土木在线论坛 \ 园林景观 \ 景观规划设计 \ 捷克LIKO NOE生态办公楼
捷克LIKO NOE生态办公楼
发布于:2017-08-31 16:42:31 来自:园林景观/景观规划设计 [复制转发]
▼ 建筑外观,立面长满植物,融于自然之中,external view of the building, green facade merges into the nature
建筑介绍
Architecture Description
建筑被分成了两支,表现出了强烈的二元性,对观察者产生了重要的影响。建筑的表面设有种满植物的巨大圆盘,仿佛与大地融为了一体。
Architecture of the building presents dichotomous conception of space increasing its effect on a spectator through its duality. The spectator has a feeling of entering an entity connected with earth and its essence visually represented by large wheels full of greenery.
▼ 建筑立面长满植物的巨大圆盘,the large wheel with plants on the facade
棕榈教育官网:palm-edu
建筑由两个体块组成,办公区位于地上,由承重CLT木板构成,外侧喷设隔汽泡沫保温层,并覆以垂直绿化,形成有生命的立面。地下层设置隔音室,通过整体浇灌混凝土建造。
棕榈教育论坛:zonglujiaoyu
The structure is comprised of two main volumes. Above-ground office section is constructed from load-bearing wooden CLT panels, insulated by a vapor-open sprayed ICYNENE insulation and covered by vertical gardens – living facade. Underground section with acoustical chamber is built out of monolithic concrete.
▼ 平面图,建筑由两个体块组成,plan, the structure is comprised of two volumes
建筑的室内构造与外部结构相呼应,空间连续流畅,轻盈而通透,人们可以透过不同位置的开窗看到室外交错的景观。
Inner construction equals the outer structure. Heaviness of the construction is negated by its truthfulness and all that remains is spatial experience with the horizon fluently interlaced through vistas from the inside out.
▼ 室内构造与立面呼应,办公空间流畅通透,interior construction equals to the facade structure, creating open and fluent working space
建筑师将项目中使用的材料种类控制在最少,创造出了形式纯粹的理想工作环境,让人们可以把注意力集中在实验上。
Minimum of material types lays the foundation of formal purity of an environment optimal for focused laboratory work.
▼ 地下室由混凝土浇筑,设有设备间,basement is composed of concrete, containing equipment space for the architecture
▼ 用料简洁,创造不受打扰的实验室环境,minimum material creates an ideal laboratory space without disturbance
生态与建筑
Ecology and Architecture
LIKO NOE可以说是生态建筑典范,在建筑和工作环境的生态性上获得了许多成功。建筑中使用自然热稳定系统,在尽可能少对周边环境产生影响的前提下,利用自然资源进行采暖和降温。人工湿地水处理系统实现了雨水和废水的循环利用,而通过光热墙面加温的建筑底土则大大提高了热泵的效率。
LIKO NOE can be seen as an exemplary project among ecological approaches toward architecture and work environment. It utilizes so called natural thermal stabilisation. The building is heated and cooled primarily using natural resources with emphasis on minimal impact on the surroundings. It uses constructed wetlands for wastewater treatment, that repeatedly processes rainwater as well as wastewater. The subsoil of the building is heated through photothermal wall, which increases efficiency of the heat pump.
▼ 湿地水处理系统,wetland water treatment
▼ 水处理分析图,water treatment analysis
▼ 建筑耗能分析图,energy analysis
这些成果表明艺术和科学并非对立的,它们可以相互渗透,合而为一。设计的初衷是要在建筑中尽量使用生态手段,创造一座超高品质的生态建筑,这也成为了建筑最重要的特征。
This approach proves, that art and science need not exist adjacently, but they can permeate one another. At the genesis of the design was the determination to encompass maximal quantity of ecological criteria. And those have then become the main subject matter.
▼ 建筑表面种有不同植物,颜色随季节变化,既生态又美丽,various plants on the facade which colors change according to seasons, being
ecological while meeting aesthetic requirements
毫无疑问,生态原则在这个项目中十分突出,但它并没有与建筑割裂,而是融合在了结构之中,成为了建筑本身。
The ecological principle in no way stands out of the building, it is not demonstratively paraded. Instead it becomes one with the structure, it becomes its very architecture.
▼ 生态与建筑合而为一,融于自然之中,ecological principle became part of the architecture, merging into the environment
景观规划设计
25.01 万条内容 · 265 人订阅
Paprocany湖岸景观
波兰蒂黑居民经常在Paprocany湖度过他们的闲暇时光。 在湖岸走廊附近拥有许多康体旅游景点的娱乐中心,景观建筑师对这一区域的重新塑造旨在挖掘景观价值,为当地居民提供更多的休闲娱乐的选择。 设计的初衷是沿着湖岸建造一条木质的蜿蜒的走廊,局部凸出到湖面上方,有些部分则退回到靠近岸边的绿地。
