这个小型建筑位于札幌北部,那里的居住区都被分割的像网格一般。一个被三栋建筑包围的大约100平方米的区域保留了下来。在建筑的东边,由散布的原始白杨林充当防护林。虽然这些树木并没有对地块本身产生直接影响,但却间接的影响建筑规范条例,由于退线距离的规定,导致了区域内部可用空间减少至40平方米。
The parcel is located in the north of a city named Sapporo, where the housing block is split like a grid. Surrounded by 3 buildings, a tiny parcel that contains about 100 sqm was left over. On the east side of the building, there is a promenade with an old growth poplar forest which acts as a windbreaker. While these trees don’t have a direct influence over the parcel itself, they indirectly contribute to the building standard law, which requieres an inevitable set back distance, reducing the usable space within the parcel to 40 sqm.
区位图
楼梯,浴室,楼梯平台和其他的各种空间都将布置在建筑的北部。这是一个位于公共空间与私密空间之间的一个缓冲区。在它后面,卧室层低于周边房间60厘米。
In the northern section of the building you will find the stairway, the bathroom, the landing, and other various spaces will be arranged in the north of the building. This is a Buffer zone between the public space and the private space. Behind it, the living room floor is -600mm lower than the surrounding rooms.
出于建造半地下室的决定,房间天花板被抬高。建筑师设计了一个类似门廊的缓冲区,并在南部做了一个巨大凸窗。在首层和第二层之间使用一些遮泥板,并且在顶层设置了一个很大的卧室。
With the decision to make a semi basement, the ceiling of the room becomes higher. I designed a Buffer zone, like a porch, and a big bay window in the south of the LDK. Between the first and the second floor there is some duckboards, and a large bedroom on the top floor.
尽管根据建筑规范条例,在建筑内必须设置窗户,这个房子却没有任何可以观看外部风景的窗户。窗户都被纤维素胶板遮挡,通风窗都被木板覆盖,它们与外墙使用的是同一种材料。
This house doesn’t have any window to regard the outer scenery; however, according to the building standard law, some windows must be placed in the building. The windows are covered by a fiber plastic board and, and the ventilation windows are covered by a wooden board, which is the same material as the exterior wall.
剖面图
从南向剖面看,矩形空间采光只允许反射光照亮起居空间。 但是在这个矩形的背后,光源初露真容,并且渐渐地显示出另一番特点。
In the southern section of the building, the light collects in the rectangle allowing only the reflecting light to shine back into the living space. But in the back of this rectangle, its light’s origin shows face and changes little by little into another characteristic thing.
区位图
西南立面
东北里面
剖面图
平面图
平面图
建筑设计:五十岚淳建筑师事务所 地点:日本 札幌 项目面积:71.54平方米
Architects: Jun Igarashi Architects Location: Sapporo, Japan Project Area: 71.54 sqm
只看楼主 我来说两句抢地板回复 举报
