© Nico Saieh
V之家是由建于上世纪六十年代晚期的一座公寓翻新和扩建而来。 From the architect. V house is a renovation and extension of a existing house designed and builted in the late sixties.
© Nico Saieh
First Floor Plan/首层平面图
原先项目是带下斜屋顶的两层楼建筑,底层有公共空间和服务设备,一楼有卧室。翻新的工作包括去除原先的屋顶,拆除底层不必要的结构墙体,扩张项目面积,改变外形,并进行外观加盖和翻新。 Originally the house consisted in a two levels building, with inclinated roofs, that included public spaces and services on the ground floor and bedrooms in the first floor. The renovation consisted in remove all the original roofs, demolish non structurals walls of the ground floor, extend this and reconfigurate and redo newly the same program in a bigger surface.
© Nico Saieh
© Nico Saieh
二楼加入了卧室并进行扩张。 除此之外,设计师营建了一个连接室内外的露台通道,使屋顶庭院变得宽阔,作为一个阳光房和协调项目周围环境的阳台。同样在这一层,设计师安装了太阳能板,用于加热项目和泳池所需的热水。 The second floor was extended also and contains the bedrooms. Besides we create a roof terrace with access from the interior and exterior in order to have an extension of the yard on the roof serving like solarium and balcony of the surrounding area improving the insulation of the house. In this level we locate also solar panels contributing with the heating water of the house and the pool.
© Nico Saieh
在停车场下,设计师把原本的锅炉房改装成一个工作和健身的场所。 Under the parking we incorporate a place of work and a gym in what was formerly the boiler room.
© Nico Saieh
项目新墙体、室内装饰的面板和粉刷石灰的走廊中都包含了水泥元素。项目外部的耐候钢和镀铝锌板护坡是垂直的,使项目看起来更加独立。 The materiality of the house is a mix of concrete in the new walls and in the slab of the interior, travertine pavement in all the house and corten steel and aluzinc revetment for the exteriors in all the facades that are ventilated in order to increase the insulation of the house.
© Nico Saieh
© Nico Saieh
© Nico Saieh
© Nico Saieh
Basement Plan/地下室平面图
Second Floor Plan/二层平面图
Roof Plan/屋面平面图
North Elevation/北立面
South Elevation/南立面
East Elevation/东立面
West Elevation/西立面
Section 1/剖面1
Section 2/剖面2
Section 3/剖面3
© Nico Saieh
建筑设计:Mathias Klotz 地点:智利,圣地亚哥大都会,拉斯孔德斯市,拉斯孔德斯区 面积:480.0 ㎡ 项目年份:2011 摄影师:Nico Saieh 联合设计:Héctor Hormazábal 结构设计:Patricio Stagno 建造:Estructuras Cordillera 景观设计:Francisca Saelzer |
1人已打赏
居住建筑设计
返回版块28.67 万条内容 · 403 人订阅
泰国Baan San Kraam住宅区风景园林:Sanitas Studio Co.,Ltd. 年份:2013年 地点:Cha-Am,Petchaburi,泰国 面积:23,109.96㎡ 委托人:Sansiri PLC 总设计师:Sanitas Pradittasnee 设计团队:Ronarong Chompoopan、Supavadee Nimawan、Rachaniporn Tiempayotorn、Amisa Raksiam、Vongvaritt Siwatwarasuk
只看楼主 我来说两句抢地板回复 举报
可以可以的
