土木在线论坛 \ BIM技术 \ 施工BIM应用 \ Autodesk Revit MEP 2012安装失败
发布于:2017-09-29 15:05:29 来自:BIM技术/施工BIM应用 [复制转发]
提示:
2017/9/29:14:31:59 Administrator PC-201709280939 === Setup started on PC-201709280939 by Administrator ===
2017/9/29:14:31:59 Administrator PC-201709280939 Launch
2017/9/29:14:32:08 Administrator PC-201709280939 === Setup ended ===
2017/9/29:14:32:00 Administrator PC-201709280939 === Setup started on PC-201709280939 by Administrator ===
2017/9/29:14:32:00 Administrator PC-201709280939 Launch
2017/9/29:14:32:10 Administrator PC-201709280939 PageOpen LaunchDialog
2017/9/29:14:32:20 Administrator PC-201709280939 PageOpen LicenseDialog
2017/9/29:14:32:27 Administrator PC-201709280939 PageOpen ProductInfoDialog
2017/9/29:14:32:54 Administrator PC-201709280939 PageOpen ProductSelectionDialog2
2017/9/29:14:33:44 Administrator PC-201709280939 PageOpen FullProgressDialog
2017/9/29:14:33:44 Administrator PC-201709280939 Installing Microsoft Visual C++ 2005 Redistributable (x86): D:Revit3rdPartyx86VCRedist2005vcredist_x86.exe /q:a /T:C:Windows emp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:UsersADMINI~1.PC-AppDataLocalTempvcredist_x86_2005.log"" "
2017/9/29:14:33:58 Administrator PC-201709280939 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2017/9/29:14:33:58 Administrator PC-201709280939 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:Revit3rdPartyx86VCRedist2008SP1vcredist_x86.exe /q
2017/9/29:14:34:20 Administrator PC-201709280939 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2017/9/29:14:34:20 Administrator PC-201709280939 Installing Microsoft Visual C++ 2010 Redistributable (x86): D:Revit3rdPartyx86VCRedist2010vcredist_x86.exe /q /l C:UsersADMINI~1.PC-AppDataLocalTempvcredist_x86_2010.log
2017/9/29:14:34:23 Administrator PC-201709280939 Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2017/9/29:14:34:23 Administrator PC-201709280939 Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2017/9/29:14:34:23 Administrator PC-201709280939 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2017/9/29:14:34:24 Administrator PC-201709280939 PageOpen InstallCompleteDialog
2017/9/29:14:34:44 Administrator PC-201709280939 === Setup ended ===
2017/9/29:14:36:19 Administrator PC-201709280939 === Setup started on PC-201709280939 by Administrator ===
2017/9/29:14:36:19 Administrator PC-201709280939 Launch
2017/9/29:14:36:28 Administrator PC-201709280939 === Setup ended ===
2017/9/29:14:36:21 Administrator PC-201709280939 === Setup started on PC-201709280939 by Administrator ===
2017/9/29:14:36:21 Administrator PC-201709280939 Launch
2017/9/29:14:36:27 Administrator PC-201709280939 PageOpen LaunchDialog
2017/9/29:14:37:46 Administrator PC-201709280939 PageOpen LicenseDialog
2017/9/29:14:38:40 Administrator PC-201709280939 PageOpen ProductInfoDialog
2017/9/29:14:46:35 Administrator PC-201709280939 PageOpen ProductSelectionDialog2
2017/9/29:14:46:50 Administrator PC-201709280939 PageOpen FullProgressDialog
2017/9/29:14:46:51 Administrator PC-201709280939 Installing Microsoft Visual C++ 2010 Redistributable (x86): D:Revit3rdPartyx86VCRedist2010vcredist_x86.exe /q /l C:UsersADMINI~1.PC-AppDataLocalTempvcredist_x86_2010.log
2017/9/29:14:46:53 Administrator PC-201709280939 Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2017/9/29:14:46:54 Administrator PC-201709280939 PageOpen InstallCompleteDialog
2017/9/29:14:50:14 Administrator PC-201709280939 === Setup ended ===
2017/9/29:14:51:41 Administrator PC-201709280939 === Setup started on PC-201709280939 by Administrator ===
2017/9/29:14:51:41 Administrator PC-201709280939 Launch
2017/9/29:14:51:48 Administrator PC-201709280939 === Setup ended ===
2017/9/29:14:51:43 Administrator PC-201709280939 === Setup started on PC-201709280939 by Administrator ===
2017/9/29:14:51:43 Administrator PC-201709280939 Launch
2017/9/29:14:51:47 Administrator PC-201709280939 PageOpen LaunchDialog
2017/9/29:14:51:53 Administrator PC-201709280939 PageOpen LicenseDialog
2017/9/29:14:51:56 Administrator PC-201709280939 PageOpen LaunchDialog
2017/9/29:14:53:23 Administrator PC-201709280939 PageOpen BeginDeploymentDialog
2017/9/29:14:53:27 Administrator PC-201709280939 PageOpen LaunchDialog
2017/9/29:14:54:58 Administrator PC-201709280939 PageOpen LicenseDialog
2017/9/29:14:55:04 Administrator PC-201709280939 PageOpen ProductInfoDialog
2017/9/29:14:55:33 Administrator PC-201709280939 PageOpen ProductSelectionDialog2
2017/9/29:14:55:48 Administrator PC-201709280939 PageOpen FullProgressDialog
2017/9/29:14:55:48 Administrator PC-201709280939 Installing Microsoft Visual C++ 2010 Redistributable (x86): D:Revit3rdPartyx86VCRedist2010vcredist_x86.exe /q /l C:UsersADMINI~1.PC-AppDataLocalTempvcredist_x86_2010.log
2017/9/29:14:55:50 Administrator PC-201709280939 Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
求大神解决
施工BIM应用
4749 条内容 · 269 人订阅
高层钢结构BIM软件研发及在上海中心工程中的应用
