热能的转化率而减弱高频传输,从而达到良好的隔声效果。HY-F1减振隔音砂浆是改善楼板撞击声的新型环保材料。经清华大学建筑物理环境检测中心检测,采用HY-F1隔音砂浆,能达到国家健康住宅墙体隔音标准。
Huayang hy-f1 damping and sound insulation mortar
Hy-f1 vibration damping and sound insulation mortar is mainly composed of silica gel salt cement, quartz sand, natural environment-friendly elastic damping material, surfactant and additives. The damping material in the vibration and sound insulation mortar adjusts the rigidity modulus, increases the conversion rate of mechanical energy into heat energy and weakens the high frequency transmission, so as to achieve good sound insulation effect. Hy-f1 damping and sound insulation mortar is a new environmental protection material to improve the impact sound of floor. According to the test of Tsinghua University building physical environment testing center, hy-f1 sound insulation mortar can meet the national standard for sound insulation of healthy residential walls.
华阳绿建HY-T1隔音涂料
华阳HY-T1隔音涂料是经多年研究开发而成的,是目前世界上隔音性能最好一种水溶性隔音阻尼高性能的隔音涂料.涂料的隔音降噪效果取决于其损耗因子,形成阻尼约束结构,当声音撞击开始发出声音及振动时,隔音阻尼涂料会形成一种阻尼保护层增加管道密度,有效将声波的机械能转化成热能耗散掉,从而显著提高墙板的隔音效果。
Huayang Lvjian hy-t1 sound insulation coating
Huayang hy-t1 sound insulation coating is developed after years of research and development. It is a kind of water-soluble sound insulation and damping high-performance sound insulation coating in the world. The sound insulation and noise reduction effect of the coating depends on its loss factor, forming a damping constrained structure. When sound and vibration begin to be emitted from sound impact, the sound insulation damping coating will form a damping protective layer to increase the pipeline density The acoustic mechanical energy is converted into thermal energy consumption and dissipated, so as to significantly improve the sound insulation effect of the wall panel.
深圳市华阳绿色建筑节能有限公司(-1990-292-3619)专业致力于隔声材料的研究,通过不断的努力与科技创新,研发设计出一系列新型楼板减震隔声材料,并获得国家发明专利。
免费2人已点赞
装饰装修材料
返回版块6.32 万条内容 · 194 人订阅
普通玻璃隔断早过时了,换上夹丝玻璃,高颜值新房装修免不了要对家里的每一个空间进行再组合及再分割,这时就需要用到门和隔断。在过去,很多家庭装修的时候采用的都是普通透明玻璃门或玻璃墙来做隔断,一来不会影响到室内的采光效果,二来也会让房间显得更加的宽广。 但是如今,随着人们审美的提高,越来越多的人开始追求更加多样化和新颖的装修材料。除了普通透明的玻璃材质以外,现在有一种新型的玻璃——夹丝玻璃,比普通玻璃更具有美感,而且有高强度抗击力,也特别适合用作门和隔断的材料。
全部回复(22 )
只看楼主 我来说两句隔音砂浆:沧江中学东侧幼儿园和教育配套设施建设项目【佛山高明区】
隔音涂料:华阳绿建隔音涂料材料由新型的高性能阻尼材料加入适量的其它补强材料、阻尼防腐材料、阻燃剂等以及相关水性助剂配制而成。
