土木在线论坛 \ 暖通空调 \ 专业英语 \ 各种阀的相关术语加英语对照
各种阀的相关术语加英语对照
发布于:2006-09-06 17:39:06 来自:暖通空调/专业英语 [复制转发]
各种阀的相关术语加英语对照,比较全面,供大家参考
全部回复(4 )
  • vincent_nk
    vincent_nk 沙发
    三通阀 three-way isolating valve
    三通阀 three-way valve
    三通式 Three way type
    上密封 Back seat
    上密封试验 Back seal test
    渗漏量 Leckage
    升降立式止回阀 Vertical lift check valve
    升降式止回阀 Lift check valve
    适用介质 Suitable medium
    适用温度 Suitable temperature
    手摇油泵(阀) Manual Oil Pumps Valves
    疏水阀 drain valve
    双金属片式疏水阀 Bimetal elements steam trap
    双口排气球 Double Opening Exhaust Valves
    双联弹簧式安全阀 Duplex safety valve
    双闸板 Double gate disc
    双闸板平板闸阀 Double Disc Flat Gate Valves
    水封闸阀 Water Seal Gate Valves
    水力喷射器(真空泵) Vacuum Pumps
    伺服阀 servovalve
    填料 Packing
    填料垫 Packing seat
    填料函 Stuffing
    填料式旋塞阀 Gland packing plug valve
    填料箱 Stuffing box
    填料压盖 Gland
    通气阀 breather valve
    通气阀;呼吸器 breather
    通用阀门 General valve
    吐出阀;排出阀 discharge valve
    吐出阀限位器 delivery valve guard
    微启式安全阀 Low lift safety valve
    微阻缓闭止回阀 Tiny Drag Slow Shut Check Valves
    吻合度 Percent of contact area
    蜗轮传动蝶阀 Butterfly Valves with Gear Actuator
    蜗轮传动装置 Wormgear actuator
    屋脊式隔膜阀 Weir diaphragm valve
    无阀泵 valveless pump
    无阀隔膜泵 valveless diaphragm pump
    无阀振动泵 valveless vibration pump
    无负荷漏汽量 No-load steam loss
    无负荷漏汽率 Rate of no-load steam loss
    吸(抽)气阀 Aspirating valves
    吸入阀 suction valve
    吸入阀限位器 suction valve guard
    先导式安全阀 Pilot operated safety valve
    先导式液压阀 Pilot-operated reducing valve
    相对静偏差 Relative static characteristics derivation
    相对流量特性偏差 Relative flow characteristics derivation
    相对压力特性偏差 Relative pressure characteristics derivation
    销轴 Hinge pin
    楔式闸阀 Wedge gate valve
    斜板式蝶阀 Indined disc butterfly valve
    泄料(放空,排污)阀 Blowdown valves
    泄压阀 Decompression valves
    泄压阀 pressure release valve
    泄压阀;安全阀 relief valve
    卸荷式减压阀 Balanced reducing valve
    型号 Type Model
    旋启多瓣式止回阀 Multi-disc swing foot valve
    旋启式止回阀 Swing check valve
    旋启双瓣式底阀 Double disc swing foot valve
    旋塞阀 Cock
    旋塞阀 plug valve
    压力(増压)阀 Pressure valve
    压力调节阀;压力控制阀 pressure controlled valve
    压力特性 Pressure characteristics
    压力特性偏差 Pressure characteristics derivation
    压力增长系数 Pressure increasing ratio
    摇杆 Arm
    液动装置 Hydraulic actuator
    液化气管件 LPG Pipe Fitting
    液下泵 Under Water Pumps
    液压执行器 hydraulic actuator
    仪表针形截止阀 Meter Needle Type Globe Valves
    溢流阀 overflow valve
    翼形阀;锥形阀 wing valve
    油封式旋塞阀 Lubricated plug valve
    有阀翼板 double acting wing
    有阀翼板 wing with valve
    有负荷漏汽量 Load steam loss
    有负荷漏汽率 Rate of load steam loss
    圆板阀;圆盘阀 disc valve
    圆盘式疏水阀 Shemostatic team trap
    圆柱齿轮传动装置 Cylindrical gear actuator
    圆锥齿轮传动装置 Conical gear actuator
    闸板 Wedge disc
    闸板式隔膜阀 Wedge diaphragm valve
    闸阀 gate valve
    闸阀 sluice valve
    针形阀 Pintle valve ; Needle valve
    真空破坏阀 vacuum breaker valve
    蒸汽疏水阀 Automatic steam trap Trap
    整定压力 Set pressure
    正向作用式减压阀 Direct acting reducing valve
    支架 Yoke
    直接载荷式安全阀 Direct loaded safety valve
    直接作用式减压阀 Direct-acting reducing valve
    直流式 Y-globe type
    直流式截止阀 Oblique Stop Valve
    直通单向阀 inline check valve
    直通单向阀 straightway check valve
    直通阀 Throughway Valve
    止回阀 Check Valve
    止回阀;回流阀 reflux valve
    制动阀 Brake valves
    中压阀门 Middle pressure valve
    钟形浮子式疏水阀 Inverted bucket steam trap
    钟形罩 Inverted bucket
    轴套 Axis Guide
    主阀 Main valve
    主要外形尺寸 Prime out-form dimensions
    主要性能参数 Specifeca tion speeification
    注液漏斗阀 Priming Tundish Valve
    柱塞阀 Plunger valve
    柱塞截止阀 Plunger Globe Valve
    柱塞型摆动阀 rocking plunger valve
    撞击手轮 Impact handwheel
    锥形阀;翼形阀 conical valve
    自动循环阀 Automatic Recirculation Valve
    组合阀 Combination valves
    最大过冷度 Maximum subcoold temperature
    最大流量 Maximum flow rate
    最大压差 Maximum differential pressure
    最低工作压力 Minimum operating pressure
    最高背压率 Maximum rate of back pressure
    最高工作背压 Maximum operating back pressure
    最高工作温度 Maximum operating temperature
    最高工作压力 Maximum operating pressure
    最高排水温度 Maximum temperature at discharging
    最高允许温度 Maximum allwable temperature
    最高允许压力 Maximum allowable pressure
    最小过冷度 Minimum subcooled temperature
    最小压差 Minimum differntial pressure
    2006-09-06 21:19:06
    赞同2
  • vincent_nk
    vincent_nk 板凳
    隔膜 Diaphragm
    隔膜阀 diaphragm valve
    隔膜式控制阀 diaphragm operated comtrol valve
    工作背压 Operating back pressure
    工作温度 Operating temperature
    工作温度 Working temperature
    工作压差 Operting differential pressure
    工作压力 Operating pressure
    工作压力 Working pressure
    公称通径 Nominal diameter
    公称压力 Nominal pressure
    固定式球阀 Fixed ball valve
    关闭压力 Lockup pressure
    关阀过冷度 Subcooled temperature of close valve
    关阀温度 Closing valve temperature
    管道安全阀 Piping Safety Valves
    过冷度 Subcoold temperature
    过流阀(或节流阀) Restrictor Valves
    喉径 Throat diameter
    滑阀 slide valve
    滑阀式回转活塞泵 rotary piston pump with slide gate
    滑阀型转子泵 eccentric rotary pump with sliding sleeve
    环形阀 annular valve
    环形阀 double beat valve
    换向阀 selector valve
    换向阀 shuttle valve
    回转滑阀活塞泵 piston pump with rotary gate
    回座压力 Re-seating pressure of a safety valve
    活塞昵减压阀 Piston reducing valve
    活塞式阀 piston valve
    活塞式阀;柱塞式阀 plunger valve
    活塞式减压阀 Piston reducing valve
    减速阀 Deceleration valves
    减压比 Pressure reducing ratio
    减压阀 pressure reducing valve
    浆液阀 Parallel Slide Valves
    角阀 Angle Valve
    角阀 isolation valve angle configuration
    角式 Angie type
    角式节流阀 Angle Throttle Valves
    角式截止阀 Angle Stop valves
    铰链阀;片状阀 flapper valve
    节流阀 throttle valve
    节流阀 choke valve
    节流阀;节流 throttle
    结构长度 Face-to-face dimension ;End-to-end dimension; Face-to-centre dimension
    结构形式 Type of construction
    截止阀 Globe valve
    截止阀 Shut-off Valve
    截止阀;关断阀 shut-off valve
    截止式隔膜阀 Globe diaphragm valve
    紧急切断阀 Emergeny Cut-off Valves
    进气阀 air intake valve
    进水阀;进口阀门 inlet valve
    静态特性 Static characteristics
    静态特性偏差 Static characteristics derivation
    开阀过冷度 Subcooled temperature of open valve
    开阀温度 Opening valve temperature
    开启高度 Lift
    壳体试验 Shell test
    壳体试验压力 Seal test pressure
    空气阀门 Air valves
    快速排污阀 Quick Draining Valves
    类型 Type
    冷凝结水排量 Cold condensate capacity
    冷态试验差压力 Cold differential test pressure
    理论排量 Theoretical flowing capacity
    连接槽尺寸 Dimension of connecting channel
    连接尺寸 Conncetion cimension
    连接形式 Type of connection
    帘面积 Curtain area
    流道面积 Flow area
    流道直径 Flow diameter
    流量孔板 flow orifice plate
    流量控制阀 flow control valve
    流量特性 Flow characteristics
    流量特性偏差 Flow characteristics derivation
    漏汽量 Steam loss
    脉冲式疏水阀 Impulse steam trap
    密封面 Sealing face
    密封试验 Seal test
    密封试验压力 Seal test pressure
    明杆平行式双闸板闸板 Double Disk Parallel Gate Valves
    明杆闸阀 Outside screw stem rising through handwheel type gate valve
    膜片 Diaphragm
    内压自封 Pressure seat
    逆止阀;止回阀 check valve
    逆止阀;止回阀 non-return valve
    逆止阀;止回阀;单向阀 check valve
    排放背压力 Brilt-up back pressure
    排放压力 Relieving pressure
    排灰阀 Ash valves
    排量系数 Coefficient of discharge
    排气阀 air release valve
    排气阀 Exhaust valves
    排气阀 Vent Valve
    排水阀 Drainage valves
    排水温度 Temperature at discharging condensate
    排污阀 blowdown valve
    排污箱(阀) Waste Valves
    排渣闸阀 Scum Gate Valves
    盘阀 moushroom valve
    盘状阀 plate valve
    旁路阀 by pass valve
    配汽活塞阀缸套 piston valve line
    喷射阀 injection valve
    喷射阀 sprayer valve
    喷水阀 spray water valve
    频跳 Chatter
    平衡阀 Balance valves
    平衡式 Balance type
    平行式闸阀 Parallel gate valve Parallel slide valve
    启闭件 Disc
    启闭压差 Blowdown of a safety valve
    起始升程 Commencement of lift
    气动装置 Pneumatic actuator
    气阀摇臂 valve arm
    气-液动装置 Pneumatic-hydraulic actuator
    潜水电泵(排污泵) Submerged Motor Pumps
    切断阀;截止阀 block valve;shut-off valve;stop valve
    切断式止回阀 stop check valve
    切换阀;多向阀 changeover valve
    球、球芯 Ball
    球阀 Ball valve
    球阀 globe valve
    球体 Ball
    全启式安全阀 Fall lift safety valve
    热凝结水排量 Hot condensate capacity
    入口隔离门 suction isolating valve
    塞子 Plug
    2006-09-06 21:18:06
    赞同1
专业英语
313 条内容 · 80 人订阅
GMP英语
PIC/S的全称为:Pharmaceutical Inspection Convention/Pharmaceutical Inspection Cooperation Scheme, PIC/S(制药检查草案), 药品检查协会(PIC/S) ,也有人称PIC/S为医药审查会议/合作计划(PIC/S) PIC的权威翻译:药品生产检查相互承认公约API(Active Pharmaceutical Ingredient) 原料药 又称:活性药物组分
